Question about Solis Crema SL-70 Espresso Machine
We need a new filter basket insert,where can we buy it?
    Master:
  • 344 Answers
Hi there.. Is this what you are looking for?
http://www.essentialespresso.com/Solis/soils_pressurized.cfm
Posted on Mar 20, 2011
Coffee squirts/sprays out of the machine rather than gently flowing or dripping into the cup. The machine is brand new.
Fit the small black Crema enhancer between the filter basket and portafilter, or buy a non pressurised filter basket - lots of holes...
Jan 17, 2011 | Gaggia Baby Espresso Machine
The coffee will go all over the counter. We did not get a manual with the coffee maker. Could I possibly be setting the pot incorrectly on the plate?
Check the following:
1. Make sure that you are using the correct size coffee filter in the basket. Only one filter is needed to allow proper drainage.
2. Check the spring loaded button on the bottom of the coffee basket. Remove the basket, put some water in the basket, push the button up to make sure the water is released from the basket.
3. Put the basket back in place, insert the carafe and check to make sure that the top of the carafe cover pushes up the button on the basket to release brewing coffee.
If all these check out, then there is an internal leak and the unit need to be repaired or replaced.
Aug 11, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
I need to purchase new filters for GE coffee-maker model number 169164
I'm not sure whether you mean the charcoal filters or the basket filter for the coffee. I have the exact same basket that I bought years ago as a replacement for a different pot, so I doubt that would be a problem. You can try your local Walmart for the charcoal filters since this model was sold exclusive contract with that chain. Depending on the size of your Walmart, you might have to special order those. Otherwise, they are available at most super centers. Just as an added measure, you might want to try washing the filters and using a coarser coffee grind before you buy new ones.
Dec 19, 2009 | GE 106591 Coffee Maker
Cuisinart Brew Central 12-cup Coffee Maker Filter Basket Anti-dripo has come unattached. We have a spring and the anti-drip puiece. How do they go together?
Hello tfsmithcambr,
You need 3 pieces. The bottom plug, the spring, and the collar. Slip the spring over the plug. Insert the plug into the basket end. Slip the collar onto the inside the basket end of the plug shaft until it clicks. Should be good to go. If this does not work or you are missing a piece, you may need a new basket. Hope this is helpful. Good luck and kind regards, NormanZ
Jul 07, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
COFFEE GROUNDS COME THROUGH THE HOLES IN COFFEE BASKET. WHAT TYPE COFFE SHOULD I USE TO ELIMINATE THIS? IS THEIR A FILTER MADE FOR TJHIS URN
Your coffee is too finely ground for your basket. 2 solutions: buy "regular" ground coffee from now on, OR use filters inside the basket. Many 30 cup or 45 cup maker's baskets are sized so that a normal filter, flattened-out, and a small hole torn in the middle will fit into basket and prevent the grounds from passing through.
Oct 05, 2008 | Hamilton Beach GE 42-Cup Coffee Urn Coffee...
Water/grinds spillover in coffee basket
Pot must be inserted with the handle pointing straight out the front so it will hit the valve that is below the basket designed for the "rob a cup" while brewing feature.
Calvin
Aug 13, 2008 | Coleman 5008C700 Camping Coffee Maker Free
Have the Cuisinart DCC-1200 coffee maker. When you begin to brew coffee it brews some of it but leaves the whole filter top full with coffee and coffee grounds. Called then customer service line and...
It sounds like you were using the gold permanent coffee filter in addition to a paper filter. You should use one or the other.
The gold permanent filter must be cleaned between each brewing cycle.
Try this:
1. Remove the filter basket from the coffee machine.
2. Remove the gold permanent coffee filter from the basket.
3. Clean the basket thoroughly. Ensure there are no grounds clogging any holes.
4. Insert a new paper filter only into the basket. Do not use the gold permanent filter for this test.
5. Fill the water reservoir with the desired amount of water.
6. Add the desired amout of coffee grounds into the paper coffee filter.
7. Replace the filter basket into its holder in the coffee machine, and close the water reservoir lid. Press firmly on top where it says, "Press to Close".
8. Ensure the glass carafe is placed correctly in its position on the heating plate.
9. Turn the Function Knob to "BREW", then flip the Power Swich to "ON"
Hope that helps.
Jul 07, 2008 | Cuisinart DCC-1200 Coffee Maker
Handle is pushed out
Are you using the pressurized filter baskets? My 2 1/2-year-old SL70 recently started doing the same thing, and I think I have narrowed the problem down to the filter basket (it works fine with a non-pressurized basket). I've ordered a new pressurized basket. I can't guarantee that this is the answer, but you might try it.
Feb 12, 2008 | Solis Crema SL-70 Espresso Machine
Solis Crema SL-70 Espresso Machine Logo
54 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
