Question about Lenovo 3000 N200 Notebook
Yesterday suddenly my computer is tripped off with out warning.. at that time i was running it on battery. It never happen before and i have my coputer shutdown action setup at 10% battery charge but it just tripped off no shut down opertion. so i plugged in and start it again.. i saw my battery is 13% and my laptop is running on AC power and battery is not charging it is still on 13 %. i could not figure out.. i tried removing battery and again plagging in but no luck.. help me please. My laptop model is : Lenovo 3000 N200 0769 A74
  • 30 Answers
It seems that you need a new battery. My Lenovo 3000 N100 goes through them pretty quickly - with pretty much the same symtoms. Using Ubuntu Linux seems to wipe them out even faster. Now I have the battery installed only when traveling.
Posted on Mar 20, 2011
  • 135 Answers
Sound like your power adapter is about to go. Replace it and check if will to the charging.
Symptoms bad alternator
Engine dying when running was a problem to me on a diesel ute. Was fuel related - Starving from Air lock which cleared by bleeding the primer pump.
Sep 20, 2013 | Infiniti I35 Cars & Trucks
2005 Pontiac sunfire wont start,
Well, you may have shot yourself in the foot by cranking the engine until you totally killed the battery. If there were any fault codes in the computer that could lead you to the cause of your engine not running, they are probably gone now, so the car will have to be diagnosed manually.
When engines stop running, they almost ALWAYS do it suddenly without any warning - so you are not alone. The problem here is that there are probably at least 300 different parts of your car that can be the cause of this. So, I am not surprized that you have been told that it COULD be so many different things. The fact-of-the-matter is that NOBODY can tell you with any certainty what is going on with your car without FIRST performing some diagnostics to eliminate certain possibilities.
The only way any of that is going to happen with any efficiency, is to get the battery charged back up first. NOTHING on your car works properly with a discharged battery. Only after the battery is charged can the other systems be tested.
Nov 18, 2011 | 2005 Pontiac Sunfire
After worming up idle surges and it down shifts hard when driving. Run good when cold. Today after short trip. It surged over 1300 RPM. sitting in the driveway. It seems to be getting worst. 04 Gand...
without a data reading scan tool and the truck in front of me, i can give a very likely cause, that would be the TPS (throttle position sensor) it tells the computer where your foot is at all times and they get testy over time giving the computer very erratic information, think garbage in/garbage out, i recommend replacing the TPS disconnecting the battery for 10 minutes and seeing what happens, WARNING: only an OEM or very high quality sensor(such as NAPA,ACdelcoetc..) is recommended cheap sensors cause more issues than they are worth remember you get what you pay for
May 26, 2011 | 2004 Jeep Grand Cherokee
My 2005 Malibou Maxx ls loses power without warning. Sometimes it happens when it is cold but yesterday I had been drivving for over 1/2 hour before it suddenly stopped. It doesn't happen every time I go...
can be a sign the cam or crank sensor is on its way out, can also be a dirty MAF sensor. cam sensor will make the engine run ruff, MAF will make engine ruff and not idle properly, Crank sensor if it fails it shuts engine down as it dont know were the engine is at on its cycle. air filter changed or replaced damage air filter will coat the maf with muck and it will need cleaning off the sensor, easy to do with MAF cleaner. sensors they can fail when they to hot for them to run anymore or to cold. the resistance in the sensor goes up and down in different temperatures. some time when it goes completely out of range the engine light comes on, but a failing one that is still in range makes the engine run out of order.
Jul 15, 2017 | 2005 Chevrolet Malibu
I have a Peugot Partner 1.4 . I was driving
you have a stripped and or binding speedometer cable or gear :)
Jun 22, 2009 | 2005 Peugeot 405
Acer Aspire One Zg5 will not boot up no indicator light come one
Hi there.
Try taking the battery out and booting it on AC power only, if it boots up turn it back off and reinsert the battery, turn the computer on, if it boots up all good, if not please post back.
Good luck
May 21, 2009 | Acer Aspire 5100 Notebook
AMD Sempron 2600+ (Socket A, 1.83GHz, 256KB L2) suddenly trip OFF
I suggest that your CPU fan and heat sink need cleaning it seems that your computer is overheating
Jul 24, 2008 | AMD Sempron 2600+ / 1.83 GHz ( 333 MHz ) -...
Toyota Prius starting problem
There's a known problem with the early Toyota Prius (2001 - 2003), when running the engine for a long period of time without moving or when the car is driven only for short trips (short city driving), the Prius might not start.
You have to change the original battery with a 356 CCA which is bigger because the battery is bigger you also have to change what is holding it into place.
Jul 22, 2008 | 2003 Toyota Prius
Lenovo 3000 N200 Notebook Logo
171 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
