Question about Maytag MMV4205 Microwave Oven
Unable to press buttons and message appears --SE--
  • Maytag Master
  • 6,771 Answers
The word --SE-- means systems error, caused by a short in the keypad membrane. The solution is replace the keypad to resume normal operation.
Posted on Mar 20, 2011
LG Microwave MC8289UR/00 want to know if has child lock and how to turn on and off
Here is a section of the manual for your microwave on child lock, hope this helps.
"L" - Page 7 Press and hold STOP/CLEAR until " L " appears on the display and a BEEP sound is heard. The CHILD LOCK is now set. The time will disappear on the display . To cancel CHILD LOCK press and hold STOP/CLEAR until " L " disappears. You will hear a BEEP when it's released. If any button is pressed, "L" will appear on the display Your oven has a safety feature that prevents accidental running of the oven. Once the child lock is set, you will be unable to use any functions and no cooking can take place. However your child can still open the oven door. Press STOP/CLEAR. Child Lock 7
Jan 10, 2018 | LG Microwave Ovens
401.800084700 se error
www.kenmore.com/customer
Jun 23, 2014 | Kenmore Microwave Ovens
-SE- error message
Sensor Error , qualified Tech can help you , could be anything from a fan to a faulty switch
Dec 03, 2013 | Samsung Microwave Ovens
What does message SE mean on my samsung microwave
Does the clock show at all? If not the fuse has probaly blowin in side the oven. The cover has to be remove to replace it, Or does it beep when you push any of the functions buttons on it? If not the fuse has deffently blowin in it. I admit the the se message has got me stomp.Do you have the manaul for it.If you do check in the manaul if there is a trouble shooting (Section) If worse come to worse call there customor support office for (Help)
Oct 25, 2012 | Samsung SMH9187 Microwave Oven
Samsung microwave child error/ turnd power off now se appears in window and does nothn when push buttons
SE indicates a short in the keypad membrane, the keypad control board will need to be replaced, a costly venture.
Apr 06, 2012 | Samsung 1.8 Cu. Ft. Over-the-Range...
Microwave beeps and with each beep a 6comes up on display, and the START under the numbers flashes, but I am unable to press any buttons to clear it. Also sometimes I can open the door and press the...
You didn't mention your brand or model number, so I can only give you a general response.
It sounds like a shorting membrane keypad.
On Samsung's, they will show the error code "SE".
For detailed do it yourself info and/or an estimate, please post a new FixYa help request and include the model, or contact me here with that info.
Jul 25, 2011 | Samsung MW6351G Microwave Oven
Says "locked' an unable to use, no buttons work
The child lock is on. Turn off the lock by pressing and holding 0 until the word Locked disappears.
To turn on the lock, press Stop/Clear and then press and hold 0 until the phrase appears.
The manual for the Jenn-Air JMC8130DD is available from http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=JMC813&siteCd=JA_EN_US&userType=Consumer .
I hope this helps.
Feb 02, 2011 | Jenn-Air JMC8130DD Microwave Oven
?E - 5" message
From Samsung's FAQs:
"Some models are equipped with a sensor that can automatically adjust the oven's heating time based on the amount of steam in the oven. If your microwave is displaying E1, E4, or E5, there may be an issue with the gas sensor. For an E1 error, press the Cancel button and check on the food.
"Other microwaves do not give specific error messages and just display "8888" on the LED. If you get this error message, your microwave needs service.
"If the message is either ERROR or E-6, it indicates a mechanical fault.
"For all error indications, including the SE or 5E error, try unplugging the microwave from the outlet for at least ten minutes and then plug it back in. If the error persists, the microwave may require service. Please use our ASC Locator to find your nearest Authorized Service Center."
Or instead let us know if we can help further.
Aug 22, 2010 | Samsung MU3050 Microwave Oven
Error message SE
Hello :
Many models of the GE microwave have sensors that can detect humidity from the foods you are cooking. This allows the microwave to make adjustments to the power levels used to cook your food. If "Sensor Error" appears, you should either press "Clear" to cancel the mode or leave the food in the appliance longer to give the microwave more time to detect the food.
Press "Time Cook" to manually enter the time if you receive an error message when trying to use the "Sensor Reheat" mode of your GE microwave. The error message may be caused by the food item being too large or too small to detect .
I hope this will help you .
please rate !
Mar 29, 2010 | Frigidaire Microwave Ovens
Quit working
SE probably means a sensor error.
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Otherwise, it may have a problem with the control panelm such as moisture or contamination or a bad connection.
Let us know if the hard reset doen't fix it, and please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 12, 2007 | Samsung SMH7178STD Microwave Oven
Maytag MMV4205  Microwave Oven Logo
283 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
