Question about HP Officejet Pro 8500 Wireless All-In-One InkJet Printer
I removed the paper and it won't reset. I've looked all through it and there is no more paper in the printer. It will not do anything else but say that there's a paper jam.
    Novelist:
  • 137 Answers
  1. Turn OFF the Printer, unplug it and turn it backward.
  2. Push the tabs on either side of the access door -NEVER try to Pull Paper out of the front.
  3. Check inside the opening to see if there is a piece of paper jammed in the rollers.
  4. Using a flashlight, gently pull the paper out from the rollers and look for missing pieces.
  5. Replace the access door into the opening. Push gently until you hear it click into place.
  6. Turn it around, turn it On and try again.
***NOTE:
Got Kids? Little Ones? Little Visitors, lately? (Sounds Funny but No Joke)
Try, unplugging, turning it upsidedown giving a gentle shake. I've found paper clips, coins, thumb tacks, swiss cheese, pieces of plastic, etc...
Thank You For Choosing FixYa~!
Posted on Mar 20, 2011
  • wendyapple62 Apr 07, 2011
    I have done this and all the other suggestions on the HP website and others I've seen posted online. The paper jam error persists - but there is no jam!
  • bhammonds Jun 03, 2011
    Wendy, did you ever figure out what was wrong? I am having the exact same problem - have cleared everything, turned it off and back on, error message persists.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 105 Answers
You'll need to open up the printer and look for a sign of paper jam. Maybe it's a small piece of paper that got stuck in the wheels or somewhere else. If there's no paper, reset the printer and reinstall the drivers. You can find them on the official HP website. If you need users manual download it here
Posted on Nov 30, 2013
I have an HP Color LaserJet 2600n. Recently I had to replace the magenta cartridge. I bought a 3rd-party cartridge and the printer display shows that magenta is now "full." But, it won't...
I guess you should try to reset it ..and get the cartridge out and see if the toner (ink ) is getting out ..by pressing it (with the part where you removed the tape ) on some absorbent paper ..when it is working well it should leave a mark on the paper ..the mark should be not washed ...but real color and all...
If it do not ..just use a syringe and blow air in the cartridge ..just to agitate it ..and make sure it is not dry ..
Insert it back ..repeat the procedure until works ..and also if you have the procedure ..reset it ..
http://www.ehow.com/how_6881778_reset-2600n-toner-chip.html
Aug 09, 2011 | HP Color LaserJet 2600n Printer
My paper won't load - it pulls in about 1/4 of the sheet and then stops. I'm getting error code E3 and have checked for a jam but see and feel nothing. I've also used alcohol to clean the...
This is a paper jam error. Unplug your computer from the AC outlet and from the computer, next place the printer on a table or anywhere that you can get access all panels and the paper tray easily. Remove the paper tray and look for any pieces of paper that may be stuck in the printer. Look also around the back as there is usually a panel that can be removed without any tools.and check there. Also open the printer as if you were going to change the ink and look around there. Make sure you have plenty of lighting or a flashlight as even the tiniest piece of paper can trigger this error message.
Hope this helps.
Jul 17, 2011 | Canon PIXMA MP240 All-In-One InkJet...
Paper goes in crooked and won't go down into the printer to print. This is a Cannon bjc-2100.
In most cases there is an obstruction in the paper path causing this. Sometimes by lifting the printer upside down and shaking it can remove the obstruction. If this does,nt work get a torch and look down into the paper path and see if you can see anything foreign.
I have also dislodged the objet by using a A4 cardboard ( folio ) and feeding it back in from the inside of the printer to where the paper usually sits.
I have found hundreds of varied objects that have dropped into printers.
Jul 17, 2011 | Office Equipment & Supplies
I've had my brother mfc-7440n for over 2 years and it's been working great until this past week. Now, it has a paper jam every single time I try to print anything, causing me to have to remove the...
85% of paper jams are caused by worn rollers . The rubber treads in the rollers wears down, making them smooth, so they won't pick up the paper. Sometimes, they are aged, which also gives them a smoother rounded texture, causing jams. The quick fix is to liven up that roller with a mixture of alcohol and soap. Damp a rag with the solution and wipe the rollers clean with it. That's make them more pliable and the paper jams will cease. If you plan to keep your printer,
Replace the pick-up and feed rollers.
Metal Tab Separation- Pull out your paper tray and examine either end where the paper sits in. If any of the corners are held down by metal tabs, this is your paper feed system. Chances are, you only have one rubber roller or one set of rollers arranged along side of each other. Reach in where the tray goes and feel up. You should feel some rollers. They might be completely round, or they might be shaped like a half moon. Clean whichever part of them you can with the solution, and this should stop your paper jams. It might be necessary to turn them, but don't force them if they don't move freely.
Pickup Roller and Separation Pad-
If your printer uses this paper feed system, you should see a small piece of flat or slightly curved rubber or cork. It would be towards the end of the paper tray, or deep inside the paper loading cavity on top loaders. This 'separation pad' rubs against the paper feed roller, so if you find the pad, you've found the roller. Clean it and your jams should stop.
Three Roller Paper Separation System- Pull your paper tray out, and look for a roller on either end of it. If you find one, clean it. Then look inside the printer where that roller would rest with the paper tray inserted. You'll find another paper roller there. Clean this one also. Finally, look further back or closer to the front of your printer (depending on which way your paper feeds) to find another roller or set of rollers. Clean all of these, and your paper jams will go away
Jul 10, 2011 | Brother MFC-7440N Laser Printer
We just moved, and now that I've set the printer up in a new location, the paper won't feed at all. I removed the cartridge and wipped the paper feeder with alcohol still no luck
Hi
When you move the printer normally somethings will brake and get stuck. But 1st things 1st did you check if the tray lifts to take the paper? or try to take the paper atleast? if not then you can try to wiggle the printer a little and you should fine some thing being stuck come out and the printer work well again.
PLZ RATE MY SOLUTION
Jul 06, 2011 | Samsung ML 2010 Laser Printer
Pritner not taking in the paper properly & even if starts taking in half way through it stops
Hello chippyprem,
If the paper is stopping due to a paper jam and it doesn't seem like anything is in the way try looking around the inside of the printer near the cartridges (I'm assuming the paper goes from the back to the under side of the printer - judging by the pictue) for anything, even small, and remove it.
If you've ruled that out and it just seems to be stopping on it's own, your best bet would be to contact the manufacturer of the printer, if it is still in warranty, have it repaired. If not, I would suggest buying a new one, because alot of the time it's cheaper to buy a new printer than to get one fixed.
Hope this helps!Please rate :)
May 28, 2011 | Epson Stylus Photo R320 InkJet Printer
The printer won't feed the paper in properly. It turns crooked and then doesn't load in. Printer thinks there is either no paper or a jam. Can see anything physically in the way blocking the...
Hi Trevo
First, check the the paper guide in the feed tray is up against the edge of the paper. If it is not snug then the paper will skew.
If it is OK then check with a torch both sides of the paper path - where it goes in and where it comes out.
I've found bits in the path before now that are not seen at first.
This printer may have a removeable panel at the back where you can check a bit more easily.
May 25, 2011 | Canon PIXMA MP600 all-In-One InkJet...
Copier won;t work
the sensors are little plastic peices that hang down along the paper trail its how the printer determines where the paper is. There would be one along the trays.
Feb 12, 2009 | Office Equipment & Supplies
Laserjet 4345 mfp paper jam
13.20.00 can be also caused be a jam near the fuser (the part of the printer that gets hot to make the toner stick to the paper). Remove the toner cartridge and take a look for small scraps of paper along the whole path. Also open the door on the back of the printer and look for paper scraps from there. If you see paper stuck in the fuser, do not use anything sharp to remove it, be careful not to scratch the surfaces.
Oct 08, 2008 | HP LaserJet M4345 MultiFunction Printer
HP Officejet Pro 8500 Wireless  All-In-One InkJet Printer Logo
303 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
