Question about Philips Televison & Video
Trying to hool up Philco model DVD3315V to a JVC TV. TV works. DVD has power, lights on. No video. What did I do wrong? Original set up
SOURCE: JVC DR-M10 DVD Recorder not working
Contact JVC @ 800-252-5722, the "loading" is a known bug and they will fix this defect at n/c even if it's out of warranty period.
Posted on Mar 31, 2008
SOURCE: video channel
you can connect this using a set or RWY AV leads connecting your VCR/DVD to one of the TV's AV inputs. This wont require any tuning and most TVs developed in the last 10 years have AV inputs. Then you would just need to put the TV onto the AV channel you have chosen and play the video. Presto you should have a picture.
Posted on Aug 25, 2008
  • 325 Answers
SOURCE: How do I connect a JVC DVD video player model
There are several ways in which you can do this.
The first way. If your cable box has two scarts one will be label as tv and the other vcr or something similar. connect your Dvd player via scart to the vcr scart on the back of your cable box. then connect a scart from the cable box to the back of the TV.
That would be you all sorted. when you turn your DVD player on this should override your cable and display the dvd screen.
Second way. If your cable box has not got two scart ports on the back of it. Then you would have to connect both to the back of your TV. If there are not two scart ports at the back of your TV then you can purchase a scart lead splitter. I would imagine the Cheapest you could find would be on Ebay or something similar.
Hope this Helped Clarify things for you.
If this has then please leave a thumbs up
Cheers Little Dish Fitter.
Posted on Oct 14, 2009
josetejas
  • 300 Answers
SOURCE: How do you hook up a jvc tv to a jvc dvd/vhs
There may be more than one video output. Use the one that says VCR/DVD
Posted on Jan 22, 2010
walesarumi
  • 6993 Answers
SOURCE: attaching D200B to TV using
I think your connection is wrong that's why the content of your DVD is not display on your TV. Cross check your connection by reading further....
The RCA cord has three wires. I'm sure you are aware of this.... The wires are yellow, white and red.
The yellow cord is responsible for display, while the red and white is responsible for sound.
Look at the back of the TV, connect the yellow to "video in", then the white and red to 'audio in'.
Connect the other end of the RCA cable to 'video out' and 'audio out' respectively at the back of your DVD player.
Now, press source/AV on the TV and there should be a display of the DVD on your TV.
Now you are through.
Let me know if this doesn't work for you so that I can look further into the issue.
Regards.
Posted on May 21, 2011
Hello, I have a JVC TV Model #EM302T We are trying to play a DVD on it. We get sound but no picture. What are we doing wrong?
For a dvd player you will need to use 3 cords. The 2 cords you talk about are probably the left and right audio cords which are red and white. You will need the yellow cord for video.
Feb 12, 2015 | JVC AV-32D305 32" TV
I have a JVC HD 52g787, the sound works but no picture, The tv comes on, but the blue light just blinks, then cuts off, I have sound no picture
The problem is usually from the power or the Y sustain at the left or right side of the display when one of the large capacitor or heat sync on the capacitor even the flat power cable connection it to a main power board needs to be checked too, if the fuses on the board are blown it will need to be replaced
But after replacingthe fuses and the capacitors and still no solution,youwill need to replace the all board ..
You can also trouble shoot first before going to the board of the TV..
How to Troubleshoot an LCD With Sound But No Picture
It can be overwhelmingly frustrating when an electronic device as expensive as an LCD television set starts having problems. Luckily many of these problems are easily troubleshot. While being able to hear sound coming from your LCD television but seeing no picture may seem serious on the surface, fixing the problem involves checking a few different settings to make sure everything is set properly
Instructions
Check the video connection of any devices plugged into the LCD television. If you can hear sound but are seeing no picture while trying to use something like a DVD player or cable box, the problem is probably that a wire is loose somewhere. Check the yellow video cables running from the DVD player to the TV and make sure everything is plugged in firmly and where it should be. Also check the coaxial cable running from the cable box (or cable outlet) to the television and make sure that wire is also screwed in securely.
Check the image settings on your television and make sure everything is set properly. Certain settings like "Picture" or "Brightness," if set to one extreme, can make the picture appear completely black. This could cause you to simply hear television shows but not be able to see them. Reset all picture settings on the TV to their original factory default settings to see if that fixes the problem.
Try another channel. If you're watching TV and not getting a picture, the first thing you should do is check a variety of random channels to make sure it is a problem with your TV and not with your television signal. If it is a problem with the television signal it is the fault of the TV station or cable service provider and there isn't anything you can do yourself to fix it.
Try the DVD on another DVD player. If you're trying to play a DVD and can't see any images, make sure the disc isn't defective. Try it on another DVD player or a computer DVD drive and make sure the disc works in the first place.
Hope it helped ..
Jul 17, 2011 | JVC HD-52G886 52" Rear Projection HDTV
I have a samsung tv i am trying to trying to program for this jvc remote. Could you give me some instructions?
Hi wnowens, to program your tv to that remote follow these 3 easy steps.
Samsung code = 12
1 Holding down TV/VIDEO, enter the code "1 2" by using the numeric buttons (0 - 9).Do not release TV/VIDEO. Keep holding it until the next step is completed.
2 Press STOP button while holding down TV/VIDEO.
3 Now try to operate your TV by pressing DVD POWER - TV POWER while holding SHIFT.
If your TV turns on or off, you have successfully set the control signal.
If you want a PDF copy of the user manual click HERE to download it.
Hope this helps enjoy : )
Feb 11, 2011 | JVC Rm-sxv521j Remote Control
Old JVC television model AV27220, serial number 10616951, chassis number A67, manufactured May 2001 - I lost connection with my CD/DVD player (Sony model DVP-NC615, serial number 1165211) for no...
The outputs from the dvd that you are describing are that of line level and not rf...so you don't need to tune the tv to anything..you just need to put the tv on the video source setting(video1,2,3 etc..)..if you have the remote..there should be an input buttton or a source button
Jan 07, 2011 | JVC Televison & Video
Flashed my XV-NP1 with wrong firmware. now player wants original firmware CD. I need original firmware ISO!!!
  • Check the DVD player to ensure that you do not have a DVD disc inserted into the device. Press the "Eject" button and lift out any DVD present in the device.
  • Turn off your JVC DVD player.
  • Unplug the device from the power source.
  • Examine the front or rear of your DVD player and note the model number.
  • Reset your particular device using the "DVD Reset Procedures" documentation provided by JVC (see Resources). Cross-reference your particular device's model number with the instructions provided within the reset procedure documentation
  • Read more: How to Reset a JVC DVD Player ' eHow.com http://www.ehow.com/how_6940950_reset-jvc-dvd-player.html#ixzz16g5rec91
    Nov 29, 2010 | JVC XV-NP1SL DVD Player
    My JVC model AV27330 has a constant blue screen. I can go thru Video 1, video 2, video 3 and then says chn 04 but should be 03 - when I push channel button down channel 105 shows or the other way channel...
    You need to use the original remote and call up the customer menu; select auto program or channel program and see if reprogramming will help.
    If no JVC remote you have only one other choice----connect a DVD or VCR to one of the video inputs and see if the set functions that way.
    SD TECH
    Aug 09, 2010 | JVC AV-27530 27" TV
    Picture works on tv but not dvd only sond works
    Should be one of 2 problems:
    • Connections in wrong spot - double-check to make sure all cables are in correct inputs and outputs
    • DVD may be set to display video through a digital conneciton instead of analog (or vice-versa)
    If it's not the connections, then try unplugging the DVD player, hitting the power button couple of times, plugging it back in, this may force it back to default settings (if you're not using DVI or HDMI connection).
    Apr 07, 2009 | JVC AV27MF47 27 inch TV
    Remote Codes for Commtel Control Freak and JVC
    0053, 1253, 1923 if those don't work, I have others.
    Jan 18, 2009 | JVC RM-C18G-1H Remote Control
    JVC XV3E
    trying to record on it. if your tv had an output video try to connect it there do not connect the cable to the input of the tv.
    should be tv output to the dvd recorder input.
    Feb 23, 2008 | JVC HR-XVS30 DVD Player/VCR
    Televison & Video Logo
    26 people viewed this question
    Top Philips Televison & Video Experts
    matt martin
    matt martin
    Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
