Question about Whirlpool Duet GHW9150P Front Load Washer
Noisy on spin cycle "rattling"
  • Whirlpool Master
  • 43,501 Answers
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Posted on Mar 20, 2011
Noisy during spin cycle
Yes that is definitely bearing noise you here.
Jun 21, 2017 | LG Washing Machines
Noisy clutch, spinning sound, intermittent
If it's a rattle type sound it maybe dual mass fly wheel noisy too much play in it, requires replacing!
It also could be release bearing noisy too if it sounds like a wurring noise
Mar 07, 2015 | 1997 Nissan Pickup
Hi, I have an AEG 72630 Update machine, its been very noisy for a while on spin cycle but now is making a rattling noise & is leaving black spots on clothes, could it be bearings??
Yes this is the bearings, they have completely collapsed and the oil is leaking out onto your clothes. You will need a new tub rear and that is around £120 plus labour. Sorry its not better news.
Mar 07, 2011 | AEG Washing Machines
My Hotpoint BWD129 washer/dryer has got noisier and noisier during the spin cycles. It is now so loud it is unbearable to be in the same room as it and it rattles anything off the worktop nearby. Any...
This is most likely the drum bearings failing.
Drum bearings normally last a long time (10 years or more isnt unusual), but quite often drum bearing failure is caused by a faulty drum shaft seal allowing a small amount of water through and in to the bearings. The bearings then start to rust and this accelertes how quickly they deteriorate.
Replacing a drum bearing requires well above average DIY skills, so unless you feel you can do it, can get hold of a tech manual, and can find a supplier for the bearings, it's time to get a quote from an engineer.
Nov 13, 2009 | Washing Machines
This may be due to a worn belt (squeeks when changing speed), Faulty dampers - (banging about), constant rattling (rear bearing), or a motor on it's last legs (replace motor).
Most faults can be fixed by replacing those listed.
Sep 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
Kenmore Washer: Noisy Spin Cycle
if this sound is similar to a jet engine then it may be best to get a quote from your local repair man to see if repairing the unit will be worth it. there are a lot of steps in fixing this problem and you may be able to do this yourself but it is pretty difficult.
sound like you need a new rear bearing and a spin support shaft
May 01, 2009 | Washing Machines
GE Top load washer 15years old. noisy when spinning
washer making a load cluck noise when the spin cycle starts.
It only happens when the motor turns slow for the first minute during the spin cycle. Otherwise it works fine.
if the motor is proper then the bearings in the motor got rusted and that needs replacement.the beasrings are located on the back of the motor.
Apr 03, 2009 | GE WVSR1060A Top Load Washer
Noisy cycle and dirty dishes
Hi
If your dishwasher seems noisy, check these:
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
Please accept the solution and revert for any further assistance.
Thanks
Rylee
Mar 25, 2009 | Kenmore 24 in. 17362 / 17364 / 17369...
Whirlpool Duet GHW9150P Front Load Washer Logo
749 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
