Question about GE (PSS26MSRSS) Side by Side Refrigerator
Water seapage the fridge seems to defrost the freezer or something all over the floor everyday. the water is un hooked an has been for some time now to eliminate the water filter.bottom of freezer there is ice build up like you wouldnt believe.
    Champion:
  • 210 Answers
Check the freezer drain. is it frozen over? drain is back of freezer on bottom.
Posted on Aug 04, 2008
Auto defrost seems to not be working because the drip tray is dry is it supposed to be like this or wet most of the time freezer is cold but not freezing and fridge isnt cold i have temp gaugers in both...
either un plug the fridge and let it defrost manually, or empty and flush out drain line with a hose or hot water. when it goes into the defrost mode, water should drip into the pan..
Apr 03, 2012 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
Freezer is cold, fridge side is not. Fan runs, compressor seems to run. water puddle on the floor on fridge side. anything available for DIY?
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 01, 2011 | Amana ASD2620HRZ Side by Side Refrigerator
I've had this problem before, where the fan is frozen so the fridge is no longer cold but the freeze is OK. What the guy did last time was remove the floor of the fridge, and poured hot water on the fan...
fridge not going into defrost, freezing up coil, replace defrost control, should thaw out fridge, or your evaporator fan motor is burnd out, thaw fride first see if fan works, if fan ok ,derost timer, if not relace fan motor
Sep 06, 2010 | GE GDS20KBS Bottom Freezer Refrigerator
Our Whirlpool top freezer unit is leaking water into the refrigerator. The model number is ET21NKXGW01 and at the top of the inside of the fridge, water is draining out into the fridge. The defrosting...
We were able to fix the freezer water leak. We unscrewed the false freezer floor and the inside back panel. Ice had accumulated on the freezer floor and the defrosting drain was frozen. We removed the ice by using a blow dryer then poured boiling hot water onto the frozen drain hole. The frozen water in the drain pipe hole eventually melted and the water released into the defrosting drip pan at the bottom of the refrigerator. Problem solved. We no longer have water leaking into the refrigerator.
Aug 05, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
53 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
