Question about Kenwood KAC- X810D Car Audio Amplifier
Is the P.con the hook up that turns the amp on and off? If yes, then where does the other end connect to?
My vizio LCD TV has vertical lines. issue is connection btwn LVDS cable and T-con panel. reset the connection- fixed the issue for a day, but came back. next step- replacing the cable/T-con/both?
Yes. Replace both. If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 18, 2017 | Vizio Televison & Video
Ford explorer 1997
First use a battery charger to charge the battery, instead of a jump start. Second, with a complete dead battery you may want to pull the connection for the horn under the hood till the battery is completely charged.
May 23, 2014 | 1997 Ford Explorer AWD
2004 Pt Cruiser. Put on a new alternator and new battery...the battery light still came on. when the new alternator was being tested it was fine with all the auxiliary things going...radio, lights, wipers,...
If you have a connection such as you describe, frayed ends, greenish color, what happens is under small loads things seem fine. Until you try to pull a heavy load then you loose your connection. Yes that certainly can be your problem. You should replace either the cable end fitting or the whole cable. You may need the whole cable if there is not enough slack in the cable to trim off the end and attach a new one, and still reach the batt terminal.
Jul 02, 2013 | Cars & Trucks
Can I hook two 12in. Subs up with a 1100w amp. Sony explode, pioneer subs
Yes....hook one up to the left channel and one up to the right.....once everything is wired up.....keep gain down on amp and turn stereo on.....turn up stereo with amp gain down to right before high end speakers start to distort......then while its playing, turn amp gain up about 1/2 way. close your trunk and hop in drivers seat....sound gd????? You might have to adjust level on amp and bass on head unit to taste.....Be careful though....pioneer subs are only rated around 300 watts continuous.....dont want to blow them...gd luck....
Mar 20, 2012 | Pioneer Car Audio & Video
Is the p.con the spot where i should hook up the remote wire on a kac9105d kenwood amp?
Yes it is. it runs to the blue and white striped wire coming off the head uni.
Oct 03, 2010 | Kenwood KAC9105D Car Amp
How to hook up without connectors
car colors
yellow 12v switched
orange 12v con
green rf-
lite green rf+
grey lf- paired with tan
tan lf+
blue rr+
lite blue rr-
yellow lr- Paired with brown
brown lr+
pink pwr antenna
brown alone illumination
grey alone illumination dimmer
black ground
radio wires
purples rr
green lr
grey rf
white lf
red switched
yellow 12 con
bluewhite stripe ..amp turn on
blue power ant
black ground
hope it helps
Jun 07, 2010 | JVC AM FM CD DET FACE CAR STEREO
Air con pump not engauging
Hi:
You should verify that your AC system still has a full charge of refridgerant, and if it does,
The problem is most likely the AC clutch assembly on the front of the compressor.
Since the dash light works, and the fan turns on, there is power to the system, but the compressor won't turn on if the pressure switch says the charge is low, and if you turn the switch, and someone can hear a click of the compressor clutch solenoid, but no air, the clutch assembly is probably the culprit
Nov 06, 2009 | 2000 Honda Civic
Printing syntax
'declare the variables
Dim Connection
Dim ConnString
Dim Recordset
Dim SQL
'define the connection string, specify database driver
ConnString="DRIVER={SQL Server};SERVER=yourServername;UID=yourUsername;" & _
"PWD=yourPassword;DATABASE=yourDatabasename"
'declare the SQL statement that will query the database
SQL = "SELECT * FROM TABLE_NAME"
'create an instance of the ADO connection and recordset objects
Set Connection = Server.CreateObject("ADODB.Connection")
Set Recordset = Server.CreateObject("ADODB.Recordset")
'Open the connection to the database
Connection.Open ConnString
'Open the recordset object executing the SQL statement and return records
Recordset.Open SQL,Connection
'first of all determine whether there are any records
If Recordset.EOF Then
Response.Write("No records returned.")
Else
'if there are records then loop through the fields
Do While NOT Recordset.Eof
Response.write Recordset("FIRST_FIELD_NAME")
Response.write Recordset("SECOND_FIELD_NAME")
Response.write Recordset("THIRD_FIELD_NAME")
Response.write "<br>"
Recordset.MoveNext
Loop
End If
'close the connection and recordset objects to free up resources
Recordset.Close
Set Recordset=nothing
Connection.Close
Set Connection=nothing
May 16, 2009 | Microsoft Windows Vista Ultimate Edition
Amp
if its the factory radio more likely it dont have RCAs ..You will need a 'speaker to line level adaptor" ..This has 3 or 4 wires at one end and RCAs at the other.simply connect a left and right set from behind radio or from rear speakers into left and right sets on adaptor ..then connect your RCA cables side to amplifier using RCA wires.
Dec 15, 2007 | Car Audio & Video
Amp wont work jxp340
hi if you got a voltmeter TEST IT ALL ON A LOW LEVEL OF VOLUME!! check the outlets of the amp if there is a signal at all... no? - the amp isnt hooked properly! yes? - check if the volt level on the outlets is higher then the level on the inlets of the amp (the amp is amplifying) no? - the amp isnt hooked properly! or its bad... yes? - connect a speaker to see if its working wont put out a lousy spark? check your system, the problem if probably there... check all the connections, fuses, wires begin from battery and go FWD antill the next device isnt working good luck
Feb 21, 2006 | Jensen JXP340 Car Audio Amplifier
Kenwood KAC- X810D Car Audio Amplifier Logo
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
