Question about Galaxy Technology Galaxy 43GGS8HX3SPZ GeForce GT 430 Video Card - 1024MB GDDR3, PCI-Express 2.0, DVI, HDMI, VGA Direct...
I just installed the Galaxy GT 430 video card in my Dell inspiron - 531. I have a monitor connected to the VGA and another monitor connected to the DVI connection. My computer is not showing that I have two monitors connected. How do I fix this? Thanks
  • 11,800 Answers
You need to enable the second one from Control Panel>Display>Settings. In there select which one will the the default one and the correct resolutions.
Posted on Mar 23, 2011
2 monitors installed, Each works well independently. when attached to this card, it boots off monitor 1 then after win 7 logo shuts off monitor 1 then monitor 2 takes over. Cannot use dual monitor feature?
Posted on Mar 26, 2011
Driver download
drivers are avaliable on the nvidia website
Sep 16, 2013 | Galaxy Technology Galaxy 43GGS8HX3SPZ...
Can't install drivers for GeForce GT 430. "Graphics Adapter Not Found."
I am assuming that your PC is working alright connected to the onboard graphics port.
Make sure any supplementary power connectors to your video card are in place, and the card is firmly inserted into the PCIE slot.
If you try these two items with no results, you might try installing the card in a known working PC. It could be a problem with the card itself.
Mar 24, 2012 | PNY GeForce GT 430 Video Card Bundle
My main vga monitor has no signal until windows starts loading, but my secondary connection (hdtv) has signal as soon as i power on my pc. If i need to change my bios settings then i need to have my tv on...
It looks like you have your TV set as your primary display, you will need to open up control panel to change this. I'm assuming you're using Windows 7 (the process should be similar for Vista and XP).
Open control panel > Appearance and Personalisation > Display, and choose the "Change display settings".
There should be a button that says "Detect" or "Detect Displays". Click this button. You should see something like this:
http://dl.maximumpc.com/galleries/dualmonitors/Win7_ScreenRes.png
Click the icon which corresponds to the monitor that you want to make you primary display (the boxes numbered 1 and 2 represent your two displays). Since you have yours the wrong way round, you should click box 2. If any check boxes come up saying "do you want to make this monitor your primary display, say yes. You should then have your monitors the right way round.
Jun 03, 2011 | Galaxy Technology Galaxy 43GGS8HX3SPZ...
I Have a Dell Inspiron 1525 and tried to add a 21.5" Dell Monitor. The color on the monitor was purplish, and even talking with the service techs, couldn't resolve the problem. They sent a second...
Your laptop's video circuit is integrated into the system board (motherboard). There is no VGA card. Try using a different VGA cable, if no go, then your motherboard has a problem.
May 20, 2011 | Dell Inspiron 1525 Notebook
I have a Galaxy GT 430 1GB graphics card and I installed into the PCIe x16 slot. But when I boot up my computer, it locks up in POST. I can see that my computer recognizes the graphics card because a...
If you had a graphics card prior to this one make sure all software from previous card is uninstalled. If you installed your card correctly, it should come up normally then, you can run your installation cd. If it is not coming up properly, see if you can start in "safe mode", go to "device manager", click on the box next to "sound , video, and game controllers", then click on your card and in the list make sure you see "disable". If you see "enable" click on that and exit, then restart. You should now be able to run your cd. If you had prior software and didn't uninstall before the install of new software, you may have to start over. After your original install from cd you can get all prior updates from Nvidia
http://www.nvidia.com/Download/index.aspx?lang=en-us
Apr 25, 2011 | Galaxy Technology Galaxy 43GGS8HX3SPZ...
Hello there. So you want to use 2 monitors at the same time? Well this is simple enough. Ok go into windows and right click your desktop. Go down to screen resolution. There is a dropdown there that will allow you to extend your display to 2 monitors. Select your desired mode from here and click apply. You should be good to go.
Mar 26, 2011 | Galaxy Technology Galaxy 43GGS8HX3SPZ...
Are there linux drivers for this card?
http://www.nvidia.com/object/linux-display-ia32-260.19.36-driver.html
Feb 21, 2011 | Galaxy Technology Galaxy 43GGS8HX3SPZ...
Have a Dell 531 Inspiron 4400+ Desktop with a Nvidia GEForce 6150SE. Would like to upgrade graphics card???
hello, according to wiki your Dell 531 is same as 530 except for the nvidia chipset.
ATI Radeon HD 4670 is recommended for this system without adding too much of extra burdun on the power supply.
rest also depends on how much are you looking to invest in a graphic card. below is link for newegg's graphic section:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=40000048&Description=pci%20express%20video%20card&name=Desktop%20Graphics%20%2f%20Video%20Cards
after you have the card follow this sequence(unless ofcourse you know excatly what to do)
1 go in BIOS and change graphic card priority from onboard first to PCI express.
2. turn off system install the new card, switch the vga/dvi cable to the new card and startup the system.
3. upgrade drivers with provided cd.
let me know if you have any questions.
good luck
regards
Amar Sondhi
Dec 06, 2009 | ASUS ATI RADEON HD 4670,, PCI Express...
I own a Dell Inspiron 531S. I'd like to get a new graphics card. I currently have a NVIDIA GeForce 6150SE nForce 430. I don't want to spend too much for this but I'd like to run my Second Life game with...
When you install a new video card you must disable the onboard video card by going into the bios setup. Below I have listed the requirements of Second life game. e 531 does come with PCI-E slots so make sure you buy a VIDEO card with PCI-E Walmart sells some pretty decent priced Graphics cards. pretty much any pci-e card you buy new in walmart these days will be fine for this game.
PC Minimum System Recommendations:
* Internet Connection*: Cable or DSL
* Computer Processor: 1.6GHz Pentium 4 or Athlon 2000+ or better
* Computer Memory: 512MB or better
* Video/Graphics Card**:
o nVidia GeForce FX 5600, GeForce 6600, or better
o OR ATI Radeon 9600, X600, or better
M
Jan 02, 2009 | Computers & Internet
Galaxy Technology Galaxy 43GGS8HX3SPZ GeForce GT 430 Video Card - 1024MB GDDR3, PCI-Express 2.0, DVI, HDMI, VGA Direct... Logo
457 people viewed this question
Top Galaxy Technology Computers & Internet Experts
David Payne
David Payne
Are you a Galaxy Technology Computer and Internet Expert? Answer questions, earn points and help others
