Question about Belkin F5D7230-4 Wireless Router
How do I set a password for entry into my router when I type 192.168.2.1
    Master:
  • 451 Answers
Go to the link below
to set the password for your router
http://en-us-support.belkin.com/app/answers/detail/a_id/30/kw/password/session/L3RpbWUvMTMwMDU5NDA2OS9zaWQvKjJpQy1tcGs%3D
Posted on Mar 20, 2011
4 Suggested Answers
Tom Marvolo
  • 708 Answers
SOURCE: cant get into the settings of my belkin router http 192 168 2 1
Step 1 : Check the IP Address of the Computer
Step 2 : If it is in the Range of the Router ( 192.168.2.x)
Step 3 : Try typing 192.168.2.1 on the address bar of internet explorer
Step 4 : If not working Hard reset the router by inserting a paper clip into the reset hole on the back of the router
Step 5 : If the IP Address is any public address or 169.254.x.x then also do step 4
Posted on Jan 10, 2010
eastpole
  • 22 Answers
SOURCE: set up router/modem as instructed
Problem can't be solved as described, a fixer would need more details.
What kind of modem/router is it?
What instructions are you working from so far (you say, "as instructed" so I take it you're looking at a Quick Start Guide of some sort?)
How are you connected to it?
What http address are you going to (E.g. some routers use 192.168.1.1, others 192.168.1.254 or various alternatives)
What happens when you enter that address on a browser?
Have you set your computer's address to a nearby address so it can talk to the route?
If I had one guess with not enough information, I'd say you need to set your PC to an address one different from the target you're going to.
( http://compnetworking.about.com/od/workingwithipaddresses/g/192-168-1-254-d.htm )
Posted on Jan 10, 2011
bhushan_soft
  • 14 Answers
SOURCE: 192 168 1.1 requires a
enter router company name and model number for default username an password in google u will get it.
But if default password is changed then
u can reset it also manually or by command.
Posted on Feb 18, 2011
I dont remember my adm password
You can reset the router to factory default settings.
  1. Before resetting the router make sure you have a computer connected to it via a network cable.
  2. A link for the linksys manual for the WRT54GL is listed in the next step.
  3. http://homedownloads.cisco.com/downloads/userguide/1224638971110/WRT54GL_V11_UG_C-Web,0.pdf
  4. If you have a different router, go to this page and enter the model number of your router in the search field at the top of the page. http://homesupport.cisco.com/en-us/support/routers/WRT54GL/download
  5. The manual for your router will give you the default IP address for your router.
  6. Download the manual to your local computer, you will need it later.
  7. Get a pen and paper you need to write some things down.
  8. Write down your wireless SSID and password.
  9. Go to your computer. Go to the "Start" menu and click the run button, OR in Win 7 go to the "Search Programs and Files" field at the bottom of the menu.
  10. Type in the word "cmd", do not type the quotes, and press enter.
  11. In the cmd.exe window that pops up type the following command "ipconfig/all".
  12. Scroll up to the first entry and look for the section titled "Ethernet adapter Local Area Connection".
  13. In that section look for the entry "DHCP Server" and write down the address, it will be 4 numbers separated by periods. This is the address your router is currently using.
  14. Now type in "ipconfig/release" and press enter.
  15. Now go to your router.
  16. On the back of your router there is a hole labeled "Reset" with a small button inside.
  17. Press and hold the reset button for approximately 5 seconds. This resets the router back to factory default settings.
  18. Wait 3 minutes for the router to reset.
  19. Go back to your computer and your cmd.exe window. Type in the command "ipconfig /renew" and press enter.
  20. Now type "ipconfig /all" and check the IP address like you did before. You should now have a different IP address. If your IP address did not change then restart your computer and continue following these instructions.
  21. The manual for your router will give you the default IP address for your router.
  22. Open your browser on the computer and type in the default IP for your router. Many linksys routers use 192.168.1.1.
  23. A login window will appear. Leave the username blank, the password is "admin", omit the quotes, and press enter.
  24. In the admin tool change the default router IP address the what you wrote down a few minutes ago and save the settings.
  25. Now change the admin username and password. NOTE: Make sure you write them down this time.
  26. Configure wifi. If you use the same SSID and password as before all your wireless devices will connect without problems.
  27. Make sure you enable DHCP if you use it.
  28. Set your other settings as needed.
  29. Make sure you save your settings in the router admin tool.
  30. You should be good to go.
  31. Have fun.
Dec 02, 2011 | Linksys Wireless-G Broadband Router
Tip
How to Configure your Linksys router with wireless security
Launch your Internet Explorer, Netscape or your Mozilla.
On the Address, Search or URL, type: http://192.168.1.1, then hit Enter/Return. A login screen will appear. Type admin for the password and leave the username blank or empty then hit “OK”.
Note: If it doesn’t take admin as the password you might have changed it when you have ran the RUN ME FIRST CD that came with the router so try other passwords.
If you cannot remember the password, I regret to tell you but, you have to reset the router and, reconfigure it again. Next time, remember the password to avoid unnecessary reset and reconfiguration.
To reset the router to factory default
1] Press and hold the reset button for 30 sec., after that
2] Unplug the power keep holding down the reset button for another 30 sec.
3] Then, plug back the power keep holding down the reset button for 30sec., after that
4] Release the reset button.
Note: Configuring WEP in the router varies depending on the model number and firmware version of your Linksys Router.
Cisco Interface (If your Setup page has a Cisco Logo)
Go to Wireless Tab > Wireless Security > Click the drop down arrow then select WEP:
Regular Linksys Router Interface (If your Setup page has a no Cisco Logo)
Under Setup > Click WEP Key Settings or Edit WEP Key Settings
Using passphrase 64bit
Encryption LEVEL 64bit > type a passphrase > click Generate > copy key1 on a piece of paper (10hex character). Then hit Apply or Save Settings.
For manual key entry of 64bit encryption:
Encryption LEVEL: 64bit > Under Key 1 type a 10 digit character from A-F and 0-9.
(e.g.: A0B3F58C9E, 0123456789, ABCDEFABCD). Then hit Apply or Save Settings.
Using passphrase 128bit
Encryption LEVEL128bit > type a passphrase > click Generate > copy key1 on a piece of paper (26hex character). Then hit Apply or Save Settings.
For manual key entry of 128bit encryption:
Encryption LEVEL: 128bit > Under Key 1 type a 26 digit character from A-F and 0-9.
(e.g.:0123456789ABCDEF9874561230, 012345678901234567890123456, ABCDEFABCDABCDEFABCDABCDEF).
If you want better security for Vista computers, you may want to select WPA personal (WPA-PSK) under security > set the Algorithm to TKIP and type your personal security code (any code you want, any characters)
on Jan 06, 2010 | Computers & Internet
How do I set a password on my wireless after it has been installed?
Start your web browser and in the address bar type 192.168.1.1
A pop up window will appear asking for a username and password. leave the username blank and type admin in the password. This will allow you entry into the router. Once there you can navigate using the menu bar on the top to set things like what channel, what type of security for the wireless and such. Channel selection is not needed unless you find a lot of interference with other devices like a cordless phone. Broadcast SSID is another setting. If you disable it, then any device that you try to link to it will require you knowing the "name" of the network. I would leave it on broadcast SSID.
You should change the "name" of your network from the default "linksys" to anything of your chooosing, and then in the wireless security tab, create a "passphrase" using WAP personal settings.
If you choose to change the password to enter the router settings, you need to make a note of it. Don't do anything with the username, just change the password, that way when you need to make changes and type the 192.168.1.1 the only thing you will need is the password again. Don't make the settings password and the "pass phrase" the same.
Jan 16, 2011 | Linksys Wireless-G Broadband Router
Chige pas wrd
To change the password:
1 Click Password in the left column. The Password screen opens.
2 In the New Password field, type the new password (up to 9 alphanumeric
characters).
3 In the Verify Password field, type the same password to confirm your
change.
4 Click Save to accept your Password change or Cancel to remove your entry
and return to the default setting.
Hope this helps and thanks for using FixYa!
Dec 04, 2010 | Gateway Wireless-B Router (wbr-100)
I need to change my NAT type from strict to open
Just look for the reset button on the router and by pushing it for about 10 seconds it will revert to it's factory settings and be an open router. Bear in mind it also resets your entry passwords to something like password or password1
Dec 03, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I have my linksys wrt160n connected but with no password, i cant find my install cd. i want to set a password.
Take it easy. You don't need any installation cd. Connect your computer with the router and after the connection between pc - router established, click on start - run and at the white line type "cmd" without the quotes and hit enter. At the new black window type "ipconfig" and hit enter. Write down the numbers at the last line referring for Default Gateway. Open a browser window and at the address bar type the number you write down before and hit enter, without www etc at the beginning. You will go at the router's entry settings page. In case you don't know the user - password I have to tell you that the default credentials for Linksys routers are:
for user type "admin", without the quotes
for password type "admin'' or"1234" or none, without the quotes. Now on you can change any settings as you like.
In case of the above procedure don't work, locate and press the reset button in order to get the router at the default setting and retry the procedure.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Sep 06, 2010 | Linksys WRT160N Wireless Router
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Jan 31, 2010 | Microsoft Windows 2000 Professional for PC
I want to know how to secure my linksys router over the internet
  1. go to web address 192.168.1.1
  2. default user name is blank, password is admin
  3. click the password tab, to change your password
  4. To change the SSID, click on the Wireless tab. Look for an input item labeled SSID. It will be near the top. Enter a new name for network. Don’t use something like “My Network”. Use a name that is be hard to guess
  5. In the same screen that you changed the name of your network, you will see options for SSID broadcast. Choose “Disable SSID” to make your network invisible. Now save all your settings and log out.
Jan 03, 2010 | Linksys Wireless-G Broadband Router
Can't remember password for my router and need it to get on the internet with another device with my linksys
You can accsess the router config menu by using your browser. Type in 192.168.0.1 or 192.168.1.1 into your browser. That will bring the screen up to enter your user name and password. If you have not changed it the default is username:blank(no entry) and password is:"admin". If you have forgotten this password then you will need to use a pen to push and hold the reset button for more than 4 seconds to re-set the password to the default(this will clear all the router settings to factory default and disable WEP/WPA settings). Once in the router config menu you can then look at/change the WEP or WPA security key that every computer needs to connect to the router.
Dec 28, 2009 | Linksys Wireless-G Broadband Router
Netgear wgr614
Just type 192.168.0.1 into your web browser address bar and then enter admin as the admin and password or admin as the password entry, you will then be able to check the settings without a cd
Nov 27, 2007 | NetGear WGR614 Wireless Router
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 The most secure way to keep your important business data safe online on Cloud backup for easy access anytime anywhere. Apt for businesses of all sizes and also pocket friendly. If you need your life to be sorted out from all the trouble of managing the enormous amount of data that is being generated every day in businesses whether small or large, then look no further because business online backup service of Dataalign is all you need to keep all important data safe and accessible. We at Dataalign provide companies and businesses a unique and easy way to save their essential statistics, facts and information related to different clients securely encrypted on a safe Business Server Data Backup system which allows them to analyze and download their saved data anytime from the saved storage with just a click of the mouse. One of the most distinct and advanced feature of Dataalign Online Cloud Backup is that it makes all your searches easy with the use of artificial intelligence due to which any file or photograph can be accessed by just typing a name or phrase even if you don't remember the particular name of that file. This results from Computer Data Backup smartly and orderly organized documents for easy sorting and categorizing in order of file size, type, owner name, date of creation etc. You never have to worry about the security of your crucially important data on our business as access to all data is restricted only for the person intended. This system provides security and the freedom of choosing who can view all that data. One more feature of this that helps in Business Server Data Backup making our lives more convenient is the choice for the number of days for which you want to keep a data saved on the online storage so that it automatically gets deleted after that, for saving your extra effort of sorting all your data and getting rid of unwanted files and photos to save space for more important data. So, for making your lives less complicated and more sorted contact our toll free helpline number 888 784-9316 for any assistance regarding business online backup.
Jun 23, 2018 | The Computers & Internet
See all Belkin F5D7230-4 Wireless Router Questions
Belkin F5D7230-4 Wireless Router Logo
20 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
