Question about Garden
Where is the serial number on the echo pb- 770t blower?I see no tag on the machine and the box is missing part of the bar code
  • Roy Cagle
    Roy Cagle Mar 20, 2011
    Do you need this to register the machine for warranty service or ??? Their website may be able to assist you in this matter.
  • 708 Answers
SOURCE: would like owners guide and parts manual
Go to following site
www.echo-usa.com/documentation.asp?Model=pb210e&lang=E
Posted on Mar 24, 2009
  • 708 Answers
SOURCE: echo pb 200 leaf blower want start
Turn on ignition switch, Choke, prime bulb 5 times (or until fuel flows), hold throttle down and pull starter cord sharply until it tries to start, then place choke in mid position pull cord sharply again until it runs then move choke to off when it will allow it.
Also you can go to toro.com then customer care, then manuals and parts then type in model no. and download an owners manual.
Posted on Apr 06, 2009
  • 708 Answers
SOURCE: Echo backpack blower stops after 20 minutes
Make sure the fuel tank cap inlet valve is working properly, this will allow a vapor lock if it is not. Then check the fuel line in tank to make sure the pickup filter is not hung up in tank thereby allowing the fuel to get below the pickup. Also check the fuel line for holes. You can also try toro.com customer care, manuals and parts, type in model no. then get owners manual and see if in troubleshooting section it list this problem.
97F350diesel
  • 1326 Answers
SOURCE: I have a Echo PB 2601 made a loud bang then stoped working.
Sounds like it has seized up. If the pull cord won't pull then the motor is locked up. Did you run gas/oil mix for the fuel its a 2 cycle motor...
Posted on Sep 25, 2009
  • 430 Answers
SOURCE: ho spark on a pb 403t backpack blower
Be sure you have no spark ( 90% of the units that come into my shop for repair with the complaint of no spark- have a fuel issue). Be sure the spark plug is good.
If no spark then remove the ground wire from the module and check for spark again. You must use the recoil starter- spinning by hand is not sufficient. If still no spark then replace module. If there is spark with the ground wire disconnected then there is a problem with the kill switch or a bad wire.
Posted on Nov 30, 2009
Looking for a serial number for a back pack echo pb-413h blower
if unlucky lost its serial number sticker from petrol spill/heat
if lucky something stamped into the alloy housing of assembly
most mower repair shops can track down sample parts without the serial number
a factory limit of hours on blowers are as little as 100 hours
unless it came with the user book from new purchase
you may never know
Jan 13, 2017 | Echo Garden
About Echo blower Flywheels
Potentially. Give it a try and see if it runs
Mar 29, 2016 | Echo Pb-251 Leaf Blowers
- how do I stop the piston from hitting the spark plug on my echo pb-251 blower?
You either have the wrong plug in it or the aluminium sealing washer is missing.
Feb 26, 2016 | Echo Pb-251 Leaf Blowers
Echo pb-1000 blower
depends on the serial number as they have multiple breaks throughout production of that model... but you have a inlet line a return line and a vent line
Aug 21, 2014 | Garden
Where do you find the serial number of a echo PB403T
Model and serial number are underneath the recoil starter, on the engine block. Tip the blow on it's non-engine side and look right above the tank from underneath the blower.
Nov 04, 2013 | Echo Pb-403T Leaf Blowers
Echo 770t misfiring
I have installed new carb kit, fuel lines, plug, and air filter. Blower continues to bogg down when opening up throttle. echo 770 blower any ideas?
Aug 13, 2013 | Echo Backpack Blower PB-770T
Echo leaf blower has gas coming out of the exhaust
My ECHO dealer told me that my PB-251 was not worth repairing because it was 2 years old an to buy a new one... It will not be another Echo. So much for the 5 year war. I'm not very happy........
Aug 26, 2012 | ECHO, Inc. PB-251C Handheld Blower
Can't find serial # on Echo PB-500T Blower
The number is on the side of the recoil starter, its on a white or silver tag mounted on the underside.
Hope this helps, Matt
Dec 10, 2010 | Echo Garden
Garden Logo
712 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
