Question about Refrigerators
Cannot locate water valve in amana refr, mod# afi2538aew. its not in the back,where its usually is.please,help.
  • 17,970 Answers
Check in the next diagram, item 15...
Your parte replacement VALVE, DUAL WATER is the Part Number: AP4081950 made by WHIRLPOOL
Hope helps.
Posted on Mar 20, 2011
My model AFI2538AEW fridge control panel is stuck and I cannot select anything on it.
Can you unplug and replug it back in to reset compter? It might be easier to go to your circuit breaker box, vs pulling fridge out, and turn off fridge from there. That will cause it to reset. Here is the manual for it.
http://kitchen.manualsonline.com/manuals/mfg/amana/afi2538aew.html
Nov 15, 2016 | Refrigerators
How to program a amana modle # afi2538aew put in new card now trying to program it but i don't know what ll is or UR or LR can u help please
Hallo
First disconnected the card again wait 1min and reinserted it.
Now turn Fridge on and do not adjust anything within 24hours please. Wait for temperature to adjust the card is factory settings.
To turn Fridge off and on:
Press theFreezer + pad until "off" is displayed and press the - pad on the fridge or freezer controls to turn refrigerator on.
Hope this was helpful can you please send me a picture of what the controller display message please.
Regards
Jun 08, 2016 | Amana Refrigerators
How to Replace water valve in a ice maker
The water valve is located where the water line connects to the refrigerator in the back. There are usually 4 wires so don't mix them up. One pair is for the ice maker and the other 2 are for the water dispenser in the door. A couple of screws hold it to the frame and you'll see water lines connected to it. Same thing...don'r mix them up.
Sep 07, 2014 | Amana Refrigerators
What is the water valve for my washing machine
usually along the back side u will see it where ur 2 water hoses go into it. usually have to remove the cabinet or back to get to it
Mar 28, 2014 | Amana ALW880WH Top Load Washer
Ice maker problem
Try empty tray and see if ice has froze on any area if not buddy hire a tech it may be electrical component of the ice make
Dec 11, 2013 | Amana / AFI2538AEW
I have an Amana AFI2538AEW. Most of my Vegatables in the crispers are freezing and a bottle of milk in the back is frozen also on the shelf. Can you help me?
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Apr 30, 2011 | Amana AFI2538AE (25.6 cu. ft.) Bottom...
We have an Amana AFI2538AEW we have had two techs. out already and we have replaced the fill valve. But still we have no ice. What happened is it started leaking water out of the fill cup in the ice...
There should be a float connected to this valve that tells the valve when to open and when to close it kinda works like the float valve in your toilet (check this float),as far as the water leaking out of the cup in the ice maker the float probably bad, Hope this works for u
Apr 03, 2011 | Amana Refrigerators
My amana side by side fridge water dispenser drips and seems to drip a lot more when say the toilet flushes or the washing machine is running almost like it starts a siphon
Sounds like you need to replace the water solenoid valve, located where the water line connects to the back of the fridge, usually behind the fiber cover at the bottom.
These valves are damaged by dirt in the lines. Dirt and scale roughs up the valve needle and seat, and leak more with lower water pressure.
You can get valvesand valve kits from appliance part stores, Home depot or sears parts via ordering. I highly suggest an external in-line filter that will stop this forever, and suppliment the internal filter for taste. If particles are damaging this valve, it is also slowly causing damage to the other water valves in the bathrooms and toilets. If you have to replace valve washers a lot, then a whole house filter would be worth it.
Jan 08, 2011 | Amana 22.6 cu. ft. Side-By-Side...
The icemaker overfills and the water keeps running and runs out of the fridge onto the floor
Hi, If the ice maker is overflowing, you will need to change the inlet valve. The inlet valve should only draw water when 120V is sent to the solenoid to open it. The inlet valve is located in back and has the water supply tube attached to it.
I hope this helps you. If I can assist you further, please let me know.
Vic
Jun 05, 2009 | Amana ASB 2623 Side by Side Refrigerator
Amana ice maker not working
From your description, would it be likely to assume that you are experiencing a water pressure issue? If so, then I would start the investigation at the supply valve that attaches to your homes water lines and do whatever is best for you, i.e. replace the valve or attempt to disassemble and inspect it for blockage. Once that has been removed from the list of suspects, the next culprit is your water inlet valve on the refrigerator. This has filter screens and can become blocked by water residue. These can be removed and cleaned or you can replace the valve to completely eliminate any other electrical/mechanical aspects of the valve. Below is a link to assist you in finding parts and diagnostic tips.
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
May 05, 2008 | Amana ARSE66MB Side by Side Refrigerator
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
