Question about Sanyo Refrigerators
I need a THERMOSTAT KNOB for a sanyo SR1286-1 - the one place I found in yur solutions, said it is discontinued. The refrigerator works perfectly, but unfortunately when defrosting, I did NOT wait long enough, tried to turn the dial to OFF and it snapped off. My email is: dialouky@insightbb.com. I have been looking everywhere on line for weeks now and just came across your website. Thanks.
  • 1462 Answers
SOURCE: Defrost problem diagnosis
you will need a multimeter. check continuity thro the heater and stats mounted on the evaporator
Posted on Apr 08, 2007
  • 87 Answers
SOURCE: Refrigerator
Have looked at the schematics for this cabinet and am unsure as to the location of both defrost thermostats as unclear on drawings. The purpose of the defrost thermostat is to overide the heater and end the defrost cycle, once the temperature on the evaporator is high enough (normally around 0'C). If you have two then one will probably control the heaters going off and the other may well control the fan, for coming back on. I.E. once the defrost has ended the second sensor will tell the fan when the coil is cold enough to come on, this prevents heat being pushed into the main area after a defrost cycle. If you feel competent enough then I would bypass the heater thermostat temporarily and see if the heaters kick in. The other thing to check is that you have a resistance across the two ends of the defrost heater. In my experience the heater is the most likely to fail, the sensor sometimes fail and the timers rarely fail. The age of your cabinet would suggest the heaters. Please do not leave the sensor bypassed as it performs an essential role. Hope this helps.
Posted on Sep 05, 2007
aborcass
  • 2651 Answers
SOURCE: Amana defrost thermostat
hard to tell which but either on will work not critical
Posted on Mar 03, 2008
mikedurland
  • 481 Answers
SOURCE: Kenmore refrigerator 5260 not cold
  • the defrost timer on your machine is actually integrated within a control board/air diffuser. hopefully that is not the problem (expensive).
  • i would start by testing the heater and bimetal thermostat in the freezer. (note: the bimetal thermostat will only have continuity when below 40 degrees.)
  • the heat you feel between the doors is normal (if it is not too hot).
  • some of the heat that is released by the machine is intentionally released between the doors to prevent condensation.
  •  if it seems warmer than usual then you might need to clean the coils under the machine and make sure the airflow under the machine is not obstructed at all.
  • if the coils are dirty then they will not be able to release the heat properly and the heat will be released in other areas like between the doors.
Posted on Jul 18, 2008
jvernice
  • 63 Answers
SOURCE: magic chef refrig model # MCBR1000W defrost thermostat
RepairClinic.com is a fantastic online site for ordering appliance parts.
Posted on Jul 29, 2009
Why imperial fry over heat
Replace the thermostat. Not an uncommon problem. Although there is an adjustment if you remove the thermostat knob and look in the hollow knob shaft where you'll see a place for a precision flat head screwdriver, I have generally found that if the thermostat was working properly at some point, the problem is rarely fixable by adjustment.
Sep 04, 2014 | Imperial Kitchen Appliances - Others
Sanyo mini refrigerator continually runs
Check the door gasket to see if it seals correctly.
Aug 09, 2017 | Sanyo 4.4 Cu. Ft. Compact Refrigerator -...
How to remove and replace Thermester
If you discover that your refrigerator is not getting cool enough or not cooling down at all, then it is perfectly possible you may need to change your refrigerator thermostat. If you wish to test the thermostat to make sure whether it is working or not, then you should change the refrigerator temperature to something a bit cooler than normal. If the thermostat is working okay then it will take a few hours to maintain a steady temperature. However, if it doesn't then it will need replacing.
Step 1 - Preparation for Replacing Thermostat
The first thing you should do before undertaking this work is to turn off the appliance from the mains. This is something that should be done with all appliances of an electrical nature for safety reasons. If you find that the plug is hidden away behind cupboards or panels then you should turn off all the power to the entire kitchen.
Step 2 - Locate the Thermostat
Next you need to find the thermostat and where it is positioned inside the refrigerator. For the majority of refrigerators where they have a freezer on the top level, the thermostat will be right at the back of the fridge or on the roof of the fridge on underneath the freezer panel. If you have a refrigerator that is next to the freezer then the thermostat should be found in the freezer at the back.
Step 3 - Remove Shelving
Ensure that you take out all frozen food and shelves that are in your way that many prevent you from working on the job with plenty of space to move about in. In order to take out some of the shelves on the inside you may have to make a few screws loose and take out clips holding it in place.
Step 4 - Remove Wires
There will be some wires that are attached to the thermostat and these need to be pulled away gently using the pliers. You should make sure that you are extremely careful doing this as if you pull too hard or grip the wires in the middle then they could break under the pressure.
Step 5 - Take the Broken Thermostat Out
You are now in a position to take the old faulty thermostat out of the refrigerator after taking out the remaining screws and clips. If the thermostat is around an evaporator tube then you should take care then removing as this may cause damage.
Step 6 - Install the New Thermostat
Once you have gone through all the steps, then you should put the new replacement thermostat in to the refrigerator in the same place as the old one. Ensure that you screw it into place and reconnect all the wires. Ensure that when you have done this and put the panel back on to the thermostat that it is secure. Next put back any shelving you took out before replacing the thermostat.
Step 7 - Test the Refrigerator
Finally, turn the power to the refrigerator back on and then wait for the refrigerator to cool down again to a lower temperature. If the new thermostat is working correctly then it will kick in and maintain a steady temperature within your refrigerator.
I hope this will help in solving the problem....
May 17, 2011 | Dometic RM2652 Refrigerator
The refrig motor starts but the refrig is not getting cold.
Hello,If the refrigerator is not getting cold, you need to answer some question.
1. check if the compressor is running.
2. Is the thermostat knob turn to the proper setting?if not reset it. then see if the compressor motor is running. The compressor is a football-sized case with no apparent moving parts,it's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of these components.
1. The compressor
2. Thermostat
3. The overload, relay, or Capacitor
4. The defrost timer
5. The condenser fan motor.
Thanks
Jun 21, 2010 | Sanyo 4.4 cu. ft Counter-High...
My refrigerator only kicks on when I adjust the temp knob.
You need to replace ( or have it replaced ) , the thermostat . The piece the knob pushes onto . The liquid is seperated inside the thermostat cap tube , causing the internal contact not to close . Also , a tap on the knob , will start the refrig , until it reaches temp , but then may not restart until another tap . Replace it and that will solve the problem .
Apr 20, 2010 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Freezer thaws then refreezes
I was going to suggest that maybe it is a self defrost issue not shutting off when it should but sine you mentioned this knob, it suggests a thermostat out of calibration - I can rule out circuit problems since you can manually turn on compressor by turning the knob to a cooler position - you will need to have it serviced and change the thermostat which is not cycling whne it's supposed to.
ALSO - do not refreeze foods in your freezer that have thawed ! Throw them away !!! Normal freezer temps should not be warmer than 10F, the normal temps are 0F, and optimal recommended temp -10F (for hard ice cream) and to allow better recovery in case of power failures.
Refrigerator section no warmer tan 40F.....optimal recommended 34F.
Oct 02, 2009 | Amana 22.6 cu. ft. Side-By-Side...
The refrigerator ignores temperature setting.
Hello, This problem is going to be the cold control/thermostat, this part can be located in the control console inside the fridge bhind the freezer temp control knob (can also be found sometimes in the freezer depending on type/model) The reason your food in the fridge is freezing is because the thermostat controling the freezer temp is not shutting down and the air being blown into the fridge is too cold. Replace this cold control/thermostat and you should be fixed. If you have any other questions or concerns please feel free to comment again and give me some time to respond. Good luck! Mike
Sep 08, 2009 | Kenmore Refrigerators
My Kitchenaid refrigerator light works, but nothing else runs.
Sounds like someone turned the thermostat off. It's like it is sitting at the appliance sales place on the showroom floor. Try turning unit on with the knob inside the unit. If this does not make it come on. You will need to replace that part. It will be your thermostat
Please rate solution
Sep 07, 2009 | KitchenAid Refrigerators
Need a replacement door gasket for compact fridge Sanyo SR1286-1
Here is a link to get exactly that Sanyo SR1286-1 door gasket. It says Panasonic on the page but it fits perfectly. O know, I bought one!
SR1286 1 Sanyo
Jun 03, 2009 | Sanyo SR-4310 Compact Refrigerator
Need to repace a knob on a colmans water heater
I've just done that. The shorter leg of the spring must go into the knob. You will see two thicker mouldings in the knob where the spring fits ...v shape. The longer side of the spring goes between the two raised bits on the insert to the knob. The insert can only go two ways and the depressed portion must be at the top so that it is not pushing the micro switch in the off position. Assemple the knob, spring and insert before screwing to the unit.
Mar 18, 2009 | Coleman Hot Water On Demand
Refrigerators Logo
65 people viewed this question
Top Sanyo Refrigerators Experts
John Tripp
John Tripp
christian nielsen
Are you a Sanyo Refrigerator Expert? Answer questions, earn points and help others
