My dell 5100cn printer is printing orange instead of yellow
  • Gail Elizares Mar 20, 2011
    Yes, I'm using a dell toner cartridge and it was printing in yellow but now its orange. I did check the 20% color and it comes out okay but when I print a spreadsheet it comes orange.
  • 1,915 Answers
Are you using actual dell toner catridge or a 3rd party/remanufactured cartridge. 3rd party products do not always match in color. It is also possible that your printer needs to be calibrated which it should do automatically, or you can usually run from the built in menus on the printer control panel.h
Posted on Mar 20, 2011
  • Mark Schmit
    Mark Schmit Mar 20, 2011
    What you may be seeing is a difference between what your spreadsheet says is yellow and what the printer thinks is yellow. To test this, open up paint and pick the obvious yellow color there and put a block on the page and print it. If it is yellow then something in your spreadsheet is causing a different color to show. This can often be the difference between pantone color numbers.
Dell 5100cn Error cod 010-397 Restart Printer
ahmad, does the printer show as default? if not make it. Try test print and make sure all printer compartment are securely closed.
Jan 11, 2014 | Dell 5100cn Laser Printer
My dell 5100cn printer is not printing red tones at all. Everything comes out in green tones. Has new toner cartridges and drum. What can I do?
The M6090 Magenta Developer is failing. It has lost it's magnetism. So the toner isn't ready to be transferred.
The Cyan Developer G6593 or Yellow Developer H6682 may be failing too, because it can't dependably hold all it's toner. One of those is probably bad too.
Whit
Item, Inc
Aug 17, 2010 | Dell 5100cn Laser Printer
Dell 5100cn printer printing yellow lines across the page.
This can be any of rthe following depending on the position iof the lines on the page. You need to establishe the position of the lines relative to the top of each page and this determines which of the following component will cause the problem
Dirty or damaged developer roller.
Dirty or damaged charging roller.
Dirty or damaged cleaning roller.
Dirty or damaged developer DSD wheels. These wheels are located on the outer ends of the color toner cartridge and appear as a black bushing.
Dirty or damaged transfer roller.
Dirty or damaged transfer drum.
All of them need inspecting and cleaning
Sep 23, 2009 | Dell 5100cn Laser Printer
Dell 5100cn
How do I remove a job history page from printing on a Dell 5100cn printer?
Aug 06, 2008 | Dell 5100cn Laser Printer
Prints only blue and pink
There seems to be an electrical problem with the yellow toner. Check all the electrical contacts that make contact with the yellow toner. They may be just dirty or they may be bent. If they look good then the could be a problem with the power supply of the printer or the engine board.
Jun 16, 2008 | Dell 5100cn Laser Printer
Dell 5100CN Color laser printer - full page wash
Hello from france !!
Your mistake come from the fuser.
Change it and all be fun
See xerox phaser 6300 fuser is most cheaper and it's compatible !!
Jun 08, 2008 | Dell 5100cn Laser Printer
Dell 5100CN Not printing magenta
Dell 5100cn won't print yellow. No error messages except "replace imaging drum soon". Replaced yellow cartridge, cleaned yellow, etc. Still not working
May 13, 2008 | Office Equipment & Supplies
Horizontal Striping Problem on a Dell 5100cn
As you have just replaced the drum you may have a faulty drum unit put old one back in a test if lines go way then return drum to store and get a replacement. If they do not go the check the toners and the fuser unit.
Thanks J
Jan 21, 2008 | Dell 5100cn Laser Printer
Dell 5100cn Laser Printer Problem
My Dell 1600n suddenly stopped printing. It keeps saying "No paper," and even though I've changed papers, fanned it, squared it, changed how much, how little.............it still says "no paper."
Dec 27, 2007 | Dell 5100cn Laser Printer
71 people viewed this question
k24674
jasbo
jasbo
