Question about Plumbing
Need to remove fuel pump for a 96' S-10 Blazer 2 door 6 cyl. 2 wheel drive not pumping fuel to air chamber
  • Paul Beyer
    Paul Beyer Mar 20, 2011
    Clarify air chamber
    Master:
  • 403 Answers
But what is your question please
Posted on Mar 20, 2011
Won't keep running
Fuel injectors ? Are there being commanded on by the PCM/ECM ? Do you know how to test fuel system , fuel pump relay etc... Fuel pressure test ! Follow this guy's testing procedure ! GM Fuel Pump Relay Testing If you can't your best bet is take to the dealer !
Feb 28, 2016 | 2000 Chevrolet Blazer
Need diagram of fuel pump on 1989 ford ranger truck
Sounds like you have the wrong part should be OEM Be careful of after market
Jan 25, 2018 | Chevrolet Astro Cars & Trucks
Where is the fuel filter on a 94 dodge dakota sport 6 cyl. 2 wheel drive
its possible its an inline filter which would run across the chassis, or in the tank mounted with the fuel pump.
Jan 06, 2011 | 1994 Dodge Dakota Club Cab
Does a 1991 chevy s-10 blazer have inline fuel pump?
  1. Place wheel chocks behind the passenger side wheels, and lift the driver side of the Blazer with a floor jack. Place jack stands under the frame, and lower the vehicle onto the jack stands. Supporting the truck with the jack stands in this manner prevents injuries that occur if the floor jack fails.
  2. 2 Remove the fuel filler cap, and turn the ignition key to the off position. This relieves some of the fuel pressure on the system, and prevents the fuel pump from starting when the filter is removed.
  3. 3 Locate the fuel filter on the driver side frame rail, just behind the front door. The filter is a cylindrical shaped part, about six inches long, that's in the fuel line on the inside of the frame rail.
  4. 4 Place a drain pan under the filter to catch any fuel that spills. Loosen the filter fittings by using a 21mm wrench to hold the filter while turning the flare-type nut on the line with a 16mm wrench. Remove both sides of the fuel line from the filter and drain it into the drain pan.
  5. 5 Check the rubber O-rings located on the fuel line ends for tears and nicks. Replace any O-ring seal that shows damage. These seals are available at your local auto parts store.
  6. 6 Insert the fuel lines into the ends of the new filter, and thread the flare-nuts into the filter by hand. Be careful not to cross-thread them and cause the need for replacement fuel lines. Tighten both lines with the 21mm and 16mm wrenches.
  7. 7 Raise the truck off the jack stands with the floor jack, and remove the stands from under the vehicle. Lower the Blazer to the ground. Reinstall the fuel filler cap.
  8. 8 Turn the ignition key to the "Run" position--and then back to the off position--three times to prime the new filter. Each time the key is turned to the "Run" position, the on-board computer turns the fuel pump on and opens the injectors to add fuel for starting. Start the engine and check for fuel leaks.
Waterbed Pump Video Inst.
This has an electric fuel pump located in the gas tank.
To replace or check it you do one of 2 things. You can drop the tank or cut a hole in the cargo area to gain access as they are on the top of the tank.I would not suggest cutting hole
Dec 09, 2010 | 1991 Chevrolet S-10 Blazer
How to change a fuel pump on a 2005 Nissan
Nissan Car Altima & Sentra 1999-06 Repair Guide
Fuel Pump - Removal & Installation
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Relieve the pressure from the fuel system.
  3. Remove or disconnect the following:
    NOTE When the fuel sending unit needs to be removed, pull the tab upwards. The tab is located on the sending unit, opposite the end of the float. After the tab is pulled, the sending unit will lift straight out of the tank bracket.
    Negative battery cable Rear seat and the access cover Fuel pump electrical connector Fuel lines from the fuel pump assembly Locking ring Fuel gauge assembly Fuel tube and connector from the fuel gauge
    Fuel pump by pinching the 2 locking tabs together. Lift the fuel pump assembly straight upward and out of fuel tank. O-ring and discard
  4. Place a clean rag in the hole to keep out dirt.
To install:
  1. Remove the rag
  2. Install or connect the following:
    NOTE Verify that the mark on the fuel tank and the components are aligned when installing the pump and fuel gauge sending unit.
    New O-ring and fuel pump Electrical connection and fuel tube to the fuel gauge sending unit Fuel sending unit into the tank
  3. If equipped with a threaded lock ring torque the ring to 22-26 ft. lbs. (30-35 Nm). If equipped with a lock ring held by six retaining screws, torque the screws to 18-22 inch lbs. (2-2.5 Nm).
    Fuel lines and fuel pump electrical connector. Always install new clamps on the fuel lines. Negative battery cable
  4. Start the engine, check for leaks and repair if necessary.
    Fuel pump access cover Rear seat
The fuel pump is located in the fuel tank on all vehicles. In-tank fuel pumps are accessible by lifting up the rear seat to gain access to the inspection cover.
  2. Relieve the fuel system pressure.
    Negative battery cable Rear seat from the vehicle Inspection cover that is located under the rear seat Inlet and outlet fuel lines from the fuel pump assembly Fuel pump and gauge wiring connections 6 mounting bolts that secure the fuel pump assembly to the top of the fuel tank
  4. Raise up the fuel pump assembly and detach the fuel tubes and connector.
    Fuel gauge assembly Fuel pump with the fuel chamber
  5. Pull up the front of the fuel pump chamber and slide the chamber forward.
    Fuel pump from the chamber O-ring seal or gasket
To install:
  1. Install or connect the following:
    Fuel pump to the fuel pump chamber and slide chamber rearward Fuel pump with the fuel pump chamber Fuel gauge assembly using a new O-ring Fuel tubes and connector. Use new hoses and clamps. 6 mounting bolts to the top of the fuel gauge unit and torque the bolts to 18-22 inch lbs. (2-2.5 Nm) Fuel pump and gauge wiring connections New inlet and outlet fuel lines to the fuel pump assembly Negative battery cable
  2. Start the vehicle, check for leaks and repair if necessary. Inspection cover and the rear seat
Hope helps (remember comment and rates this).
Jul 07, 2010 | 2005 Nissan Sentra
I have a 2000 / s-10 pick-up what is the fuel pressure for starting and does the pressure change when running. It cranks and cranks but won't start until i spray starter fluid in air intake, than it runs...
fuel pump issue. Soon it wont run at all. Fuel presure should stay consistant with key on.
6 cyl 60 - 66 psi
4 cyl 41 - 47 psi
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/thomas_c50676e836a18949
Jan 13, 2010 | 1991 Chevrolet S-10 Blazer
2002 chevy blazer fuel pump (4 door)
yes you have to drop the tank. you will also need a fuel line tool to unhook the fuel lines. before you drop the tank see if tou can reach and wiggle the electrical connection on the top of the tank. these pumps have a pigtail issue. please rate
Dec 08, 2008 | 2002 Chevrolet Blazer
99 Chevy Blazer
Have you tested the crank sensor? sounds like no command from PCM to pulse injectors.
Aug 04, 2008 | 1999 Chevrolet Blazer
Plumbing Logo
24 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
