Question about Dell Inspiron 1525 Laptop
I HAVE A 1525 DELL, JUST BOUGHT A NEW BATTERY AND A NEW POWER CORD FOR IT. IVE BEEN CHARGING IT FOR ABOUT 2 HOURS AND IT DOES NOT TURN ON, NO LIGHTS NOISE OR ANYTHING, JUST DEAD, PLEASE TELL ME WHAT TO DO..... BOBBY
    Master:
  • 325 Answers
Theres two possibilities 1. your socket is broken details here bottom right
www.2pages.co.uk/laptops.html
otherwise
worse.. 2. your motherboard is dead.
either way I recommend you take it to a repair service if your laptop is worth more than £200 ($300)
otherwise its what we call BER (beyond economical repair) which means it would cost more to repair than the laptop is worth.
Posted on Mar 20, 2011
MY DELL LAPTOP SAY 0 % NOT CHARGING
Take it back to where you bought it from for testing.
Try putting charger in a different power point.
Dec 12, 2012 | Dell Inspiron 1525 Laptop
Inspiron 1525: "plugged in, not charging"
Not charging means the battery is not being charged. Batteries only have a useful life of so long, then they die and will not take a charge so you have to replace them.
If the laptop works fine when the power cord is plugged in, then just replace the battery. if the laptop does not work on the power cord, then you need to either replace the power cord or look to see if the DC Jack where the power cord plugs into the laptop is broken or wiggles. When the DC Jack it bad the battery will not charge and eventually the laptop will not turn on if the power cord can't make the connection correctly.
Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
May 22, 2012 | Dell Inspiron 1525 Notebook
Bought a new battery for Dell Inspiron 1545 and it's not charging.
You may want to try a new power cord to verify the power jack on the laptop is okay. If you have a battery plus store; or something in your area. They may test it for free.
Sep 21, 2010 | Dell Inspiron 1525 Notebook
I have a Dell Inspirion 1525. I have a fairly new after market replacement battery which I have only had now for 4 months. I am using Vista. As soon as I unplug, computer shuts down. I go to power settings...
The adapter is working correctly. The battery is either slow to charge or in need of replacement.
It's possible your battery isn't charging at all so to test this boot into bios -> battery status and watch it run overnight.
Sep 09, 2010 | Dell Inspiron 1525 Notebook
I have a dell inspiron 1525 the battery light was blinking orange and wouldnt come on so listening to an expert i bought a new battery when you first plug it in should the light still be orange??
Hi. Blinking orange light on battery indicator means it's charging. To make sure, point your mouse to the battery icon on the Taskbar located on the lower right-hand corner of your screen...near the system time and speaker icons. It should say plugged in, charging. If you see "plugged in, not charging, then you need to call Dell Phone Support for additional help.
^_^
^_^
May 10, 2010 | Computers & Internet
Dell Inspiron 1525 battery problems.
try removing the battery and turn on your laptop, then while laptop is on, slide in the battery.
Apr 18, 2010 | Dell Inspiron 1525 Laptop
Dell Inspiron 1525 not turning on
hi. I suspect that you have either a dead battery or just need a reset. unplug the power cord and then remove the battery. wait two minutes and reinstall the battery.
this will reset everything. now try turning it on. if it won't come on plug in the power cord and charge the battery for 30 minutes before attempting to power up.
Jun 29, 2009 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 won't charge
The battery has most likely been "Over charged". Most rechargeable batteries can only be charged around 500-1000 times depending on the brand of your computer. I would recommend buying a new one.
May 30, 2009 | Dell Inspiron 1525 Laptop
My new itouch will not boot up. It just seems to be dead
Check the wall outlet where the Power Transformer is plugged in and verify that it has current by using a lamp or something like that. If ok, then...
Check the laptop battery for charge state. The indicater light should show full or good charge. If not, the battery could be dead....
If no current from the adapter, the battery goes dead in 2-3 hours of use.
Daniel Bonnici
Mar 27, 2009 | Dell Inspiron 1525 Notebook
Power problems Inspirion 8600-battery not charging
Most Dell batteries have an LED indicator that allows users to see how much run time and how much overall battery life are available at the touch of a button.
To check battery charge, press the button and the number of lights that appear will tell you charge status. If all lights appear, you have a fully charged battery. Each light that appears accounts for approximately 20% charge.
To check the battery health, press and hold the status button on the battery charge gauge for at least 3 seconds. If no lights appear, the battery is in good condition and approximately more than 80 percent of its original charge capacity remains. Each light represents incremental degradation. If five lights appear, approximately less than 60 percent of the charge capacity remains, and you should consider replacing the battery
if the ac adapter will power the laptop without the battery installed its fine. if the cord is fine and your battery is fine its a mother board issue and it will most likely have to be replaced
Feb 05, 2009 | Dell Computers & Internet
Dell Inspiron 1525 Laptop Logo
61 people viewed this question
Alun Cox
