Question about Kenmore Elite 45986 Front Load Washer
My washing machine keeps stopping mid cycle. It flashes the numbers F 11. Do I need to have a technician come out? What might the problem be?
  • Kenmore Master
  • 2,694 Answers
I just worked on a washer with the same problem,had to replace the central control unit or ccu,unfortunitly it also could be the mcu motor control unit,with all this computer stuff it's hard to know what part it actually is,some places tell you to change both parts for this problem,i noticed that there was alot of clicking sounds coming from the top of the machine from it trying to communicate with the other components when the code came up so i changed out the ccu and it took care of the problem,if you send the model number i can look up your machine for you or call your parts store,give them the model number and they will sell you the correct parts.just take your time when changing out the ccu,mark the connectors or make a diagram,there's alot of wires but if you mark them you'll have no problem,i'm gonna look up a site and send it to you and hopefully it will help you out,one more thing with front load washers,i've found that if you use more than 1/4 cup of H.E. detergent you'll have problems with the spider gear,it's in the rear of the tub,using to much detergent eats at the gear and when it goes you'll know it,it gets very loud in the spin cycle like the machine is going off balance and the tub makes a slaming sound,just keep that in mind
Posted on Mar 20, 2011
  • Sal De Mar 20, 2011
    Whirlpool Duet / Kenmore HE3/4 Washer: F11 and FH Fault Codes | Washer Repair | Fixitnow.com Samurai Appliance Repair Man ............copy this and paste it up to the periods,hopefully this will help you out,good luck,if you need anymore help let me know.
    Sergeant:
  • 170 Answers
F 11 is slow drain/remove lower kick plate screws at bottom/pump is behind it remove cleanout from pump counterclockwise turn/you will get some water so lay down some towels put back togeather test ..now you can spend the 100.bucks on something more usefull LOL.. good luck thanks for voting...
note the cleanout is in the front of the pump...
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Machine keeps stopping between cycles, turning power off wall for hour seems to reprogram and start machine to next cycle then stops again
It sounds like an 11 series machines,
When power supply gets warm it stops.
You will need a technician to fix the power supply in the brown board.
Mar 27, 2012 | Fisher Paykel Eco IWL16
Machine stopping mid cycle
Count the number of green flashes(1st number of error code). count number of red flashes(2nd number of error code).
Common codes are:
E10 or 11 water pressure faults.
E20 filter/pump faults.
E30 pressure switch/heater faults.
E40 door switch faults.
E50 motor faults.
E60 Heater faults.
These are some of the error codes but there are many variations on some codes depending on the model.Hpoe this has been some help.
Apr 24, 2010 | Zanussi ZWF10070W Front Load Washer
Stuck Mid-Cycle, Wet Clothes!!
unplug the machine for 15 minutes then try again
Jun 09, 2009 | Whirlpool GHW9150 Duet Washer
Washing machine timer stops mid cycle
Your lid switch needs replacing.
Part number 3949237 available at any applinace parts store.
Apr 05, 2009 | Estate TAWS800JQ Top Load Washer
i bought a new washing machine but thanks anyway
Jan 22, 2009 | Creda W100FW Front Load Washer
KitchenAid Washing machine stops mid-cycle and stays stopped
sounds like you need to replace your lid switch asssy part number 285671, unit not recognizing the door closed so for safetyreasons stops after first rinse and wont drain/spin. your tripping the switch by bangin on it
May 12, 2008 | KitchenAid KHWS01PWH Global Horizontal...
Kenmore Elite 45986 Front Load Washer Logo
43 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
