Question about GE Refrigerators
Freezer does not seem to be cold and frost on the back wall
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 20, 2011
Frost build up in freezer
You need a new bimetal fuse for your defrost cycle in your freezer.
Feb 28, 2014 | Hotpoint HSS25GFP Side by Side...
My refrigerator is not getting cold
Is the freezer freezing? Do you hear a fan motor running inside the freezer? If the freezer fan is working and the freezer is still getting cold, do you see allot of frost on the back wall of the freezer?
Freezer not cooling at all - t-stat or compressor would be where to check next
No fan running in freezer and freezer is cold - bad evaporator fan motor.
If fan is running and you have heavy frost on the back wall of freezer - unit is not defrosting. could be defrost timer or defrost t-stat
Mar 12, 2013 | Amana Refrigerators
Although the compressor seems to be working the freezer and refrigerator are not maintaining cold temperatures
Check to see if there is excess frost on the back wall of the freezer look behind the wall if you can . you might have a defrost problem. if you do look behind the freezer wall but don't see frost on the evaporator ( even but not restricting) you might have a sealed system problem.
Apr 14, 2011 | Refrigerators
My Whirlpool Freezer/Refrigerator model# ET19RMXGW02 is not keeping items cold. The ice maker is not working. There is frost in on the back wall of the freezer but objects like ice cream are all soft. ...
your evaporator coil behind this frost on the wall is iced up and you cant blow cold air through solid ice,remove this panel and defrost the coil,then check the defrost heating element below the coil,the defrost thermostat located on the coil or the defrost timer itself for being defective
Aug 05, 2010 | Whirlpool Refrigerators
The freezer is well and very cold, but the refrigerator is cool ,but not cold enough to keep the food well.
Check and see if there is frost on the back wall of the freezer. Also make sure the fan is running in the freezer. If the fan isn't running in the freezer replace it. If you have any frost or ice on the back wall of the freezer, remove the back wall inside the freezer. Check and see if the coils are completely frosted over. Thaw the coils out with a hair dryer, then measure the heater and make sure it measure there. (ohms)
If it's ok, then the defrost thermostat which is attached to the coils or the defrost timer is bad.
Sep 15, 2009 | Refrigerators
Warm fridge
check the fan in the frezer and check the defrost
Nov 29, 2008 | Amana Refrigerators
My freezer dosen't work but the fridge seems to be O.K.or at least cold enough (Model BX2255W Manufacturing# P1196708WW) Ive vacumed underneath and adjusted both the freezer and refer controls. The fans...
Normally it is the temperature of the refrigerator that shows the first sign of a problem because the refrigerator is cooled by air from the freezer. Check the back wall of the freezer for signs of frost. If there is frost on the back wall you have a defrost system problem.
Jun 29, 2008 | Amana Refrigerators
Freezer not cold enough
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Jun 29, 2008 | Amana ARB2205C Bottom Freezer Refrigerator
The refrigerator is not getting cold to it's recommended settings.
Check for a frozen coil in the freezer. Air from the freezer supplies the cold air to the refrigerator section for cooling. If frost is on the back wall of the freezer section you have a defrost system problem.
Frost on the back wall of the freezer indicates timer or heater circuit failure.
Jun 10, 2008 | Whirlpool Refrigerators
Frig not cold but freezer is ice maker not making much ice either
Is your fan blowing in the freezer? Frost on the back wall of the freezer usually indicates a defrost problem... defrost themostate, heaters, take back panel off and check evap for frost build up and if your fan in working.
Aug 28, 2007 | Amana AFD2535DES French Door Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
