SOURCE: Campbell Hausfeld Air Compressor won't start
try turning the switch off for 5 minutes the turn it back on there is usually a circuit breaker or thermal overload that can trip let me know if problem still exists
SOURCE: what kind of oil and how much to use in campbell
you can reach help for campbell hausfeld @ 800-955-6879
SOURCE: Need new pressure regulator for Campbell Hausfeld
Friend had some pressure regulators and one of them fit. It is also a step up from a direct replacement OEM part. Thank you for your responce to my question.
SOURCE: i have a campbell hausfeld 60 gallon compressor 20
I am not a master electrician but I was an apprentice for 5 years and think you should be ok with a 30 amp breaker. anything less and you may be resetting the breaker when the unit first turns on. Dont forget 30 amp breakers will require # 10 wire or larger, #12 just wont do.
Testimonial: "thanks alot"
