Question about Chauvet Intimidator 1.0 Dmx-600 512 Scanners
Internal fuse blew and is soldered in and I can't read what is the voltage and amperage of the internal fuse on the circuit board?
  • Chauvet Master
  • 5,603 Answers
The ratings are normally stamped into the end caps of the fuse. Sometimes they are a bit hard to see. Make sure you repair the cuase of the failure before replacing.
Posted on Mar 20, 2011
My Yamaha electric piano, P80, will not power up
first - check the power supply if it's really giving power.
Get voltmeter or plug it to something else you know it's working.
If you are sure it does and still nothing, you need to check the fuse inside the P80. I've been there, it's not so hard to open it
(from below of course)
BTW, it's advisable to user surge protector on such delicate devices like computers and keyboards if there are any fuses that have blown. I can't tell you how many times a blown fuse has stopped equipment from working. I had a blown fuse go in a microwave oven a few years back. I called a repair guy while on a job to fix my Leslie (many years ago) and the culprit, a blown fuse. I could have fied it myself if I had given it more thought.
Check the internal fuses first and you might save some money and a trip to a repair center. , sometimes a fuse can look good even when it is blown. If you have a voltage tester do a continuity check on the fuse just to be certain.It's possible that the P80 does not use internal fuses especially since it uses an external 12 volt power pack There might be info on the fuse in the P80 manual. Otherwise try Yamaha support. A lot of low volage gear run of AC adaptors is unfused.
Another possibility is that the power connector or switch on the P80 is broken. DC power jacks are liable to get broken solder joints due to movement, especially if they are circuit board mounted and not chassis mounted. If you know what you are doing test the connector and switch with a multimeter.
If they are good then also check the wires from the switch to the main board. They a probably connected with a plug, which itself can come lose.
You can test for bad connections with the power off. Only test with the power on if you really do know what you are doing! You won't electrocute yourself but you can easily damage the keyboard if you are not careful.
Unless you are experienced in electronics repair that is as far as you should go.
Oct 23, 2017 | Yamaha Music
Model Yamaha ME-50 no power
John
With AC power off.
Use a meter (on Ohms scale) to check internal fuse for blown (open) fuse.
If you feel qualified & safe with AC Power On.
Check input to internal power supply on AC Scale (Caution when AC is on) for volts in.
Use meter on internal Power Supply for "probably" DC volts leaving internal Power Supply electronics to power the rest of the electronic circuits.
Switch mode power supplies can break down. They stop doing their high frequency switching so they don't convert AC to DC.
If this P/Sup is a separate box or circuit board, inside the unit, then it can have a part number & be replaced.
Good Luck
Jul 14, 2014 | Yamaha Music
Wont turn on. even with new battery
Presence of the inout guitar cable enables the unit to turn on. If the cable is present, and it won't turn on, the problem is likely internal. Cracked circuit boards and broken solder joints, especially at connectors are common.
Aug 27, 2011 | ProCo Rat2 Rat Distortion Pedal
Elation DP-DMX20L will not power up. Not sure if it is the internal fuse or if it is something else. Please help.
There usually are no internal fuses in these. Open the unit watching out for buttons that may fall out of the cover. OFTEN the problem will be visible like a loose wire/broken solder. If the logic circuits are working and the display is lit, often the problem is blown Triacs that control the output receptacles. These are usually 600 volt, 16 amp Triacs.
Aug 04, 2011 | Elation Dp-dmx20l 4 Ch Dmx Dimmer Pack...
The fuse blew, can't read what the ampage is
This doesn't compute as there is no fuse external to the unit and it runs off a 12 volt wall wart supply. The supply is 500ma or more. Any INTERNAL fuse would probably be rated at that or slightly higher like 650 ma or even 3/4 amp. If the internal fuse blew it was for a reason... using wrong adapter probably would do it... Other than that take it to a competent repair shop as the fuse will probably blow instantly again. This appears to take 12 to 20 volt 500 ma minimum wall adapter with CENTER positive, unlike many devices. If you put wrong polarity adapter that would probably blow the fuse and MAYBE another component.
Apr 26, 2011 | Elation Stage Setter 8 Dmx Controller
I recently purchased an Orange AD5 amp. It came to me dead so the store I bought it from told me to try to change the fuses for this amp is becoming rare and hard to get. I replaced both fuses with the...
Check for burned components, broken wires or cracked insulation on wires. Inspect the tube sockets and circuit boards for carbon tracks. Next, check the power supply rectifiers for shorts.
If you don't find anything, pull out all of the tubes (be sure to document where each tube goes!) and see if the fuses still blow. If they don't, one of the tubes has an internal short. (If the fuses blew only after warm-up, it would be an overload on a tube rather than a short through the tube.)
If this was a solid-state amplifier, I'd suggest checking the audio output driver transistors - this is the most common fuse-blowing failure in those.
Feb 13, 2011 | Orange Amps Orange Amplifiers AD Series...
Fuse blew out on my american audio after my girlfriend tripped on the chords, how do i repair it . is there a fuse or a reset button thank you
You are saying the fuse blew out and then asking if there is a fuse??? That makes no sense...
Tripping on cords could do certain things but NOT likely to blow a fuse.
Tripping on cords OFTEN breaks the plugs on the cords or the jacks in the equipment. The power input jacks from those wall transformer power supplies seem to be very vulnerable to this. They often disintegrate OR break loose from the solder on the circuit boards rendering the unit inoperable.
In future, loop the cords through handles so they don't yank the jacks if somebody yanks the cord.
Dec 26, 2010 | American Audio CK 800 MP3 CD PLAYERS SOUND...
How do I replace a fuse on a Marshall DFX 100, where is it located?
The fuse would be internal. The fuse blew for a reason, and unless you had an accident with the amp such as shorting a speaker lead, there is likely internal damage requiring servicing. Replacing the fuse without curing the original reason it blew will likely cause damage to further components.
Take the unit in for repair.
Sep 06, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
I have an Epiphone Blues Custom 30 amp. I have had it about 2 months - purchased used. I have probably played it about 10 hours total. This morning, I turned it on and it played for about one minute then...
There may be an internal fuse, but the unit will need to be serviced by an electronics shop.
If no odor or burning smell happened, then I suspect a bad solder joint or cracked circuit board. Look the board over with a very bright light.
LOOK for a dark circle around pins of HEAVEY components in the solder menicus for all the pins of the heavy components.
Look for board cracks with a small LED flashlight shined through the board.
Feb 28, 2010 | Epiphone Music
Convert a Behringer BCF2000 to run on batteries?
The basic unit requires 10 watts at line voltage. Modifying the unit internally would be a disaster. You are better off using an invertor to drive it.
The internal supply will be a switching type and probably generate +/- 15 volts and +5 volts.
Feb 01, 2010 | Behringer Music
Chauvet Intimidator 1.0 Dmx-600 512 Scanners Logo
123 people viewed this question
Top Chauvet Music Experts
Michial Gueffroy
rhodesworks
James Kovacs
James Kovacs
Are you a Chauvet Music Expert? Answer questions, earn points and help others
