Question about Bosch Nexxt 700 Series WFMC6401UC Front Load Washer
Cannot get out and clean the washing machine lint filter. We can open the service flap and unscrew the pump cover, but the lint filter does not come out. Our washing machine ia a MAXX Classic. Thank you for your help, Angeles
    Sergeant:
  • 192 Answers
Manual is here...
https://portal.bsh-partner.com/TCcustomBSH/controller/download_file?PDFOBID=rhdu2Hjcdcso0pdmdb---hNm&UMOBID=rhdu2Jhcdcso0pdmdb---hNm
Go to page 26 for instructions.
Posted on Mar 20, 2011
Where is the pump filter on an lg washer?
The PRIMARY filter for discharged water in most front loaders is located under the opening of the washer behind a small 'door'. There is usually a small tube which you will need to pull the plug from and drain about 2 cups of water into a bucket BEFORE you remove the filter to clean it.
After you unscrew the filter which is mounted from front-to-back and clean it out, replace both filter piece and plug and replace the small drain tube.
Close the access door and operate your machine.
* Clean this filter every month or especially after washing heavy lint-producing materials.
Jul 21, 2014 | LG WM-2277HW Front Load Washer
Bosch washer will not spin
Check the pump filter. This is located at the bottom front right of washer. Look for a drop down flap or cover, once located, unscrew filter anti-clockwise to remove and clean. Be prepared for a lot of water and junk. If you find a closed hose pipe when you remove the drop down flap it is to drain excess water.
The pump itself is directly behind the filter housing, check if there is nothing stuck in the housing, especially after you are cleaning out your filter after a long time. Clean out and refit carefully
Pl click if helped.
Mar 25, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Hi my washing machine starts but afta 5-10 minutes it keeps tellin me to clean pump... how do i do that and where is the pump?
Try cleaning the filter first. The filter is behind a flap on the lower part of the front panel of the machine. The flap is normally opened by pushing at one side - then unscrew the cap that is behind the flap and withdraw the filter. Clean it thoroughly and replace.
If this does not work you will need to remove and clean the pump itself, which is accessed from beneath the machine, but this is a more major job.
Jan 04, 2011 | Whirlpool AWZ412 Front Load Washer
My wahsing machine is not draining and will nor spin
If it is not draining, then it will nbot spin.
If it is a u/k model, then check and clean the pump filter, usually located at the bottom front right of washer behind a drop down cover or flap.
Unscrew anti-clockwise to remove and clean.
Nov 16, 2010 | Zanussi Washing Machines
"ZWF160070W1 Washing machine. Only 18 monthe old!
I would start by checking the filter and cleaning it, this is usually located at the bottom right front of washer behind a flap or cover, unscrew an ti-clockwise to remove and clean.
Nov 14, 2010 | Zanussi WJD1257W Front Load Washer
Bosch wwf1201 won't drain.
Probably a blocked filter that needs cleaning.
You should find this located at the bottom front right of washer behind drop down flap/cover.
Mar 30, 2010 | Bosch Washing Machines
My zanussi washing machine fj1033 finishes normal wash progam but doesnt go into hihg spin therefore clothes are wet rather than damp.if i turn dial to spin cycle only it works that way.please advise.
If you have not already done so, then check and clean the pump filter, this is usually located at the bottom right front of washer, behind a drop down cover or flap.
Jan 08, 2010 | Washing Machines
Display show f21 and it wont drain
the f21 code actually is a no drain code....the machine has an electric pump behind the cover on the bottom with a lint trap in it....just unscrew the lint filter from the pump(there will be alot of water coming out when you take this out) and clean the trap and that should take care of your problem
Oct 01, 2009 | Kenmore Washing Machines
Clothes come out soaking wet seams like it doesn't spin out the w
There are 3 possible places to look for filters as each machine is made differently –
1 If machine has a square flap fitted on the front filter maybe located behind this.
2 It could be located behind the front lower kick panel (remove panel to see).
3 Located inside the sump hose, this is the hose that is attached to the bottom of the
main tub.
Try this:
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Apr 10, 2009 | Maytag Neptune MAH6500A Front Load Washer
Won't rinse or drain
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
Apr 06, 2009 | Washing Machines
Bosch Nexxt 700 Series WFMC6401UC Front Load Washer Logo
1,126 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
