Question about Nintendo Wii Console
Internet isn't working right. Say error code 51030
  • 135 Answers
Error Code 51030, 51031, 51032
    It appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
    • Change your wireless router's channel to 1 or 11
      Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
    • Where is your wireless router located?
      Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
    • Look for other devices
      Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies.
Posted on Mar 20, 2011
piyush dixit
  • 136 Answers
SOURCE: cant connect to the internet
If you are getting this error after completing a system update, this is usually because the console resets to using the first connection slot after an update. There are two things you can do:
If you know which connection file you were using before, you can select that connection file, then select "Use this connection" to change that to the default. You will need to do this each time they download an update.
If you don't know which connection file you are using, or if you would prefer not to update the active connection file each time, try to clear, and then re-create your connection setting in slot one before doing the remaining troubleshooting
Check for interference that may be successful connection.
Thanks,
Posted on Nov 17, 2009
  • 85 Answers
SOURCE: connection to internet error code 51030
Do the internet connection test and see if it has a problem, if it does, then reset your wii internet again and it should work fine. This can occur rarely. Hope that helps.
Posted on Jan 19, 2010
  • 6 Answers
SOURCE: how do I connect to the internet to use the
Go to Wii Options in the lower left.
Click on Wii Settings to the right.
From this first list, click the right arrow.
Now on page 2, click on Internet.
Then click Connection Settings.
From this list, click Connection 1.
Then, click Wireless Connection...
and then click Search for an Access Point.
It will briefly search for any access points and when this screen comes up, click OK.
The following will be a list of nearby access points. If the one you are looking for doesn't show up, click Try again.
Then, click the one you have access to...
click OK once you've selected your connection, it might ask for a security key if you have one set up.
it should test the connection.
If this is the first time you've connected your Wii, it will most likely update your system
Posted on Apr 16, 2010
  • 839 Answers
SOURCE: error Code:51030 Unable to find an accesspoint.
most efficient and best way is to download all the repair guide and keep it in our system, we can use this for our personal future use...
click here to download repair guide
Posted on Dec 15, 2010
clrvuedoc
  • 175 Answers
SOURCE: trying to hook up netflix through the wii console
It is an internet problem. Check out the forum for a solution.
Posted on Mar 13, 2011
Netflix connection error code 51030
if this is on a wii that error code means no internet connection check your wireless settings
Sep 09, 2011 | Computers & Internet
Why is 51030 coming up why im trying to get on the internet on my wii.
Sorry to hear you are having problems with your wii. According to Nintendo, error code 51030 is:
"Error Code: 51030Unable to connect to your wireless network"
Make sure your wireless network is set up correctly with the correct SSID and encryption key. You may also just need to power cycle your router.
For more information, here is the official support article from nintendo for this error:
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51030&system=Wii&locale=lang
Apr 29, 2011 | Nintendo Wii Console
51030
"Error Code: 51030
Apr 27, 2011 | Nintendo Wii Console
Error code 51030 keeps on poping up
Error Code: 51030 (unable to connect to your wireless network)
Check this link -->http://www.nintendo.com/consumer/
Feb 19, 2011 | Nintendo Wii Console
Trying to hook up to are nintendo so we can get movies from netflix, ran at test got error code 51030 please let me know what to do if anything. thanks
The error code 51030 means that you have and internet connection error. Possibly caused by being too far from the wireless source, or your wireless settings on your Wii need to be adjusted. Here is a link to Nintendo's Customer Support to show you the steps to set up, or reset your wireless connection.
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=51330&system=Wii&locale=en_US
Oct 28, 2010 | Nintendo Wii Console
Connection to internet error code 51030
Jan 17, 2010 | Nintendo Wii Console
Error
http://www.wiierror.com/wii-error-51000.php
Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. This can potentially increase the download speed.
Jan 05, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
202 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
