Question about Vacuums
Unit does not recharge. One presumes the battery is kaput; now quite a few years old. Is battery replacable? Cannot see how? Where can I get parts?
    Sergeant:
  • 259 Answers
I would get the make and model of the vacume and call or write the company online that made it for replacement battery.
Posted on Mar 20, 2011
Are those new wireless stick vacuums worth buying? I love the idea but, it seems power must be limited or weak without enough suction.
I retired from fixing battery powered cleaning equipment a few years ago. The problem with wireless is that the batteries don't hold up. They will work fine for a few weeks- then they start to run out of juice after only a few min. On most rechargeables if you don't run them down completely, they only charge to the point you last put it on the charger (It's called battery memory). I personally think the rechargeables are a waist of money, and, when the batteries start to go- are frustrating. Just get an upright, with a side hose. I've got two at home that are over 20 years old. I only had to change the beater bar brush and belt twice in that time. No more than $150 bucks should be your price point for a vacuum used at your own home.
Apr 27, 2017 | Vacuums
Dyson dc30 charging issue
Defective replacement battery - unable to charge/recharge.
Jul 11, 2017 | Vacuums
I have a Eureka Easyclean that will not hold a charge and want to replace the Electrolux battery it comes with and cannot find one. Can you?
Sadly, the battery is not replaceable on this unit. According to the schematic, I can get almost every part but that. This is common with all of the cordless units too. Batteries are usually the same price as purchasing a new unit. If the unit is more than 1 year old, sorry to say its pretty much garbage. IF the unit is less than one year, it should be under warranty and replaced by your local Eureka/Electrolux dealer.
Also, not all hope is lost on this unit, if there is an obvious burn, or connection issue, a little bit of solder should correct the problem.
Good luck!!
Jan 24, 2012 | Eureka 109A Easy Clean 2IN1 Cordless Stick...
I get a blinking yellow light when recharging my IRobot Roomba 550. What's wrong?
I am afraid you are having the problem of old or weak batteries. Old batteries at times tend to show such problems and do not show charge while charging properly. For this purpose, you can use a reliable Nicad Battery Repair Guide through which you can recharge the batteries without any problem and make them work like the new ones within no time, without anyone's help and you can do this all by sitting at home! I tried it and now I never buy new nicad batteries (http://www.nicadbatteryrepair.com/).
Jan 03, 2011 | iRobot Roomba 550 Vacuum
Won't recharge. very weak.
If you know that the charger is actually working and supplying the correct voltage.Then the age of the unit would suggest that the battery is exhausted and it would be cheaper to replace the whole unit.
Hope this was a help.
May 12, 2010 | Black & Decker CHV9600 Handheld Vacuum
Model4210battry won't recharge, is it worth ordering a battery?
don't buy a new battery yet. you can reset the battery by charging for 16 hours, if this does not work, you need to take the battery out, push and hold the power button on your roomba for at least 15 seconds then reinstall the battery. plug in the charger directly to roomba not the docking station and charge until the battery light on the roomba is green. do not interrupt the battery charging cycle. after, leave the roomba charging for an additional 3 days or 72 hours. after, run roomba in max mode and run it till the battery is completely depleted. this will improve the battery overtime by charging again for 72 hours and depleting the battery. do this 3 or 4 times. and the battery should get better
Jun 28, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
Scooba not working after full recharge
NiCD and LiOn batteries have this tendency. They work great for a year, then slowly die off. The problem is you. When new, the device MUST be charged for 14hr nonstop, then every 2-3 months run dead, and recharged again 14hrs nonstop. This is done so the CPU of the Roomba (cool toy) KNOWS what DEAD is and what FULL is. It does this by measuring the amount of currrent flowing thru a very precise resistance. If you do hit and miss charge cycles of the roomba or leave it charging too long, it either develops a flase memory of the above two conditions, or gets HOT and the electrolyte paste dries out. Fix is to wear it out, charge 14hrs, wer it out againand repeat 3-4x. Then recharge and use. If that doesn't fix it, the batteries are too dried and need to be replaced.
Apr 08, 2009 | iRobot 5800 Scooba Vacuum
I have aKirby Diamand series 4 years old
Reason number 1 (not sure why Kirby Co. still has not fixed it) -improperly installed outer bag. You have to push the bag all the way tothe unit so it presses the safety switch that is between exhaust andthe vacuum shell
Reason 2 - defective cord - try wiggling it. Ifyou know how to do it - try removing cord and supplying power directlyto the unit using another cord or wire (ONLY if you know how to workwith electricity.If you get zapped - do not blame me)
Reason 3 - bad power switch (instructions on how to replace it HERE)
Reason 4 (very unlikely) - motor KAPUT
Good Luck
Rocky
Apr 04, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Vacuums Logo
22 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
