My Twchnics SU-Z900 stereo integrated amp won't produce sound. I've checked the speakers on another stereo and they're fine. Is this able to be fixed?
  • 2,098 Answers
Hi colinthomson,
Yes this is fixable. The caused of this problem is the output IC which was gone bad(open/shorted). This IC(mounted in heat sink) is responsible for producing sound output feeding to the speakers. Most of the time this is accompany of open fusible resistor in line with the power supply. If you don't have necessary tools and test instrument and can't troubleshoot it yourself, I would advice you to look for a qualified technician or send it to your local repair shop to isolate the problem.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on Mar 20, 2011
STEREO HAS NO SOUND OUT OF SPEAKERS COMING FROM AMP
I suggest you begin by checking the integrity of the speakers and wiring. This is a fairly easy test to perform and I usually used a pp3 9 volt battery across each pair of speaker wires to ensure each speaker produces a similar amount of crackle and hiss as the wires are wiped across the battery terminals.
Once that test has been performed and found to be satisfactory it is time to connect the wires to the output of the device; radio or amp.
If there is no sound it will be because there is no output from the device. At this point before calling the repair shop it would be a good idea to read the instruction manual to ensure the stereo is being operated correctly.
Aug 10, 2015 | JVC Car Audio & Video
Dennis my 1995 lincoln towncar JBL radio quit producing sound the system comes on fine but I get no sound could u help me please, what is the problem?
The Amp in the trunk might have blown,
Town Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Blue/Red
Car Stereo Antenna Trigger Wire: Blue
Car Stereo Amplifier Location: Trunk
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6? x 9? Speakers[img src="http://www.assoc-amazon.com/e/ir?t=modilife-20&l=as2&o=1&a=B00009UHRE" width="1" height="1" border="0" alt="">
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Check the fuses
24851106-prgqozi4aluuon54ixeydqz4-5-7.gif 24851106-prgqozi4aluuon54ixeydqz4-5-0_0.jpg
Jul 20, 2014 | 1995 Lincoln Town Car
Technics su a900
I have the same TECHNICS SU A900 MKII as you are talking about and it always runs warm I think using 4R speakers instead of 8R speakers should solve the problem and actually I am thinking of switching to 4R as well.
Oct 13, 2013 | Audio Players & Recorders
2000 chrysler grand voyager Integrated speaker amps???
Replace the speakers if they are amplified types.
Apr 25, 2017 | 2000 Chrysler Grand Voyager
How do I hook up a stereo reciver to the technics su-g91
I assume you want to use the SU-G91 as a power amplifier to drive your speakers. If your receiver has connections for inserting an equalizer (may be labeled pre-amp output and power amp input), remove the jumpers between the pre-amp and the power amp, then run cables from the pre-amp to the SU-G91 inputs. You can have an equalizer between the receiver and the integrated amplifier.
If this is not available, use the recording output (for a tape recorder on older receivers). Note that the volume control on the receiver will be bypassed with this connection.
Sep 23, 2012 | Audio Players & Recorders
Hi I just got a Technics SU V2 amp and can't get sound from the speakers. What size speakers would suit this amp? What is the correct method to connect the speaker leads to the back of this amp,...
Being a 500W amplifier, you need to connect speakers with 300W each. The correct method to connect speakers is red terminal of speaker should be connected to red terminal of amplifier & black to black. The left side to left side speaker & right to right speaker. There may be main & remote terminals. Main speakers are the speakers at local place of the amplifier & remote for remotely placed speakers. I do have Technics SU-V85A which is somewhat similar. Enjoy! A nice piece to listen.
Oct 22, 2011 | Technics SUV500 2-Channel Amplifier
Volume at 10 produces very low speaker output.!?
It sounds to me that all you are getting is the pre-amp stage of the amp and nothing from the power amp stage. As it is on both channels then it is something that is common to both. This could be something to do with the power supply of the power stage. Or whatever is on the heatsink. It could be that the amp uses a single audio amp IC for both channels. If it does my bet is that it's gone. If it uses two sets of semiconductors for the right & left channel it would be highly unlikely that both channels have gone, but not impossible.
Dec 27, 2009 | Audio Players & Recorders
About amplifier specification
sounds like you need a service or users manual...check their website,to find one
May 25, 2008 | Computers & Internet
53 people viewed this question
 Grubhead
Grubhead
