I have a 2230 printer with a parellel cable but my computer doesn't have a parellel port only a USB is there a way to buy any kind of attachment for this.
  • 135 Answers
Yes. you can find parallel to usb cable which cost around £5-10. Alternatively, is your printer have network port...you can use that also to connect it to your computer.
Posted on Mar 20, 2011
Computer can't find printer
Parallel connectivity: Go to printer properties, check in ports which connectivity selected, if its selected as USB by mistake correct as parallel apply make it OK.. check..
Remove parallel cable both ends, fix it back.check, replace with another cable & check
Check proper drivers are installed or not..
Remove formatter observe is there dry solder at parellel port.
Finally suspect to formater
Feb 04, 2012 | HP LaserJet 4050 Printer
Printer si not working
PLEASE CHEAK THE CABLE CONNECTION
CHEAK THE PAPER SETTING
CHEAK THE PRINTER DRIVER IS INSTALLED ON YOUR COMPUTER OR NOT
CHEAK THE PORT SETTING WHEATHER YOU SELECT A USB,SERIAL OR PARELLEL
WAITING FOR YOUR REPLY
THANKS &REGARDS
YOUR FAITHFULLY
vijay p. patel
Mar 07, 2011 | Samsung ML-2510 Laser Printer
My printer wont print from my computer. I installed it and it recongizes the computer but it wont recieve it. It says error
Have you installed the correct drivers for printing...also you need to check the connection port.. make sure you have connected it and have it registered as connected by the correct port you can find this by going to the control panel on your computer and look for printers find your copier and right click on it .. you see apage open look for the ports tab and check that the port for the copier is set to the correct method ie usb for usb connector or parellell port TCIP if connected with a network cable..if you have it connected with a network cable you will have to enter the ip address too.
Jun 27, 2010 | Ricoh Aficio 2035 Copier
Is it possible to connect an old, still very efficient HP 5L Laserjet Printer which uses parellel port cable to a new computer via a USB cable? If yes, what do I need?
Yes it is. You just need a Parallel to USB adapter. Here is a link to an example of what you need.
Parallel to USB
I have done this several times with Parallel Receipt Printers. Works Great!!
Another option would be to add a Parallel Port to your new computer. Here is another link.
PCI Parallel Card
The 1st option is probably the cheapest and easiest.
Good luck and have a great day!
Feb 26, 2010 | Office Equipment & Supplies
I have an old HP deskjet 3820 printer and a new HP pavilion desk top which has only USB I/O ports, no parallel ports. Therefore I need an adapter cable to connect my printer to my new PC. Does the adapter...
You can almost buy a new printer for the cost of the adapter you are talking about buying. They have all kinds of adapters: the kind that connects to the flat end of a USB or the square end. Parallel, male or female. Go to a computer store like best buy, they should be able to hook you up.
Hope this helps.
Dec 10, 2009 | Cars & Trucks
Can not print with Epson LX-300
The USB to parallel converter does not always work.
You should buy a Parallel port for your computer if you have can extra slot inside the machine. The cost for the parallel port is usually under $20.
thanks adi
Oct 03, 2009 | Epson LX-300+ II Matrix Printer
Cannot install Canon PIXMA MP190 printer
Thank you for your promptitude.
Today I solved my problem. Was a cable connection problem. Cable incompatibilit or all 3 cables used before are damaged. Tuday I buy an other new cable and SUCCESS!!!: my computer see de printer ("new hardware found" when attach usb cable) , create virtual usb port, install the drivers (I have the drivers downloaded from the Canon web site) and printer is working fine.
Anyway, thank yow again for your support!
Jul 09, 2009 | Canon PIXMA MP160 All-In-One InkJet...
MY SYSTEM DOES NOT HAVE A PARALLE PORT...
you need to purchase a pci parellel port card this page will give you an idea of what i mean
http://sewelldirect.com/ParallelPCICard.asp
Mar 23, 2009 | Computers & Internet
Have to keep setting up HPLJ 5P on a USB port everytime I print!
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly.
Nov 29, 2008 | HP LaserJet 5p Printer
HP Laser Jet 1320n series
The HP LaserJet 1320 has a USB port and a Parallel port.
The HP LaserJet 1320n has a USB port and an Ethernet port.
USB-to-Parallel converter cables, like this one, are designed to attach a parallel device to a computer's USB port.
But you need to do the opposite (attach a USB device to a computer's parallel port). A USB-to-Parallel converter cable will not do this.
Feb 29, 2008 | HP LaserJet 1320n Printer
23 people viewed this question
k24674
jasbo
jasbo
