Question about Kenmore Dishwashers
Have a kleenmaid dishwasher Crystal dont know mod. no. Need a manual . Does'nt seem to be filling up. Really need copy of manual please help if you can, Jan
  • Kenmore Master
  • 43,501 Answers
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Mar 20, 2011
  • dave jc Mar 21, 2011
    http://www.tradebit.com/filesharing.php/...
  • Patricia Williams
    Patricia Williams Oct 30, 2013
    Manual is hopeless, Model of my Crystal is DW-1 N In case someone else wants to know...
Dishwasher faults
I'm not familiar with this type but if it has a circulating pump, it may be stuck through lack of use and causing the breaker to pop because it can't turn. Find the pump harness connector and temporarily pull it off, switch on and see if the breaker goes. If not then see if you can free the pump. Remember, electrical safety at all times! Electricity is the silent killer.
Jul 21, 2014 | Dishwashers
I need opperating instructions for my kleenmaid dishwasher dw20x
http://dish-washer.download-servicemanual.com/kleenmaid-dw20w-dw20x-dishwasher-instruction-manual.htm
Nov 22, 2012 | Washing Machines
Do you have a manual for the Kleenmaid DW20W dishwasher?
pushed on button. lights are on . Wont let me select settings . has 3hr delay light up . salt light on. pushed start button and nothing happens.
Dec 27, 2010 | Dishwashers
I have a kleenmaid dishwasher DW 19X. it is filling with water and then emptying the water . its not washing.. it is not doing the washing cycle.. i have tried all cycles. thanks sue and justin
Hi
Thanks for using FixYa. If the cycle doesn't complete, then the first thing that should be checked is the Timer and then the heating element. Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 06, 2010 | Dishwashers
My Kleenmaid dishwasher is stopping during the cycle and displaying fault D14, what does this mean
This is a Pump Filling Fault.
As described in your manual to download below. Could be the pump, the controller, the door sensor, a float switch stuck.
kleenmaid-appliances.com/DW/KM_DW/DW37i_B3097_C_EN.pdf
Below is a DIY self help site to assist you to isolate and hopefully repair your issue. If you do wish to DIY, then you MUST obtain a service manual for your exact make and model, simply Google for one. Follow troubleshooting steps inside to find the problem.
Sometime under the inspection hatch, you may find a maintenance manual, in a plastic bag, not always though.
http://www.acmehowto.com/howto/appliance/dishwasher/dishwasher.php
If you don't wish to DIY, then please call a professional, ask for a "Quote" and go from there.
Aug 30, 2010 | Dishwashers
Dishwasher will not start cycle.
OK so you have power, your door interlock switch is working, the intake solenoid is operating.
The issue is that the cycle does not start. This would indicate that your timer is not advancing. The timer tells the machine what to do, when, and for how long. It is not advancing and is stuck at the start of the wash cycle (fill with water). This is not a big issue as a timer is usually easy to replace.
I don't know what type of machine you have so I don't know if is a mechanical or a digital timer.
If mechanical dial type you can simply tun the dial and see if the cycles change. If so for sure you timer is the issue. You simply remove and replace.
Digital is harder to check but from what you say it is most likely your timer.
Shut the breaker off.
Remove the screws from the door frame and from inside the door. Gently remove the control panel. The timer is a simple unit to remove. Unscrew it and disconnect the power supply. Go get a new one from your local parts supplier. Installation is the reverse of removal.
Hope this helps, if so please rate this answer.
Mar 20, 2010 | Dishwashers
Speed queen washing machine mod kaw693 repair manual reqired
do you know where I can obtain a repair manual for my Kleenmaid KAW693 I need to replace the seals and bearings as it leaks a bit of water and makes a screeching noice when agitating. My email address is kerryn12@optusnet.com.au Thank you
Apr 28, 2009 | Speed Queen AWS52NW Top Load Washer
Kleenmaid DW3 dishwasher not running.
Hello, this isn't a fix, but if you can't get the dishwasher fixed, I am interested in purchasing the cutlery baskets off you, if they are still in reasonable condition. Mine has plenty of breaks in the base and the handles poke through, which affects the lower spray arm rotation. Please reply through another post if you're selling. Thanks.
Jan 01, 2008 | Dishwashers
Keeps flashing clean Kenmore dishwasher 665.17019401 need a new owners manual
i was trying to install my kenmore elite 665 dishwasher but i cant find the plug do they come with one? or were do i hook it up?
Sep 22, 2007 | Dishwashers
Dishwashers Logo
454 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
