Hi!! I have a Westinghouse L1916HW 19" DVI LCD 2ms
  • 11,361 Answers
One possibility is that it may have dying power supply which may be putting out unstable DC which can cause a lot of strange symptoms.
See pictures here: http://s807.photobucket.com/albums/yy352/budm/Westinghouse%20L1916HW/?action=view&current=DSC00244.jpg
Bad caps are real common problems in all brands of the monitors as you can see in my albums.
Westinghouse monitors are cheaply made to start with.
Posted on Mar 20, 2011
Testimonial: "Sir!! Thanks very much for your help and I want to tell you that the problem with my monitor is done. I replaced the caps and my monitor is worki"
  • 2 more comments
  • Rodrigo  Arias Salazar
    Rodrigo Arias Salazar Mar 20, 2011
    Thanks you very much for you help!! I will check its , and I will let you know the result.
    Now, do you have pictures about how open the monitor cage , because I tried day ago but I could not. jeeee!!
  • Bud Martin
    Bud Martin Mar 20, 2011
    I use thin flat blade to crack it open at the bottom edge and then lay ut fase down and pull back on the cover to snap it open: http://s807.photobucket.com/albums/yy352...
    The metal box where the power supply is taped down with aluminum tape, you need to make the location of the box so you can tape it back down, otherwise you may not be able to put the cover back on, like I said, it is really cheaply made and they try to save money by not using screws!
    Rodrigo Arias Salazar Mar 22, 2011
    Sir!!
    I replaced the caps and my monitor is working without the problem.
    I changed the all caps from converter board. I used the same uf valor but with more voltage on each cap.
    And the best, I expended just $6.
    Again, Thanks very much for your help and have a great day
  • Bud Martin
    Bud Martin Mar 22, 2011
    That is great and thank you posting the result which I am sure it will help out other peopel also.
Why is my screen green?
you may change the connection cable
Aug 18, 2015 | ASUS VW246H 24 Widescreen LCD Monitor,...
Have the L1916HW monitor and it has started popping up the menu screen randomly, and as of today it has turned itself off twice.
today is our locky day!! I found the answer, please take a look on this web http://s807.photobucket.com/albums/yy352/budm/Westinghouse L1916HW/?action=view ****************************************************** http://www.aplusperfect.com/articles/lcd_capacitor_repair How-To Repair a Desktop LCD with Bad Capacitors January 17, 2008 By Jeremy Brock
Desktop LCD monitors fail for a variety of reasons, the most common being bad electrolytic capacitors. If you are willing to invest the time you can fix your LCD for a few dollars in parts. For this demonstration I'm using an IBM ThinkVision 6636-AB1 however the same techniques apply to most desktop LCD Monitors.
Disclaimer:
A+ Perfect Computers, LLC, is not responsible for any damages to your device, person, or property. Computer, Laptop, or LCD disassembly and part installation is at your own risk. This Guide offers only suggestions for taking apart your device. The components inside your device are highly sensitive. Always ground yourself by using an ESD wrist strap or by touching a metal object while handling sensitive electronics.
    Symptoms:
  • No Picture on Screen
  • LCD displays picture briefly then turns off
    Tools:
  • Soldering Iron
  • Desoldering Station or Solder ******
  • Phillips Head Screw Driver
  • Spudger (Available Here and Here)
Nov 25, 2010 | Westinghouse Electric L1916HW 19" Monitor
Hello i have a 19'' white westinghouse lcd computer monitor and it all white, is there anything i can do, i have already checked the green board and capacitators and what not and eveything tested fine, is...
chapp29, You didn't tell me the brand name of the electrolytic filter capacitors that are on your monitors "switch-mode-power-supply / cold-cathode-fluorescent-lamp-ballast" circuit board. How did you measure (check) the capacitors? Are any of the rubber seals pushed out of the bottom of any capacitors? What is the "date of manufacture" of this unit? Will L1916HW work connected to a different "known-good" pc? Will "known-good" monitor work ok when connected to your pc? 12fixlouie
Sep 15, 2010 | Westinghouse Electric L1916HW 19" Monitor
My montor is going green in place how can i fix it
move the speakers away from it the magnet is pulling the color out of the screen :)
Jan 27, 2010 | LG 19 Widescreen LCD Monitor, 1440X900...
I just rebuilt my system, and I don't have a CD to install the monitor
Usually the monitor manufacturer has a support section on their web site with driver downloads.
Dec 28, 2009 | Westinghouse Electric L1916HW 19" Monitor
The monitor turns on briefly humms and then turns off. Any ideas? Westinghouse L1916hw
Sounds like a bad inverter. Does the screen still show that the power is on? If so, then shine a bright light at it. If you can still see the image, then you have your answer.
-=/ Daft Tech /=-
Oct 23, 2009 | Westinghouse Electric L1916HW 19" Monitor
Westinghouse L1916HW Monitor On-Screen Display keys malfunction
Hi!! I have a Westinghouse L1916HW 19" DVI LCD 2ms Widescreen Monitor and it turns itself off . Sometimes it works without problem for long time or just for 15 mins, and after turn on it several times the problem disappears. Now,when it is working without the problem, sometimes the volume menu appear on the screen without touch the monitor and if you try to close it, appear again.. I am using it with Windows 7. I need help. Now, I have a router wireless close to it, Can it affect the monitor?
Dec 14, 2008 | Computers & Internet
Computers & Internet Logo
733 people viewed this question
Alun Cox
David Payne
David Payne
