MY KAWASAKI T.V. IS HOOKED UP TO COX AND HAS WORKED PERFECTLY UNTIL I TRIED TO TURN IT ON AND IT APPEARS THAT IT IS NOT GETTING POWER. NO PICTURE; NO SOUND, JUST BLACK SCREEN.
    Master:
  • 344 Answers
Check all your power connections.. unplug everything.. plug it back in. If you are using a power strip make sure that it is functioning properly. If it is still under warranty contact the company that makes it. If not.. either look into someone that is smart with electronics to check the insides for a blown fuse or consider buying another one.
Posted on Mar 20, 2011
Can't get my VCR to work with the mini box from Cox. Picture is garbled. Mini box works fine with out VCR hook up.
Here's a link that shows how to connect a Cox mini-box up with a VCR. There are other diagrams as well. There is also a support forum and you can contact their tech support for additional help.
http://www.cox.com/residential/support/tv/article.cox?articleId=c6975670-69b8-11df-5fca-000000000000
Jul 25, 2015 | RCA Televison & Video
Unable to find IR Code for power on/off using cox cable remote
1. Turn on a device and, if applicable, insert video
media, (e.g., cassette or disc).
NOTE: Please read steps 2-4 completely before proceeding.
Highlight or write down the codes and device
you wish to program before moving on to step 2.
2. On the remote control, press a device key once
(e.g., AUX, VCR, TV, or CABLE). Press and hold
SETUP until the selected mode key blinks
twice, then release SETUP.
3. Use the Manufacturer’s Codes (starting on
page 11) to locate the the type of device and
brand name and then enter the first four-digit
code for your device. If performed correctly, the
selected mode key will blink twice.
NOTE: If the selected mode key emits a long blink, the
code is invalid. Repeat steps 2 through 3 and try
entering the same code again.
4. Aim the remote control at the device and press
POWER once. The device should turn off. If it
does not, repeat steps 2-3, trying each code for
your brand until you find one that works. If it
still does not work, try searching for the code
(see Searching For Your Code on page 20).
NOTE: If the device does not have a POWER key, press
the (Play) key.
5. Repeat steps 1 through 4 for each device you
want the the remote control to control.
The potential codes for your Sylvania TV are:
0054
0030
0381
Here is the manual. The codes are on page 11 if you need more.
http://www.cox.com/Fredericksburg/digitalcable/Cox_d4.pdf
Hope this helps :)
Dec 22, 2007 | Televison & Video
Screen freezes, and buttons don't work!
It sounds that the main digital board to your TV has the fault. To check and locate the fault to this board is a very skilled work. Contact any service technician.
May 28, 2013 | Vizio SV421XVT 42 in. LCD TV
First and foremost, DVD's still play perfectly and the colors are beautiful, perfect and alligned on my PT53WX52. However, on Regular TV-(Cox Cable) every human being appears to be the color similar to...
Replace the cable from your cable box to television. Try one from one of your other cable boxes before buying one, but I highly suspect the actual cable from box to TV is bad
Feb 24, 2011 | Panasonic PT-53WX52 53" Rear Projection...
Kawasaki Kit ECU on '07 ZX-6R race bike
Hi, Simon_mcaule the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable race shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry. Not being able to pull codes really puts you in the dark, could be a faulty connection in the ignition circuit or you may have a temperamental ECM that doesn't like aftermarket performance parts, a face to face with your fuel tuner may also be in order.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
2009 ZX6R Engine Dies randomly intermittently Help please
06 zx6r randomly shuts off
http://vitek.vellum.cz/manualy/Kawasaki%20Ninja%20ZX-6R%202007%20Service%20Manual.pdf
OEM Parts for Kawasaki
http://www.factorypro.com/manuals/Kaw,KRT,zx6r,zx10r,05-07,Mk2,lateKRT/zx6r,07,Racing_Kit_Manual.pdf
Kawasaki Ninja ZX 6R Owner Manual
Jul 13, 2017 | 2007 kawasaki ZX-6R
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
No picture from cable box to tv
If you get on screen menues using the Sharp Remote then you have a main board that is defective. If you just bought it new you are in luck as the warrenty on that unit is a lease 1 year parts and 1 year labor. Contact Sharp Customer Service and should be able to refur a Sharp Auth. Repair facility to get you taken care of. In the mean time, If you got on screen menues then you can go to any one of the other video inputs and see if you get a picture.
If you DO NOT get onscreen menues with the Sharp remote then you are out of luck until a service repair facility looks at it.
Hope this helps,
Skyassoc
Jun 19, 2009 | Sharp Aquos LC-32D40U Television
0178 cox remote code does not work for samsung hdtv
some remote's have a way of programming without the code by entering a code and toggling the buttons for the device and the power button until the device turns off to automaticly find the code for the device look in your remote manual if you dont have it just search it online good luck......
Jan 11, 2009 | Zenith ZEN700 Remote Control
Cant get a picture
1st-how do you have your "cox" cable box [you could have said it was a cox cable box!!] connected.Can you 'get a picture' through the TV without the VCR ? Do that! disconnect the VCR from the line and plug the TV directly to the "cox" box.Does it work? Are any of the cables connected from cox to VCR to TV damaged.? Let me know how you have the three(3) equipments connected.
Aug 07, 2008 | Toshiba W522 VHS VCR
Hooking up rounter to cox cable
hello!
-- what is the operating system of your computer?
-- is the router working fine before or is it a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
May 27, 2008 | Linksys Wireless-G WRT54G Router
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
