Question about Activeforever Invacare Stratos Compact Aerosol Compressor IRC1710 Stratos Compact Aeros
I have an invacare stratos compact nebulizer machine IRC1710. I washed the parts etc. according to directions, and let them air dry without towel drying them, but I put them in a plastic bowl to air dry, and covered the top of the plastic bowl with a plastic lid, that I discovered had a bit of a tiny hole in one corner, maybe even two or three tiny holes ( or slits.) It is fully dry now, because I let it sit like that overnight, until now. I guess it is o.k. to air dry with no cover on it anyway, but, I still worry that it might get contaminated, even though I covered the plastic bowl with a lid. The tiny little holes or slits in the plastic bowl, or lid, that let air in from my room had me a bit concerned. Will those two little holes or slits let contaminated air into the bowl? Or is it o.k. to use the parts anyways? Please let me know. Thanks a lot. Laurie Klassen.
Nebulizer won't put out steam
Make sure compressor is putting out air.
Then make sure funnel looking piece is in the nebulizer cup.
John
Lighthouse Medical
Mar 13, 2013 | Ultra Products Ultra Sonic Compact...
What is the proper why for cleaning the Respironics HS860 Sidestream reusable nebulizer
Soak in a solution of one part distilled white vinegar and three parts water for 30 min. Rinse in water when done and lay out parts on a dry towel to air dry.
Jun 20, 2010 | Respironics HS860 Sidestream Reusable...
Sterlize my nebulizer
From Pari.com:
What is the best way to clean and disinfect my PARI Nebulizer?
Cleaning: After every treatment, thoroughly rinse the nebulizer to remove medication. Hand-wash with warm water and dish soap. Rinse thoroughly. OR... Wash in the dishwasher using a dishwasher basket on the top rack.
Disinfecting: (done after cleaning) every 2nd treatment day, mix a solution of 1 part distilled white vinegar and 3 parts warm tap water in a clean bowl. Soak the nebulizer parts (except the tubing and mask) for 60 minutes. Rinse thoroughly. OR... Mix a solution using Control III® Nebulizer Disinfectant and soak for 10 minutes. Rinse thoroughly. OR... Boil the nebulizer parts for 10 minutes.
Source: http://www.pari.com/pdd/pdd-faqs.htm
Apr 20, 2009 | Pari Proneb Ultra II Compressor Nebulizer...
Routine cleaning Mabis XP.
If your unit is the one pictured, he cup with the medication can be taken apart to be cleaned... the top unscrews and the nebulizer comes out....and should be done so after every use. Do not use house hold chemicals to clean the unit. Use a water/distilled vinegar mixture to clean, then rinse with clean water.
Apr 07, 2009 | Mabis Neb Xp Portable Handheld Cmpressor...
Battery flashes between orange and green
The rechargable batteries have life and will go bad like any other batery. The battery needs to be replaced. Some of the older units are discontinued so parts are no longer available. New nebulizers can be obtained for as cheap as $100.
Mar 31, 2009 | Invacare Supply Group Invacare Corp...
Running hot
contact email vaigaienterprises@yahoo.co.in
Mar 25, 2009 | Invacare Supply Group Invacare Corp...
Need a manual for invacare stratos compressor nebulizer
Find the product number on the device write it down. Go to Google.com and type in the make model and or pruduct number and suggest you need a product manual. 2nd site try fixya.com if it doesn't take you there from the begginning.
Nov 29, 2008 | Invacare Stratos Compact Aerosol...
There is no mist coming out of the neb machine.
No! don't buy a new machine. First wash the mask, tubes and any other washable part really well by hand. There could be some dryed on fluid blocking the flow of the liquid. Then make sure that the part where you put the liquid does not have liquid on top of the ******** part. Usually a bit of shaking off of the liquid or using a paper towel to dry that part off should help. If this doesn't work let the nebulizer dry out overnight with all parts seperate. I constantly have these kinds of problems with my nebulizer and these seem to do the trick if these don't work then you might need a new machine.
Nov 20, 2008 | Cardinal Airlife Brand Modudose 5 Ml Unit...
Activeforever Invacare Stratos Compact Aerosol Compressor IRC1710  Stratos Compact Aeros Logo
101 people viewed this question
Top Activeforever Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an Activeforever Health and Beauty Expert? Answer questions, earn points and help others
