Question about Frigidaire Washing Machines
My Frigidaire Crown Series top load washer was agitating but would not spin. It did drain the water. The lid lock did lock when it was in the spin position. It was smelling like burning belt so I replaced the belt. It did not fix it. The rod poking out the top of the motor that is connected to the metal circular thing that the belt goes around (sorry about the wrong terms) spins but does not turn the belt. I can turn the belt and drum either direction. I would appreciate any help.
  • Melissa Martin
    Melissa Martin May 04, 2014
    I need your model to help you out properly. Thanks
  • Frigidaire Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Mar 20, 2011
I have a frigidaire washing machine and it spins out just a small amout of water during the cycle, not a lot , have checked the pump and it works, just wondering if it could possibly be the lid lock
It would not agitate if it were the lid lock, just as agitation should stop when you open the lid during cycles. More likely it's something blocking the drain hose. Here is a link to an excellent online repair manual. Click on the picture of the wash machine, then go to chapter 2. Then have a look at Section 2-3.
http://appliancerepair.net/washing-machine-repair-2.html
Sep 13, 2012 | Frigidaire Washing Machines
Will not agitate or spin, does fill with water. Just happened. GLWS1233A Frigidaire top load
I replace a new solenoid, I started to get my cold water but then, I replace a new lid lock and it stop agitating. Could you please help me.
May 16, 2011 | Frigidaire GLWS1233A Top Load Washer
My kenmore series 70 will not spin or drain the water out
open your washer put a screwdriver in the lid switch hole set the machine on spin tell me what happens be careful the tub should spin out the water
Apr 30, 2009 | Kenmore 23822 Top Load Washer
Washer agitates, drains OK, but spin doesn't start
Timer is defective. Your unit has a netural drain. When finished agitating, the shuts down and then starts up reversing to drain and spin. On the initial reverse start, the water drains without the transmission spinning. After a timed period 3-4 minutes, the timer is supposed to pause, stopping the motor for a few seconds. When the motor stops again, the transmission shift to the spin cycle and when the timer resumes power tothe motor it should spin. You are doing the same thing when you lift the lid...stopping the timer and then the tranny shifts and when you set the lid down, the washer spins. Replace the timer.......
Feb 09, 2009 | Kenmore 23822 Top Load Washer
My fridgidaire washer fillw with water and agitates but it will not spin or drain.
YOUR LID SWITCH IS BAD,POP THE TOP FIND THE WIRE JACK TO SWITCH CUT BOTH OUTSIDE WIRES,WIRE NUT THEM TOGETHER,MADE SURE YOU UNPLUG MACHINE FIRST,YOUR MACHINE WILL NOW WORK BUT WHEN YOU LIFT THE LID ON FILL OR SPIN IT WILL NOT TURN OFF,SO KEEP YOUR HANDS OUT OF THERE,THE LIP SWITCH CONTROLS FILL AND SPIN,THANKS-MIKE
May 29, 2008 | Frigidaire FEX831CS Top Load Stacked...
Washer problems
if it wont drain , check your lid switch, check out your motor coupler, if it will not agitate and spin, replace your motor coupler, if it agitates and dont spin, replace your lid switch.
alot of times the washer will drain but we hurriedly cut it off when we hear noise or the water is out but it never spinned and so the clothes are soapy wet...
Nov 12, 2007 | Roper RAX7244KQ Top Load Washer
Kenmore 70 Series Washer
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Washing Machines Logo
497 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
