Question about Toro& Electric String Trimmer
My toro gas trimmer does not produce enugh power. when squeez for more gas it will stall. It will restart ok, but won't give power. squeee more gas and stal.
    President:
  • Toro Master
  • 1,545 Answers
You haven't said how old this unit is. Older units sometimes face carbon build up in the engine and muffler. Maybe pull the muffler off and see if the exhaust port of the engine has buildup of carbon and the spark arresting screen in between them is clogged? If it is, clean it and inspect the muffler for clogging too. The muffler can be soaked in a solvent of your choice to loosen and break up carbon accumulation. Other than that, the carburetor may just need an adjustment. Many carbs dont't always function well in the climate they are used in as the initital set up of the carb is a "standard" setting that is mandated at the factory. See if you can adjust it. Here is a tutorial for a typical 2-stoke carburetor, assuming that is what this machine has.
http://www.zamacarb.com/tipspage.html
Posted on Mar 20, 2011
I can not keep my weedeater running?
Mark, Ensure plug is good, remove,inspect replace in tn tank fuel filter if clogged, remove muffler and clean screen in side, carb., carb. could be dirty or out of adjustment or diaphragms worn out and needs rebuilding. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
String Trimmer Starts Then Stalls
http://support.mtdproducts.com/app/answers/detail/a_id/10666/~/basic-troubleshooting---handheld-string-trimmers-(gasoline-powered)
Toro String Trimmer Starts Then Stalls
My String Trimmer Starts But Won Stay Running
Jun 11, 2016 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Toro power head 51944 won't prime
Replace primer bulb or line and filter running from bulb to fuel tank.
Apr 16, 2013 | Toro 2-Cycle 25.4 cc Power Head 51944
My weed eater (toro), won't let me pull the cord at all. This weed eater doesn't take oil I don't think.
All internal combustion engines use oil of some description. I take it this is a 2 cycle engine and you have not added oil to the gas. If this is the case the engine is locked up, and must be replaced. Sorry.
Mar 25, 2012 | Toro& Electric String Trimmer
My toro gas trimmer does not have power, when squeez for more gas it will slow down even moreand stall on me. will restart but not enough power to wack weed.
Make sure the air filter is clean and that the sparkplug is gapped correctly and not dirty. Try putting it on choke slightly and see if you can increase the speed with the trigger. If you can't the muffler is probably dirty. You have to take the spark arrester off the muffler and clean it with a wire brush.
Mar 20, 2011 | Garden
Weed eater bogs down when i try to give it full throttle, won,t get up enough speed and torque to trim grass. i tried new gas, spark plug, and still doesn,t help.
have to adjust the high on the carb. should have, 3 screws, 2 that are together is your h for high, and L for low. the one by itself is for idle. when mackine is running, squeeze throttle and adjust the high til it clears up, if it stalls real fast, back counter clockwise while off, and try to restart it, if worse, go the other way. i do mine by 1/4 turns. keep count of turns in case your going the wrong way! hope this helps!
Sep 15, 2010 | Craftsman 25cc Gas Line Trimmer
Toro Gas edger.
the srew on the carburator that adjust the air fuel mixture needs to be turned out 1/2 turn or the choke is on.
Jul 19, 2010 | Poulan Pe550 Gas Edger
Lawn mowewr wont restart
Check the gas cap. Loosen it a bit and try again. There is a vent built into it the hole on top plugs up ans stops the fuel flow.
Eric
Jun 24, 2009 | Toro Lawn Mower With Toro Power Tools
String breaking
Check to ensure that the string is the correct size as specified in the owners manual. If ok check age of the string. If old it has a tendancy to be brittle. If new and supple try letting the trimmer get up to full speed and let the tip of the string do the cutting. Avoid taking on too much at once with this trimmer as the electric and battery trimmers are not as powerful as their gas counterparts. I hope this helps.
Sep 11, 2008 | Toro& Electric String Trimmer
Toro& Electric String Trimmer Logo
427 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
