Question about Garden
We bought a solar light a Westinghouse item # 37136608W It had a least 7 hrs of direct sunlight for over 7 hrs.but still does not work, We think we had it on. is it possible that the off switch shuts off the solar panel?
For first time use solar light needs to charge in full sunlight for 8-12 hours with the switch in the "ON" position to allow the rechargeable battery to reach maximum capacity.
There is also a protective film on the solar panel that needs to be removed.
After doing that, fully charging the battery with the switch in the "ON" position, then if the light does not turn on, remove the 4 screws from the solar cell assembly, remove the battery, wipe both ends and reinstall battery. Make sure the battery is making secure contact with the terminals. I had a new one and the battery was loose inside, making the light go on and off. I reseated the battery and all is well.
However you should not have to replace the battery or the unit, it should still be under warranty if you just bought it. Westinghouse guarantees this unit for one year.
A description is here
http://www.westinghousesolarlights.com/products/solar/instructions/371366-08.pdf
Waranty information is here
http://www.westinghousesolarlights.com/products/solar/1yrwarranty.pdf
I would counsel you to just take the unit back for exchange or refund, as the warranty has an exclusion clause and one of the exclusions is if the unit has been opened. Opening the unit might invalidate the warranty.
Posted on Jun 25, 2011
My Citizen echo drive does not hold a charge.It is 9-Months Old .
Place the watch in direct sunlight of sunrise or sunset for a few weeks and also bright light but not hot light. Wear as usual in direct sunlight as the occasion allows. Once these kind of batteries are discharged, they need quite some time to recharge. Wearing a new solar watch most of the time indoors with bright light only, is normally not enough but once the battery reaches full charge, the extra bright light conditions can be relaxed.
Sep 25, 2017 | Citizen Watches
Why isn't battery recharging in sunlight?
Failure to recharge completely could be a sign of a failing battery.
Dec 03, 2015 | Casio Mens PAG240-1CR Pathfinder Triple...
Gu10 led light bulb are energy saving led Bulbs
Yes Gu10 led bulbs are energy saving led bulbs please check out the link below to know more about how much Gu10 led bulbs save energy
SHEERLED LED Bulbs SPOTLIGHT IN UK GU10 LED Lights IN UK
Sep 08, 2015 | brianydeal 3w Gu10 16 Color Rgb Led Light...
Do solar panels need direct sunlight to work?
No. It will work in with diffused light too. Some sensitive ones will generate voltage even at moon-light.
Electro help
Nov 09, 2014 | Moultrie Feeders 12V Solar Panel
Panel will not put out more than 1.7 volts in direct sunlight
Jeff,
It sounds like the panel's tabs were wired incorrectly or incompletely. I recommend you get a new solar panel since it seems like only one cell is outputting voltage for you now (2v cell). If possible, have the manufacturer warranty it for you since it should be putting out in excess of 14 volts in direct sunlight on a cold day.
Let me know if you have any other questions.
Thanks!
Sep 04, 2013 | Wildgame Innovations Wild Game Innovations...
Does the solar cover need to have buttons up or down?
Solar pool covers should always be installed with the bubble side down, touching the water.
Jul 16, 2011 | Midwest 8 Mil 25' X 45' Rectangular Blue...
Westinghouse Solar sensor issue
Put a small piece of black tape over half the sensor. This will make it more sensitive to light conditions.
Jul 04, 2009 | Garden
I just bought a pack of Westinghouse solar lawn lights and the lights are excessively dim at night. I know they are supposed to be brighter. They are in very dark places at night that get great sunlight...
Not a solution but -
if you put your batteries in a battery charger (normal battery charger) and charge them, they will work sooooo much better.
Just keep doing this every time they seam to be dull (after many clowdy days)
Jun 09, 2009 | Garden
Dead
All you have to do is place the watch in direct sunlight for about 12-24 hours and it will be working perfectly again in no time at all. Make sure the light is shining directly onto the watch's face as that is what needs to absorb the solar power. You can just place it in a window sill that gets a lot of sunlight and let it charge all day.
If you appreciate me solving this for you then please rank this solution as "fixya" or at least "helpful", thanks!
Jan 08, 2009 | Silhouette Citizen Eco-Drive Watch
Garden Logo
1,457 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
