Question about Garden
My toro gas trimmer does not have power, when squeez for more gas it will slow down even moreand stall on me. will restart but not enough power to wack weed.
    Sergeant:
  • 259 Answers
Make sure the air filter is clean and that the sparkplug is gapped correctly and not dirty. Try putting it on choke slightly and see if you can increase the speed with the trigger. If you can't the muffler is probably dirty. You have to take the spark arrester off the muffler and clean it with a wire brush.
Posted on Mar 20, 2011
I can not keep my weedeater running?
Mark, Ensure plug is good, remove,inspect replace in tn tank fuel filter if clogged, remove muffler and clean screen in side, carb., carb. could be dirty or out of adjustment or diaphragms worn out and needs rebuilding. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
http://support.mtdproducts.com/app/answers/detail/a_id/10666/~/basic-troubleshooting---handheld-string-trimmers-(gasoline-powered)
Toro String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Jun 11, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
New Ryobi trimmer putters out at full throttle
Absolutely it can. Weight can slow it down, Friction can slow it down,. There are many things that will do exactly what you are talking but the #1 thing would be a Gummed up Carburator. EVERYONE is having the same problems right now.
Apr 07, 2013 | Ryobi 2-Cycle 26 cc Curved Shaft Gas...
How far in the gas tank does a toro trimmer fuel line need to go -- I assume not very far and not as far down as the filtered gas line, correct?
The gas line with the weighted fuel filter on it should lay across the bottom of it (somewhere near the opposite side) and the purge/return line only needs to enter the fuel tank 1/2" to3/4" to work.
Sep 11, 2011 | Toro Electric Trimmer
My toro gas trimmer does not produce enugh power. when squeez for more gas it will stall. It will restart ok, but won't give power. squeee more gas and stal.
You haven't said how old this unit is. Older units sometimes face carbon build up in the engine and muffler. Maybe pull the muffler off and see if the exhaust port of the engine has buildup of carbon and the spark arresting screen in between them is clogged? If it is, clean it and inspect the muffler for clogging too. The muffler can be soaked in a solvent of your choice to loosen and break up carbon accumulation. Other than that, the carburetor may just need an adjustment. Many carbs dont't always function well in the climate they are used in as the initital set up of the carb is a "standard" setting that is mandated at the factory. See if you can adjust it. Here is a tutorial for a typical 2-stoke carburetor, assuming that is what this machine has.
http://www.zamacarb.com/tipspage.html
Mar 20, 2011 | Toro& Electric String Trimmer
My Toro CCR 2450 GTS Snowthrower loses power after it gets warmed up. New spark plug and fresh gas with proper oil mix.Why?
Mine does same. Wait a half hour, restart, runs good for 20 minutes and slows again. Just had it in for a tune up. Machine is only three years old.
Dec 31, 2010 | Toro Lawn Mower With Toro Power Tools
My toro 51970a trimmer has been leaking gas and flooding for the past few weeks, but I could start it. Today, it is gushing gas from the back when I pull the starter string. How do i fix this?
The carburetor needs to be removed and inspected. The malfunctions possibly indicate the need for a repair kit. I've been unable to locate your exact model, but if it has the 2-Stroke engine (gas/oil mix), then you will at the very least..need a gasket and diaghragm kit installed per inspection. There is the possibility that the carburetor needs a complete rebuild and would require the complete rebuild kit. Remove the gas lines (after draining gas). Remove the carb and inspect the screws and tightness of the screws in the 2 end covers. Are the screws tight? If not tighten them up and reinstall, trying to restart the machine. Post back if needed.
Oct 26, 2010 | Toro& Electric String Trimmer
Weed eater bogs down when i try to give it full throttle, won,t get up enough speed and torque to trim grass. i tried new gas, spark plug, and still doesn,t help.
have to adjust the high on the carb. should have, 3 screws, 2 that are together is your h for high, and L for low. the one by itself is for idle. when mackine is running, squeeze throttle and adjust the high til it clears up, if it stalls real fast, back counter clockwise while off, and try to restart it, if worse, go the other way. i do mine by 1/4 turns. keep count of turns in case your going the wrong way! hope this helps!
Sep 15, 2010 | Craftsman 25cc Gas Line Trimmer
Lawn mowewr wont restart
Check the gas cap. Loosen it a bit and try again. There is a vent built into it the hole on top plugs up ans stops the fuel flow.
Eric
Jun 24, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
128 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
