Question about Ridgid 10"Wet Tile Saw with Laser and Stand
10 inch wet laser tile cutter saw (Ridgid) the water is not comeing through the clear tubes and I dont know where and how the pump should be installed
3 Suggested Answers
Mx Man
  • 45 Answers
SOURCE: nada
According to my translation your question is:
"I would like to know the price of water for cutting ceramic tiles"
Your best bet is to figure out how much water you will require and then call the water company to inquire what the charges would be for that amount.
Posted on Aug 17, 2009
  • 4088 Answers
SOURCE: where do i find a gfi for my tile saw? it stopped
You usually don't install gfi's at the load (saw) but instead at a socket where the plug is inserted. If you use an extension cord, change the socket end to a metal 'handy' outlet box and install a local type gfi there. Wire the black wire to the brass screw, the white wire to the silver screw, and green wire to the green screw. Make sure that none of the wire strands are left loose to short out on something. They are available in any hardware store or home center. Hope this helps!
Posted on Mar 19, 2010
Looking for the blade guard arm.
Search Results
    7" Job Site Tile Saw with Laser - RIDGID Professional Tools
    https://www.ridgid.com/us/en/7-inch-wet-tile-saw-with-laser
    Ridgid7" Job Site Tile Saw with Laser. ... Heavy Duty Arm - prevents flexing while keeping the blade aligned; Guard Baffle - reduces air turbulence to help keep water ...
    [PDF]7" BRIDGE TILE SAW
    manuals.harborfreight.com/manuals/97000-97999/97360.pdf
    7" BRIDGE. TILE SAW. WITH STAND. Owner's Manual & Safety Instructions. Save This Manual .... that has an outlet that looks like the one illustrated above ... Use saw-blade guard and spreader for every .... arms and shoulders. To reduce the.
    [PDF]10" INDUSTRIAL TILE/BRICK SAW Owner's Manual ...
    manuals.harborfreight.com/manuals/69000-69999/69275.pdf
    parts. Nonslip footwear is recommended. Wear protective hair covering to contain long hair. 11. ALWAYS USE ... an outlet that looks like the one illustrated above in Figure A:... For Your Own Safety Read Instruction Manual Before Operating Saw. 1. Wear eye ..... Connect the clear water Hose from under the arm of the Motor ...
    SKIL 7" Wet Tile Saw 3540
Dec 16, 2015 | Blade Saws
Was going to buy " the beast" but have seen a lot
"In my opinion" I would stay away from the Ridgid tile saw. We had one come into our shop for repair of a burned out motor and could not get parts for it. The saw, at that time, wasn't made by Ridgid, it only carried the Ridgid name. I'm not familiar with the Dewalt tile saw enough to give you an opinion on it. If I were in the market for a tile saw, I'd get one by MK Diamond, they specialize in tile, stone, etc. cutting and make the best tile cutters I've used and worked on. They're priced towards the high end but are of contractor or industrial quality so will last a long time. If they do need repairs they're easy to get parts for that are fairly priced.
Jan 31, 2011 | Ridgid 10"Wet Tile Saw with Laser and...
I have a 10" ridgid
With bigger tiles I have to cut more than half way, and then turn tile around and cut last bit from other direction.
You might be able to cut half way down tile, and then move tile forward on tray.
My wheels come to a stopper and don't run off the track, so my saw is different than yours.
Jan 24, 2011 | Ridgid 10"Wet Tile Saw with Laser and...
Rigid wts2000l WEt saw is not sending water to blade even though it is in on position
look for weak pump, or blocked pump pick up.
I have a similar saw, and the pickup at the pump gets pretty grimey, and ned to blow it out once in a while to keep it clean and of cake like tile paste. also check the hoses for splits and/or cloggs.
Jan 07, 2011 | Ridgid Wts2000l 10" Wet Tile/stone Saw...
Was cutting tile and it just shut off. Blade seemed dull. Does blade stop running when it needs to be replaced?
no it does not there is a fault with the cutter arm in most cases its a broken switch or its brusges are too worn
let me know if you need more advice
Dec 31, 2010 | Ridgid 10"Wet Tile Saw with Laser and...
Cannot keep water on the blade of my 10" Rigid wet
if waters not getting to the blade you will see the powder of what ever your cutting coming off the back of machine,i like to put my pump in a bucket of water under the drain plug instead of puting the pump in the water tray,you can run bigger tubing up to the blade and reduce it down and it will give you better presure,good luck
I purchased the new Ridgid tile saw named " The Beast". Initially it looked like a great saw buy after cutting a few ceramic tiles I began to notice that it cuts with a slight curve. I could not find any...
Its either the speed of the blade ( mine came with its speed at half rate), or its the crappy blade they give you with the saw. If a cut is bowing your blade is having a tough time with material. This often happens with tough porcelain tiles and not using a porcelain blade.
Oct 01, 2010 | Ridgid 10"Wet Tile Saw with Laser and...
The arm that holds the motor to the tray, broke and cant find any replacement part, why is that?
Go to the Rigid web site and get their coustmer number they have replacement parts there.http://www.ridgid.com/ Shows you saw and parts for it.
Nov 11, 2009 | Ridgid 10"Wet Tile Saw with Laser and...
Ridgid Wet Tile saw water pump operates, however the water is not getting directed onto the blade. Hose partially plugged? How to clean nozzle?
You could clean the hose ... however, I think Id get to the hardware store and get a new piece.
Clean the end with a broom straw. You could trim a small piece of the hose off. Dont neglect to clean the filter on the pump. Slide the bottomoff the pump to expose the filter.
Oct 21, 2009 | D Cut CS-070 Wet Tile Saw
Nada
Aug 17, 2009 | Ridgid 10"Wet Tile Saw with Laser and...
Ridgid 10"Wet Tile Saw with Laser and Stand Logo
69 people viewed this question
Top Ridgid Saws Experts
John Trevino
Jim Thurston
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
