Question about Avanti Washing Machines
Replace drain hose - Avanti Washing Machines
    Sniper:
  • 68 Answers
The drain hose comes with a clamp that is used to clamp the hose around the plastic piece on the bottom of the washer. Some washers this connection is inside the washer, but it is still the same type of connection.
Please rate this solution
Posted on Aug 04, 2008
How to fix drain hose on LG WM2487H M
The following are a number of things to check for the OE (drain error) indication.
If the washer does not drain then the drain pump may be clogged, damaged, or defective.
Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Open the drain pump filter tray at the lower left of the machine and check whether it is clean, check also that the pump impeller spins freely. Remove the hoses from the pump and check for any obstructions.
First, check the drain hose to determine if it is kinked, twisted, or bent. If the drain hose is bent, straighten it out. In addition, remove the drain hose and check it for obstructions. If the drain hose has any obstructions, try to remove them. If necessary, replace the drain hose.
Check the machine's water level frequency by pressing the WASH/RINSE + DELAY WASH buttons simultaneously. Check the reading on the display, if it is below 260 (26 Khz) then have someone measure the resistance of the pump motor coil.
It should be between 10-20 Ohms resistance, if too high or too low, replace the pump assembly as it cannot be repaired.
Mar 08, 2016 | LG Washing Machines
Where are drains located on a 2003 chevrolet impala sunroof?
They go down inside front A pillar an inside rear D pillar . To get at them you need to take trim off an the headliner down .
Sunroof Housing Rear Drain Hose Replacement (Impala)
Remove the headliner. Refer to Headlining Trim Panel Replacement in Interior Trim. Remove the rear quarter lower trim panel. Refer to Rear Quarter Lower Trim Panel Replacement in Interior Trim. Disconnect the rear sunroof drain hose from the sunroof module rear spigot. Remove the tape from the rear sunroof drain hose tube.
Disconnect the rear sunroof drain hose from the rear sunroof drain hose tube. Remove the rear sunroof drain hose tube from the upper retainer clip. Remove the rear sunroof drain hose from the rear pillar
The front is simalier .
Dec 22, 2015 | 2003 Chevrolet Impala
I need to find the reset button. It will not drain. This has happened before but I can't remember where the reset button is.
Sometimes, small objects or articles of clothing can get caught in the drain pump. To determine if anything is blocking the drain pump, remove the drain pump and check the pump for obstructions. If the drain pump is clear of obstructions, but is still noisy during the drain cycle, replace the drain pump.Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Remove the hoses from the pump and check for any obstructions.First, check the drain hose to determine if it is kinked, twisted, or bent. If the drain hose is bent, straighten it out. In addition, remove the drain hose and check it for obstructions. If the drain hose has any obstructions, try to remove them. If necessary, replace the drain hose.
Jun 24, 2015 | Samsung Washing Machines
How do I replace drain hose
Do you mean the hose that goes to your standpipe, or the hose that goes from the drain pump to the plastic box(26) behind the washer?
In any case, to remove the hose (8) going from the back of your washer to the stand pipe, grab a pair of pliers and squeeze the wire fingers sticking out of the clamp (28) holding the drain hose to the plastic box on the rear of your washer. That relieves the tension of the clamp and, while still squeezing the wire fingers, slide the clamp up the drain hose a couple of inches. Then, you can pull the drain hose loose from the plastic piece.
Then, using your pliers again, completely remove the clamp from the old drain hose and put it on your new drain hose, about 3 inches back.
Then, stick your new drain hose onto the plastic piece and use your pliers to get the clamp back down to secure the drain hose to the plastic piece.
You should be able to figure it all out with no problem.
Oct 23, 2014 | Estate TAWS800JQ Top Load Washer
Does not seem to drain completely - ran very long today and the last code I saw was "nd" - not draining? or not done?
nd code indicates a problem with draining. The problem could be:
1. Clog in the drain hose - 2. Drain pump in the washer needs replacement 3. Clog in your sewage
Some simple things to try out
a. Run a wet/dry shop vac at the end of the drain hose to clear out any crud/cloth debris. b. Replace the drain hose altogether (will require a bit of work). Remove the back panel (small) that holds the drain hose in place and disconnect the clamp that connects to the drain hose to thepump outlet. The whole drain hose can be purchased for under $20 at your local hardware store...
Good Luck!
Jun 11, 2011 | Maytag Neptune MAH5500B Front Load Washer
Water does not drain,how do I access the pump
Hi jolanda03,
Remove the Top Panel, fastened by 2 screws at the back, Then remove the right Side Panel, you should see the Drain Pump attached to the sump. To test it, you could attach direct power to the two pins on it (Alternating current, so position of connectors unimportant). If it works, it could be either that it is not receiving power from the PC Board, or the sump is clogged inside (Filter).
Hope this helps, if it did please rate with 4 thumbs up. A testimonial would be nice too. :-)
Apr 21, 2011 | Dishwashers
Cabro WTW6200SW2 Top Washer. Water drains on the floor instead of through the drain pipe.
This one sounds like the drain pump is damaged or the drain hose is damaged or detached causing water to drain on the floor instead of through the drain hose. Disconnect power then tape the washer lid closed and lay the machine on its front on a cushioned surface to access the drain pump and the drain hose connections at the bottom of the tub. Reattach the drain hose if detached or replace it if damaged and cannot be reattached to the drain pump. Replace the drain pump if damaged and leaking water on the floor.
Mar 05, 2011 | Washing Machines
Water wont drain
You use your dishwasher so often with no problems that any issue can seem like a major disaster. But you can fix a drainage problem with a trip to the hardware or plumbing supply store and a few minutes of effort. If your dishwasher doesn't drain properly, the drain hose is probably kinked or damaged, interfering with the flow of water out of the dishwasher. You can fix the problem by replacing the drain hose yourself.
Difficulty: Moderately Easy Instructions And 4 Tools (Material) Needed To Solve The Drain Problem.
  • Shallow dish,Pliers or screwdriver,Replacement drain hose,Replacement hose clamps
  1. Turn off the water supply to the dishwasher. Turn off the dishwasher's power supply by unplugging it (under the sink) or turning off the appropriate circuit breaker.
  2. Pull the dishwasher all the way out from the cabinet so you can access the drain hose and pump near the back.
  3. Locate the drain pump and hose. The drain hose is the larger of the two hoses attached to the dishwasher and is generally located close to the bottom back of the dishwasher.
  4. Place a shallow dish under the drain pump. Loosen the clamp on the drain hose close to the drain pump, using pliers or a screwdriver. Pull the drain hose off of the pump, allowing any water to drip into the dish below.
  5. Remove the other end of the drain hose from the garbage disposal or drain by loosening the hose clamp and pulling the hose off of the connection.
  6. Attach the replacement hose to the drain pump and the drain or garbage disposal. Attach new hose clamps, and tighten them to hold them in place.
  7. Turn the power and water back on, and run the dishwasher through a cycle to make sure that the dishwasher drains properly and the hose doesn't leak. Tighten the hose clamps if you find any leaks.
Good luck and thanks for using fixya.
Jan 30, 2011 | Kenmore Dishwashers
MY SON'S DISHWASHER WON't drain
Hello there:
Please try these things below my post and click on the links that are available for you ok
I hope that tthis is very helpful for you
best regards michael
Water will not drain from my dishwasher. Investigate these six areas if water will not drain from your dishwasher :
dishwasher_drain-hose.jpg Drain Hose
It is quite common for a dishwasher to not drain because either the drain hose or the air gap (if the unit has one) is clogged up. Drain hose clogs commonly occur where the hose is attached to the main household drain line, or where the hose connects with the garbage disposer. Try removing the drain hose to unclog any debris. Don't forget to reattach the hose before you start your dishwasher again.
dishwasher_pump-repair-kit.jpg Pump Assembly
The pump assembly is comprised of a pump, wash impeller, and drain impeller. The pump ejects the water from the unit, the wash impeller pushes water through the spray arm, and the drain impeller directs the water towards the drain port. Examine your dishwasher's pump assembly. Clean out any debris that may be blocking it. Replace the pump assembly if any of its parts appear to be worn or defective.
dishwasher_belt.jpg Belt
It isn't very common, but sometimes a dishwasher's pump assembly is driven by a belt. If that belt becomes worn and defective, then it cannot properly run the pump that drains your dishwasher's tub. If your dishwasher uses a drive belt, examine it now. If it shows signs of wear, replace it.
dishwasher_timer.jpg Timer
A defective timer could interfere with a dishwasher's ability to drain properly. Test your dishwasher's timer mechanism. If it is faulty, replace it. Keep in mind that you can replace either the entire timer assembly or just the timer's motor.
dishwasher_motor.jpg Motor
The motor plays a key role in a dishwasher's ability to drain water. If your dishwasher's motor is not functioning properly, it will negatively affect the draining capability of your machine. Test your dishwasher's motor for continuity. If it fails the test, replace the motor.
dishwasher_drain-solenoid.jpg Drain Valve and/or Solenoid
In some models, a valve has to open in order for the water to drain out of the dishwasher. This valve is controlled by a solenoid, but it is the timer that decides when the valve should open. If your timer is working fine, check the drain valve and its solenoid. If need be, replace them.
Nov 14, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Diswasher did not drain
HI, this seems to be an obstructed hose(drain). i recommend inspecting the hoses before replacing the pump.
To access the drain hose remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to reach the screws over the panel, then close the door to remove the panel.
The drain hose connects to the pump and runs to the sink drain (or to the air gap on top of the sink). The pump has a second hose that recirculates the water back into the dishwasher. The drain hose is roughly 1 1/2 inches in diameter. While inspecting the drain hose, check the recirculation hose as well.
When checking for blockages, disconnect the drain hose from the pump, pinch the wire clamp with pliers and slide it up the hose. Place a shallow pan beneath the pump to catch any spillage. Remove the hose from the pump; wiggling the hose may help to loosen it.
Check the hose and nipple to the pump for any debris. The only way to be certain the drain hose is completely clear is to disconnect it from the sink and run water through (such as spraying a garden hose through it at full pressure). Disconnect the recirculation hose and check it in the same way.
Reconnect the hoses and replace the clamps. Replace the lower panel and restore electricity to the dishwasher. If there are no obstructions found or debris, this will confirm a damaged pump and, it should be replaced.
Nov 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washing Machines Logo
252 people viewed this question
Top Avanti Washing Machines Experts
Jim Thurston
No_ky
Kolbrun...
Are you an Avanti Washing Machine Expert? Answer questions, earn points and help others
