Question about Acer Aspire 4315 Notebook
I cannot get my acer aspire 4315 to AC power up. new batteries are ok. i have changed the power jack but no difference. please help
    Genius:
  • 1,288 Answers
Check the light on the AC adaptor when plugged in to the laptop. If it is flashing, it indicates that the power is being "spat back". That is, not completing the circuit. Means that you have a fault in the charging circuit. I'd check for burning around the contacts where the DC port was soldered onto the board / or if the plug type, check the socket on the mobo is not damaged and is firmly soldered on.
After that, (if not already done) check the output voltage of the adaptor with a multimeter, might be a simple failure of the ac adaptor, even though it looks ok
Posted on Mar 20, 2011
My acer aspire notebook 7736Z-4412 won't turn on. I have tried taking out the battery and using the adapter but it still won't turn on?
yes boss pl remove ur battery n start only ac supply if ur laptop on or not if run ur battery defective or not run at ac ur laptop ac supply ac to dc converter circuit problem pl send my address solved n send u
May 26, 2014 | Acer Aspire One PC Notebook
How to replace AC jack in a Acer 4315-2160
buy s new plug and strip out the old wires and put in the neew plug
Aug 16, 2012 | Acer Aspire 4315-2490 Notebook
Laptop screen won't come on. Laptop battery won't charge.
Sounds like you might need a new AC-power adapter or dc-jack. Does wiggling the power plug on the computer make any difference? If the screen comes on when you wiggle the power plug,then you need a new dc-jack. If not, then maybe the AC-adapter is bad, I see a lot of replacement adapters being sold for the Aspire One.
Worst-case scenario is that you have a power problem on the motherboard,let's hope not.
Mar 22, 2011 | Acer Aspire One PC Notebook
My Acer 5630, suddenly cannot turn on. I already replace DC power adapter by a new one, but the problem still exist. Anybody can help me.
If you have already changed the charger, and tried running it without the battery, it sounds like you have a Mother Board failure. You should contact Acer and have it replaced.
Mar 14, 2011 | Acer Aspire 5630 Notebook
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
Acer Aspire 4730Z laptop
if ur charger is ok then u have need to change ur motherboard
May 02, 2010 | Acer Aspire 4730-4947 Notebook
Can't burn CDs/DVDs with the combo drive of my Acer Aspire 4315
OK you may want to tr changing the program you use to burn with. This will determine whether it is a hardware fault or a software fault. Try using http://cdburnerxp.se/ should help. I hope this helps. If it does could you please rate me.
Jun 24, 2009 | Acer Aspire 4315 Notebook
Acer Aspire 4315 BIOS Recovery
Hi there.
After using killcmos you should have updated the bios straight away, this is because you have wiped all the bios settings. As soon as you restarted the laptop you effectively killed the computer, getting it recovered can now prove near impossible. The only option you have left now is to locate the bios battery, remove it for an hour to see if the bios resets, other than that Acer may be able to help.
Good luck and thanks for using FixYa!!
Mar 12, 2009 | Acer Aspire 4315 Notebook
Acer aspire 4315 keyboard functions
aspire 4315 key pad problem some keys not working i changed new key bord and again same problem how to solve this please help me
Aug 22, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 4315 Notebook Logo
109 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
