Question about Philips Electronics - Others
Lose of sound on bluray bdp2700 on hdmi...have upgraded to latest f/w & swap hdmi cable & ports on tv
    Master:
  • 525 Answers
Make sure you have all your soundcard drivers intalled and sound codecs for blu ray.
Posted on Mar 20, 2011
How to connect tv, direct tv box, and home theater together properly ?
Hi Vincent
That would be a heap of detail to go into. Time consuming...
Hopefully this quick pointer might help.
What is HDMI
High Definition MultiMedia Interface
Note the word MultiMedia
This Means....Both HD Video & Sound through the one cable.
HDMI is the latest state of the art connection.
Use this wherever possible. It's made for High Definition
More Convenient
Use a HDMI cable from one device to the other wherever both devices have that port type (connector).
You don't have to pay a premium ridiculous price for HDMI Cables as in the Monster type. Overpriced.
Well made regular brand & Gold pins are nice. Keep them Short.
Long Cables loose quality. 1 Meter is default.
Your LCD TV should have more than one HDMI port for inputting & outputting media (sound & video)
HDMI can be used for INPUT or OUTPUT
Eg OUT to an Amplifier or IN from a device like DVD Player.
On the OLDer equipment you will Have a YELLOW connector. That is used for the Video signal.
The RED is RIGHT AUDIO.
The WHITE is LEFT AUDIO.
Fiber OPTIC cables are a better way to transfer AUDIO than the red & white cables. Cleaner.
But this only works if the 2 devices have an optical port available.
Some New Amplifiers are smart and may require you to select the optical port in the settings instead of the default HDMI.
This may also apply to HDMI Port Choice.
Simply plug the HDMI in first & check.
Use a known source e.g. play a DVD or CD or Radio Reveiver as a signal.
ONE HDMI Port on the TV might be an OUTPUT ONLY channel (PORT) to an External Amplifier (if you wish to use one)
HDMI on external devices will be Outputing video & sound on their HDMI Port
To the INPUT HDMI PORTS on the TV.
Some TV's will fall back to a particular HDMI port on power fail or startup therefore not requiring you to use the remote every time.
External SPEAKERS should have the polarity checked. Eg Red (or marked wire) to the same post on either speaker. This makes sure that the speakers travel forward together at the same time. Pumping sound forward then retracting together....
so they are not fighting against each other.
.......This is called out of phase & distorts sound.
Hope this Helps
Enjoy Your New Entertainment
Was this Helpful
.......Then give me a tick of approval for my trouble....
Cheers
HDMI Wikipedia the free encyclopedia
Feb 13, 2016 | Orion LCD TV SLED2480 Sansui - 24"...
Have lg 55ls5700 tv trying to connect samsung hw-f450
I suspect that the TV you have does not support the ARC function that the sound bar has. What you may have to do is use the Optical In from the sound bar to the TV and you should be good to go. You may have to change the TV's settings to use the Optical In though. So you should end up with the BluRay Player connected to the TV via an HDMI cable, the sound bar connected to the TV via the Optical In using a fiber optic cable. Hope this helps.
Mar 19, 2014 | LG 55ls5700 55 Edge Led Smart Tv 120hz...
Phillips 50pfp5332d/37
take it back and exchange it...then you'll know for sure if they are incompatible or TV is on the fritz or a bad sound system
Jan 14, 2014 | Televison & Video
How do I connect a Toshisba soundbar?
Your sound bar should have some sort of HDMI IN and HDMI OUT. This means that there are at least one place to plug a HDMI cable into the bar from either your dish or bluray player and then you take another HDMI cable and plug it into the port labeled HDMI OUT and this will plug into your TV either in HDMI1, HDMI2, or HDMI3 and then it will provide sound for the device. Unfortunately you didn't not list the item so I can not look it up to see if it can accept multiple devices so if it only has two HDMI ports then it can only support one device and you will have to manually change out devices through the HDMI IN port. Essentially the soundbar is just a pass though and takes the sound and sends the picture to the tv.
Jun 03, 2013 | Sanyo Dp55441 TV
Panasonic bdt210 no sound
you will know if hook to another set but I in our shop have seen similar issues where either a cable or sat box had to be rebooted or even a software upgrade done to the set.
HDMI has mostly sound issues--my experience is it also does NOT like to be connected to units which are on at the time.......
Apr 03, 2012 | Televison & Video
Pioneer vsx521 stopped recognising hdmi connection from computer
Press the Audio Parameter button (Looks like an x) then scroll up until you see 'HDMI AMP' and hit over to the left or right so it shows 'HDMI THRU' the HDMI will redo the handshake and you should have sound.
Mar 12, 2017 | Pioneer Audio Players & Recorders
Player turns on ok,display shows menu that disc is playing but tv says there is no signal, not seeing home screen with net flixs or the other apps.player has been working great we used it 2 day earlier...
The "handshake" between the television and the blu ray player has been lost. This happens a lot when connecting with hdmi. Sometimes a hot swap will work to remedy this. That is turning off and unplugging both your television and bluray player while removing the hdmi cable from both for 30 seconds to one minute. Reconnect the bluray player to the hdmi cable and then to the television. Plug them both back in and turn the television on first then the bluray player. Your television may need a factory reset going into the service menu or the board the hdmi ports are located on might need to be replaced if all of the hdmi ports are not responding. You can connect with component if possible in the meantime.
Apr 14, 2011 | LG BD390 Blu-Ray Player
When connecting motorola dct6412 to samsung tv, blu-ray player & avr via HDMI (DVI), do you run the HDMI from dvd & cable box to the avr, then seperate HDMI to the tv?
If you have more than one HDMI port on your TV,
run one HDMI cable from the DCT6412 to the TV,
and one HDMI cable from the BluRay unit to the TV.
Then, use the "source" (or "input") control on the TV's remote-control to select either 'HDMI1' or 'HDMI2'.
Dec 16, 2009 | Motorola Televison & Video
Problems connecting Yamaha & BluRay player on Portable Computer.
hi i had similar problem, you need to change the settings in the bluray player output to hdmi or auto in other to get sound after the settings turn everything off even from the socket and then turn it back on for that setting to take effect. try this
Jan 12, 2009 | Yamaha RX-V661 Receiver
Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Nov 19, 2008 | Televison & Video
Electronics - Others Logo
114 people viewed this question
Top Philips Electronics - Others Experts
Bill Boyd
Tom Chichester
Are you a Philips Electronics - Other Expert? Answer questions, earn points and help others
