Question about Whirlpool Washing Machines
Why does my washer make soo much noise when washing sheets??and the sheets wind up in a big ball
    Sergeant:
  • 170 Answers
If the mod # begins with 110 its whirlpool built. Check to see if the top part of adjatator is moving grab the top of it turn back and forth it should turn the lower section in one direction but not the other.If it is not doing that and just spinning freely then your dogs are defective. cheap part and easy to replace do the test and get back for more info......Thanks for voting
Posted on Mar 20, 2011
Why is my kenmore washer shredding sheets?
Check the drum for any Sharpe edges or splits also check the activator for the same . Something in side may have a rough edge to cause this .
Apr 25, 2017 | GE Energy Star WCVH6260F Front Load Washer
Ul code sheets are balled up machine stops working, bought 2 mos ago
Unbalanced load. Common problem when washing fitted sheets. The Appliance Assistant wrote an outstanding article about the problems associated with these machines and the solution! HERE
May 21, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
My kenmore front loading washer is screeching during spin cycle and seems to be spinning poorly at times. what is going on?
The wash drum should spin smoothly by hand without much noise. It is supported with two sets of ball bearings. If the water seal fails, water starts to leak into the inner bearing and they start to rust causing a loud noise especially during the spin cycle. The only way to fix it is to replace the bearings and seal. It a big and expensive job to replace the bearings since you literally need to take your washer apart to get to the bearings. Sorry.
Oct 07, 2010 | Kenmore 44102 Front Load Washer
I get a loud noise during the spin cycle - sounds like the ball bearings are wearing off. Is there a way to fix this? How?
Yip could well be drum bearing failure, itss quite a big job / expensive......Depending on age may not be worthwhile!!
Jun 24, 2010 | Kenmore 43052 Front Load Washer
Whirpool Cabio washer knots clothes/sheets into tight balls
whirlpool had a service bulletin on this. New agitator design. replace with new design.
Mar 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
During high speed cycle a loud bagging noise. looks like the drum is out of balance. Kenmore washer model 42832
Most likely you have a big sheet or something in the wash, this has unbalanced the load. Turn off the machine, wait for 1& half minutes to open the door, re-adjust the load, likely other clothes are stuck in the big sheet. Continue the wash...........
Feb 22, 2009 | Washing Machines
Clothes and sheets come out wrinkled and twisted
Try not to wash large items with small items the large items like sheet will twist around the small item. causeing twisting and wrinkling. Also If you are overloading the clothes or underloading the clothes they will come out wrinkled. I would try to do some testing wash a load of only towels then wash a load of only t-shirts and other light weight items that you may have. Then do just a load of your jeans. What happens? Please let me know
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Sheets wind together in a damp ball
I have a different model Bosch dryer, but I have the same problem.
I've found that the flat sheets dry okay if you have them in with other things (like pillowcases and t-shirts). I learned long ago though that you can't put those things in with deep fitted sheets; the little stuff winds up caught in the corners in damp wrinkly wads.
So I dry the fitted sheet separately, and throw in a couple of clean tennis balls. They're noisy, but harmless, and they keep the sheet from balling up.
Oct 26, 2008 | Bosch Axxis WTA 3510 Electric Dryer
Rolling into balls
There is nothing you can do about this. the disadvantage of sheets and blankets.
May 07, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
