I bought a nextwave sdr-3220c satellite receiver with out the instructions. I have connected it to the dish and tv and scanned for dtv but it was not detected. It would seem like having the instructions might be a good idea.
  • 2427 Answers
SOURCE: plasma tv connections
Hi ,,
Ok First off your Plasma has 3 inputs , 1 ,2,3
Here is what i would have done and what you can do.
First of your recivers has RCA output, thats 1 yellow cable and 1 red and 1 white,
The red and white are audoi and the yellow is video
1.) Connect your dvd player to input 1 in your Plasma.
just follow the color codes, yellow to yellow, white to whit, red to red,
2.) connect the other Reciver to input 2
using the same method
3.) connect the dvd to input 3
using the same method..
So now if you want to view reciver1 you set the tv to input1, reciver 2, input2 , dvd , input 3
In the event that your tv does not have 3 seperate inputs
you can go to your locol electctronics stor and purchase an RCA switch box
this is a device that has 3 seperate RCA inputs, a switch to slect which one you want to use and an output to connect to the tv, Simply connect all your devices to the RCA switch, and then connect the rca switch to your tv..
There are other methods of doing the same thing, but i chose this one as its the most simple solution
let me know if you are having any problems
Posted on Jan 08, 2008
SOURCE: Nextwave SUC-2500C English manual
www.rezamollayi.blogfa.com
Posted on Jan 12, 2008
SOURCE: Cnannel scan detects no channels
Kingscott,
Make sure the cable connection from the dish to the tv is
connected to the antenna/cable input and not the digital
input. Turn on the satellite receiver then auto program the
set with the receiver still on. If this fails to lock in channel
3 your suspicion regarding a faulty tuner could be correct.
A good way to check the tuner operation would be to hook
up another product such as a VCR with the rear switch set
for channel 3 and see if you can receive a picture from this
device. If it works the tuner is OK.
You can bypass the tuner by connecting an S-Video cable
and (or) a set of A/V (yellow,red & white) cables from the
output of the satellite receiver to the video 1 input on the tv.
You'll then have to switch the tv source mode to video 1.
Hope this of some help,
Caseybee
Posted on Mar 20, 2008
Agent Dort
  • 216 Answers
SOURCE: New TV won't talk to satellite receiver
Greetings ChaosReid,
I would suggest calling your satellite company and seeing if they are able to give you any suggestions. Also you might consider contacting someone like the Geek Squad® and having them come out and do a video installation. That might prove costly though. I would think that your retailer should be able to provide some insight.
What type of connection are you using presently to hook it up?
Wishing for the best!
Dorothy
Go Ahead. Use Us.
Posted on Jun 11, 2008
SOURCE: Connecting a Dish 622 Receiver to the HTR500 and a Sony HDTV TV
Have a Vip-722 Dish HD receiver with a Sony receiver w/0 HDMI input and use the optical for audio for the 5.1. Using the HDMI and digital optical at the same time works fine for me.
Posted on Aug 12, 2008
Will a 7yr old dish receiver work today on dish satillite
With an antenna that is pointed correctly to satellites 110 and 119, the receiver will function, but will not have access to paid channels without authorization from DISH (which you can get by calling 1-800-333-3474). You may have to run a check switch test after connecting to antenna by accessing the menu, system set-up, installation, check switch.
Jan 27, 2013 | DISH Network 311 DTV Receiver
Sat finder detects signal on 61.5 Sat but receiver does not display or lock.
Hi, Mary with Dish Network Customer Service. The 61.5 Satellite carries mostly High Definition programming. If your Satellite Dish is an older model, it is not equipped to bring that Satellite in. It is the part on the Dish called the LNBF (the eyes) that will pick up the satellites. Your receiver is a Standard Definition, you should be reading the 119 & 100 Satellites. I hope this helped but if you have additional questions, please let me know.
Dec 22, 2010 | DISH Network 311 DTV Receiver
Unhooked all lines in back of tv cant remember to rehook up have2
granmabj,
There are common connections to each receiver but there are unique connections also depending on the receiver. Solo receivers have a coax cable coming from the Dish outside connected to Satellite In. Duo receivers and DVR HD receivers have the coax cable that comes from the dish outside that connects to Satellite 1 and Satellite 2 using a splitter. There is also a cable (coax, RCA (yellow, white, red) or component (green, blue, red - video, white, red - audio) or an HDMI if HD) connected from the receiver to the TV 1. For a duo receiver TV 2 may be backfed on the cable coming from the dish outside using diplexers. This may sound confusing but you can call 1-800-333-3474 for assistance.
Ray Calo
DISH Network
Jul 23, 2010 | DISH Network DVR-625 DTV Receiver /...
Will a Dish network 1000 satellite dish work with my VIP 211 reciever?
It should as long as it is pointed to the correct orbital locations,
Jun 26, 2010 | DISH Network ViP 211 DTV Receiver
Tv wont pick up channels
Have you been into scanning settings and set to DTV , it seems like you are either on ATV or have a bad Antenna connection. If signal is weak from your Antenna you can add a booster in the section between your wall socket and the TV. You cannot use Satellite dish connections to receive either ATV or DTV signals without a set top box ...
Dec 05, 2017 | Coby TF-TV1901 19 in. LCD Television
I can't get past the ''searching for Sattellite'' display
Doublecheck your connections. The connection from the dish should be on "Satellite in", NOT "In from antenna." That is the most common mistake that is made.
Mar 19, 2009 | Directv D12-300/100 DTV Receiver
2 dtv boxes one Satellite
you need to install a multiswitch so you can run more than 2 coax cables from your dish
Jun 24, 2008 | Directv (DWO2-10024)
Trouble with the hooking up wiring for receiver, DVD/VCR combo and satellite to new DLP TV.
Jar50, lacking model numbers for your TV and Satellite, I would suggest connecting your DTV Satellite OPTICAL out to your 65"DLP. Connect your 65"DLP OPTICAL out to your Onkyo TX-DS484 OPTICAL in. If you are using the DIGITAL COAX, just substitute the instructions above from OPTICAL to COAX.
Hope this helps.
Aug 28, 2017 | Onkyo TX-SR803 Receiver
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
