Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
KP-51WS510 - picture is fine when set is turned on but goes solid red within a couple minutes. Is repair cost efficient? If not, what is best way to "get rid of" perfect looking 8-yr-old console TV? Give to church?
  • Sony Master
  • 8,617 Answers
Replace the RED CRT. You can get a replacement Red CRT from www.tvrepairworld.com cost around 100.00
Posted on Mar 22, 2011
Sony kp-51ws510 Rear Projection HDTV - Picture quality is fine, just doesn't have any red's in the picture. What shoud i look into?
Make sure the cable box or DVD/Blu Ray player is hooked up properly. Sometimes one of the component cables can become loose and lose the reds.
The red tube could be shot also. My old projection tv had the green go out. Believe it or not the whole thing can be replaced, but to replace a CRT on an older model can cost a lot.
May 18, 2012 | Sony KP-51WS510 51" Rear Projection...
My sony kp-51ws510 screen is red when turned on
This is one of a group of sets that had BAD picture tubes--all of them.
At one point the tubes were all being replaced under warranty for the first two years. Now the tubes are only available on a rebuild basis and very expensive--defective one has to be removed and sent out for this.
If the set goes bright red in your case it is the red tube and the set is shutting down as the set detects way too much current is being drawn by this.
There is a way to TRY to adjust to compensate for this that requires no replacing of any parts. Essentially what it involves is getting at the point of adjustment from the front of the set.
If you are interested in the instructions reply to this posting and I will be happy to post them here for you----no soldering or replacement of parts is involved and you will know in fifteen minutes if it will help you or not.
I have been fixing sets for well over 30 years and have done this adjustment several times---it may if it works just buy you some more life out of the set as ALL three tubes eventually have this trouble.
Let me know if you want the instructions and I will provide them here.
SD TECH
Apr 30, 2010 | Sony KP-51WS510 51" Rear Projection...
We hare red shadows off to the side of objects in the pictures. When you turn the power off, it corrects itself and then about 2 minutes later it goes back to the shados.
Convergence is dead.The 2 convergence ICS is dead.Must replaced 2 convergence ICS to solved this problems.Tries Websites Tv repair World.com,Tvrepairkits.com to repair it ur seslf,If u know how to solders.The shop will cost u $300 for parts and labors.
Feb 13, 2010 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51 in. Rear Projection Keeps blinking 5 times. The red and green projectors are working fine, but the blue is not working. Sears service replaced the power supply, and the first board, then...
You may want to recheck your connections coming off the blue tube to the board. Also check the IC links/Pico fuses on the power board. I have a repair manual for this Tv if you need it. shanesebay304@yahoo.com
Dec 10, 2009 | Sony KP-51WS510 51" Rear Projection...
On our Sony KP-51WS510 projector television (with HD cable box) when we turn it on the screen goes green and the turns the cable box off and goes blank. Also I noticed the light on the front of the...
when it goes green, your green picture tube is shorting out, replaceing the green tube costs alot of money. these sony's had alot of bad tubes, the red and blue are probably going out too, it will cost alot to fix this, at least $500 even if you find good used picture tubes to put in it.
Sep 19, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony 46" rear projection LCD HD - picture and sound go on and off
personally i would call a tv repairman out to fix the set.you can get alot of different opinions on here about what it may or may not be but the best thing to do is call a repaiman and let them fix it
Jan 27, 2009 | Sony KP-46WT500 46" Rear Projection...
No Picture / TV screen RED
There seems to be a dry solder joint on the video amplifier IC. The red picture is cause by a defective video amplifier IC(IC701) that is located on the red CRT assembly.
This repair might not be a DIY due to the danger of working around devices that produce high voltages in excess of 32KV.
Let me know if you need further assistance.
Jul 15, 2008 | Sony KP-51WS510 51" Rear Projection...
Screen went blurry 20 minutes later no picture no sound just red flashing light on front
These sets had bad welds in the gun assemblies of the picture tubes. Now, one of the tubes has failed (shorted) and the cost would be too high to replace all three.
Mar 02, 2008 | Sony KP-51WS510 51" Rear Projection...
Red Shadow
UNDER THE FRONT DOOR PRESS THE BOTTOM BUTTON "FLASH FOCUS" AND SEE IF IT FIXES IT. IF NOT AND YOU SEEN RED DOUBLE OF THE IMAGE, THEN THE SET PROBABLY NEEDS THE CONVERGENCE CIRCUIT REPAIRED.
DON.
Feb 01, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
42 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
