Question about Boating
What frequency transducer does the humminbird super sixty use ?
    President:
  • 2,080 Answers
That unit uses a 16 degree - 200 KHz transducer.
Found the info in a forum at the following site:
http://www.icefishingmichigan.com/forum/showthread.php?t=233551
Hope that helps.
Posted on Mar 20, 2011
  • Joe2
    Joe2 Mar 20, 2011
    Thank you for the excellent rating, I truly appreciate it.
Says no transducer connected and is in simulator mode. How do I get out of simulator mode?
the manual is here
http://www.humminbird.com/Category/Support/Product-Manuals/
I had this unit but gave it away recently. From memory, you just need to connect the transducer and make sure the transducer is in water. If not, it reverts to Demo Mode.
Aug 20, 2015 | Humminbird Piranhamax 170
Where I can bay transducer
when I lost my first one hummingbird replaced it to the tune of 50.00 us check the link I send you perhaps one of them can help Humminbird XTM 9 DI 25 Transducers Google Search
Mar 20, 2015 | Humminbird XTM-9-DI-25-T Transducers
Why does my screen loose depth return as soon as I am in 150 mts of water?.How come in shallower water I get a very good image but past 150 mts the screen is just scrambled and there's no bottom retur
Be sure you have your unit set in "max mode" and run it on 200khz frequency see if this makes any difference. Also be sure your unit is wired directly to your battery not through a switch or fuse panel as this can rob your unit of voltage, impacting the strength of your sonar signal.
Oct 05, 2014 | Humminbird Boating
I just bought a used boat with a Humminbird 160 fish finder on it but, the only thing that shows up on the screen is the temperature, NO DEPTH and NO FISH, is there a setting i need to set as i am clueless...
Check to make sure the transducer is hooked up correctly, and check the actual transducer for signs of damage. Transducers are fragile, and a good whack can break the crystal inside. For more troubleshooting, here is a helpful link with the Owners Manual for your Humminbird.
http://store.humminbird.com/media/document/PiranhaMAX_150-160-170-180-190c.pdf
Aug 29, 2011 | Boating
Correct installation/placement of humminbird 898c si transducer
You can take a picture of the transom of the boat and email it to our customer service group and they will give you an idea of where the transducer needs to be mounted. There email address is service@humminbird.com.
Feb 12, 2011 | Sport & Outdoor - Others
Hi I live in NZ and have a Humminbird 383c GPS Chartplottter which was purchased in the US. approx 2 years ago.It has a transom mounted transducer which I mounted in a piece of plastic pipe, epoxied in the...
Don,
We would recommend that you replace the transducer (if you want to keep the transducer inside the hull you may use the
XP 9 20 T with temperature and you can use epoxy to mount the transducer) If you want to keep in the compartment you have created you may want to just put water in the compartment with the transducer so its not shooting through the air.
If you have any other questions please email customer service at service@humminbird.com
Thank you,
Deborah
Humminbird Customer Service
Jan 12, 2011 | Humminbird XNT Transducers XNT 9 20 T ...
Unit wouldn't recognise the transducer. CS told me to turn off the demo mode. Did that and stuck the tranducer in water and no reading. Is transducer defective or maybe the head?
It is hard to say. If you know someone that has a unit simular to yours just slide it on to there mounting system and then you will be able to tell if it is the unit or the transducer.
Joby @ Humminbird
Jan 02, 2011 | Humminbird 385ci Combo W Internal Antenna
Hi. Just wondering how should the transducer for my humminbird 525 fish finder/sounder be installed correctly? Thanks
You can take a picture of the transom of your boat and email it to Humminbird and they will email it back to you where the transducer should be mounted at. Our email address is service@humminbird.com.
Joby @ Humminbird
Dec 27, 2010 | Sport & Outdoor - Others
Boating Logo
639 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
