Question about Dishwashers
GE Profile Smart Dispense is clogged. How can I unclog it.
  • 4,323 Answers
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Posted on Mar 20, 2011
Fabric dispenser is clogged. How do I unclog so
The dispenser is removable easily. You can scrub down the softener dispenser and it will eventually work.
Jun 12, 2010 | GE WSXH208A Front Load Washer
Ge profile won't drain water
don't panic it could be a clogged drain line. Unclog and enjoy life again.
Oct 05, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Purging ge profile smart dispense dishwasher
How to Purge Incorrect Liquid Detergent from the Bulk Dispenser
The purge routine operates the bulk dispenser pump continuously to drain the bulk dispenser tank when an incorrect liquid was poured in the tank. The process consists of setting up the dishwasher to run the purge mode, running the purge mode and then cleaning up the purged detergent.
Follow these steps carefully to have a successful purge run.
For Top Control Models:
  1. Make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  2. Press Heated Dry and Down Arrow buttons together for 3 seconds. All LEDs will illuminate.
  3. Press Added Heat and Up Arrow buttons together for 3 seconds. The Anti-bacteria LED will illuminate
  4. Press Start button one time
  5. Select Normal and make sure Pre-wash, Added Heat and Heated Dry LEDs are off.
  6. Press Start button one more time and dishwasher will run a complete cycle without the main motor running. Cycle is complete when the Clean light illuminates. This should take approximately 60 minutes.
  7. Open door and wipe up excess detergent from the door and tub
  8. Flush remaining detergent off by pouring water on the door and tub where there is detergent residue.
  9. Remove SmartDispenser cap and fill tank with water and then replace cap.
  10. Repeat Steps 1 through 9 one time.
  11. Then, repeat Steps 1 through 6. When the Clean LED illuminates, the system is purged and ready to be refilled with the correct detergent.
Front Mount Controls (same as above except for the changes in the two below steps):
2. Press Heated Dry and Cookware together for 3 seconds. All LEDs illuminate.
3. Press Added Heat and Cookware together for 3 seconds. The Anti-bacterial LED illuminates.
Jul 05, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
The water will not come out of the door. The ice will work though.
My GE Profile has a system water filter. The manual said that if the filter clogs--it will not allow water to pass thru--any ice already made will still dispense but no new ice will be made. If you have a filter and it is over 9-10 months old, it could be clogged.
Jul 04, 2009 | GE Profile PSS26NGS Side by Side...
GE Profile dishwasher with ''SmartDispense'' technology is clogged
Check the reservoir hose , and unclog it if necessary. You may need to disassemble the reservoir/dispenser to solve the problem.
Use to the diagrams below:
Apr 06, 2009 | Dishwashers
Smart Dispense on GE Dishwasher
Press the ADDED HEAT pad 5 times within 3 seconds. You will hear 3 beeps; then the light will go off. You can turn the feature back on again by repeating.
Nov 19, 2008 | Dishwashers
Smart dispense detergent dispenser
There are two different types of dishwasher detergent types, bleach based and enzyme based.  The owner's manual states that if the two are ever mixed that the mixture will congeal, clogging the dispenser.
I don't know exactly how to safely remove the detergent that is in there, perhaps a wet/dry vaccuum.  There is likely a service mode for the dishwasher if it has electronic buttons, in the service mode you could activate the pump that dispenses the detergent.  Use caution, the thicker the clog, the harder the pump has to work and it may fail.  Hope this helps.
Nov 08, 2008 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher noise
see the fix at the following link:http://www.fixya.com/support/t204050-ge_adorda_dishwasher Simply zip tie the water tube for the middle spray to the upper basket.......it works!
Sep 02, 2008 | GE Profile PDW8400J Built-in Dishwasher
How do I make sure the dispenser is completly empty?
Just use the manual dispense. The smart dispenser is horrible. You will never get it empty AND you will have congealed soap in the dispenser for ever.
Jul 21, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwashers Logo
215 people viewed this question
Top Dishwashers Experts
