My washing machine won't spin or drain the water. It washes then there's a hum from the motor but it won't progress. There's no reset button to press; I've tried changing the cycle; turning machine off; washing again; still won't spin or drain. Last time I used it it did this but after jiggling the machine it worked but not this time
  • Czerney Dort Mar 20, 2011
    What brand you have
  • hdieme Mar 20, 2011
    my Fisher
    Scholar:
  • 83 Answers
The pump has a blockage that is stopping the impellor from spinning, hence the hum and not emptying. You need to gain access to the pump and remove the item, usually I find hair ties or plastic lolly sticks have worked their way in there.
Different types of machine require different methods to do this, so provide the make/model and further help may be provided.
Posted on Mar 20, 2011
  • 1 more comment
    Thanks for your help - no children live here so neither of those things could be stopping the propellor turning. It's a Fisher
  • Richard
    Richard Mar 20, 2011
    Fisher
    I've opened the front section and everything that should be able to turn does turn. I can't turn the machine on it's side as it's full of water so a bit stuck. Have contacted F
How can I spin and drain my normal size load. I have an LG front loading washer m/n WM2455H and it will not spin and drain. I hear the hum of the pump, so it isn't that. Went through all troub
It is most likely the drain motor even though you hear it humming. The LG drain motor impellers usually wear out on the motor shaft, and the impellers then just end up wobbling. The result; a drain motor that no longer drains water.
Sep 13, 2014 | LG WM2455HG XL Front Load Stackable...
Tip
Washing Machines will not rinse or spin
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
What is wrong with a washer that does not spin?
If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drivewashing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle.
How to Drain Washing Machine That Won Drain Family Handyman
Washer Doesnt Agitate or Spin
Error codes in front load washers
Washing Machine Not Rinsing How To Fix
My washing machine stops at Rinse Does not DRAIN or SPIN
What causes a washing machine not to drain and spin?
If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.
SOLVED Why won my washer spin or drain Kenmore 110 Series Washing Machine
Maytag Washing Machines will not rinse or spin Google Search
on Dec 12, 2017 | Washing Machines
Washing machine fills and agitates but won't spin or drain, just hums.
When the machine beeps it is giving you a code with the 8 wash progress lights along the top. Some will be on some will be off. With OFF = Zero and On = 1 Can you give me the 8 digit code. An example is (01001001) It is normal for the pump motor to get very very warm. Make sure you can spin the pump impeller easily.
Aug 09, 2014 | Fisher Paykel EcoSmart GWL15
Machine stuck in drain mode, beeps, can only turn off at powerpoint.
Your motor controller board is faulty
needs repair or new/recondition board.
May 06, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Washing machine won't wash I.e. bowl won't turn in wash cycle or spin. Fills with water ok. Will drain if start button is reset. Rear panel removed, drive belt in tact.
pull shafe out it is likly broken to find out between timer and shaft look to see if timer move by itself and if it does sorry u have broken shaft
Feb 16, 2013 | Washing Machines
Washing machine will not drain
Since you've already checked the pump, hoses and motor, here are some additional issues to look at:
1. Faulty timer: Does your machine fill with water and begin agitating, but the cycle never advances far enough to allow the water to drain? The timer that controls the cycles may be broken. Arrange for washing machine repair service.
2. Worn or loose belts: Are clothes still soaked at the end of a wash, even though the washing machine appears to go through the spin and drain cycles? The timer that controls the cycles may be broken. This is a job for the pros.
3. Faulty or jammed internal impeller on pump: When the spin cycle starts, do you hear a humming noise? The internal impeller that moves the water through the drain pump may be faulty or jammed. A grinding or grating sound is almost always an indication of a coin, button or other object colliding with the impeller. Have a washing machine repair expert determine if the impeller is jammed and can be cleared, or if the pump needs to be replaced.
For more troubleshooting steps, see Washing machine won't drain. I hope this helps!
Oct 08, 2012 | Washing Machines
My GE washing machine is stuck on agiation mode.
HUMMING NOISE MAYBE OVERLOAD ON MOTOR OR PUMP SO DEAL NOW WITH DRAIN PROBLEM 1ST IT MAYBE NEED TO DRAIN FILTER CLEAN
THANKS
Jul 15, 2009 | Washing Machines
Wash will not drain
Hi, When the cycle goes into drain, do you hear the motor humming at all? If the motor does not hum, check the lid switch.
If the washer agitates, there must be a problem with lid switch ot timer. The lid switch is most common.
Please let me know if this helps or if I can assist you further.
Vic
Jun 20, 2009 | Kenmore 22422 Top Load Washer
Washer will hum and will not drain water out!
You will have to either look under the machine or take the back off.
You will see the big motor which does the washing.
You will also see a small motor which drains the machine.
Disconnect the power supply and remove the pipes from the small motor.
It could be blocked up from congealed washing powder.
Or something may have blocked the pipe from the drum to the drain motor.
If it all looks ok and still doesn`t work, then the motor has siezed.
Very easy to replace
good luck
Jan 25, 2009 | GE WBSR3140DW Top Load Washer
Fridgidaire 7 cycle - older model top loading washing machine wont drain
could be a stuck gear box. motor trying to turn it on the reverse rotation for spinning. it could be the motor that hums. or the belt could just be loose.
inspect the belt and see if it is loose and adjust it if necessary.
tnx 4 using fixya,
drcool
Oct 17, 2008 | Frigidaire CWS3600AS Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
