There is a little fuse that mounts to the htr that is between the thermoprotector and the elements that is bad and I need one but I don't know where to find it. HELP TM
  • 4 Answers
The best thing to do is to look in the yellow pages to find AC Parts and Supply. There are many who will sell to the general public. If you are able, take the bad fuse with you as well as the make, model and serial numbers of the heater with you.
Posted on Mar 20, 2011
I don't know what fuse to check for heater blower fan on 2006 dodge 3500
there is a fuse that says htr on it thats the fuse.
Mar 12, 2013 | Cars & Trucks
Not getting heat
Hello there mark and welcome to fixya
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. To determine if the heating element is burned out, you will need to test it for continuity it should read 000 on the meter if good and a 001 or a 1 means bad ok the meter needs to be set at the lowest ohms scale . Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) To determine if the thermal fuse has blown out, watch the part testing video at the bottom of this page.
Dec 17, 2011 | Whirlpool Dryers
My dryer whirlpool still blow cool air but do not heat please tell me what the problem henry le
Bad heating element or bad thermo fuse.
You will have to unplug the dryer and remove the back to access the heating element. The thermo fuse is located on the side of the heating element.
If you don't have a meter to test the element and thermo fuse or just don't know how simply remove them from the dryer and take them to your local appliance repair shop and they can test them for you.
Aug 03, 2011 | Whirlpool LER4600 Electric Dryer
Dryer will not heat up
There is a cover on the upper left on the back that houses the "Thermal Limiter"that you need to check for continuity with a multimeter. IF it's bad, replace with this part. Next, there is a thermostat on the rear heater housing that need to be checked for continuity and replaced if bad with this part. Then, check the heating element for continuity and replace if bad with this part.
Happy Holidays
Dec 14, 2010 | Frigidaire FER311FS Electric Dryer
My dryer is not getting hot
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Dec 01, 2010 | Roper REX4634KQ Electric Dryer
Dryer won't heat
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it.
Nov 26, 2010 | Dryers
Dryer is not heating
Nov 25, 2010 | Frigidaire Dryers
I have a Maytag Gas Dryer D6612. It is not warming up, there is no glow from the little door on the lower right. Is ther a pilot light that needs to be relit? The gas company was here the other day...
Okay, here is a couple of things to look for:
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Looking up a couple of other things.
Sep 30, 2010 | Dryers
I have a Whirpool Dryer model 3LEN 2000PW1 It runs but does not heat?? Four years old. Could it be the heating element?
Hello there:
Sep 29, 2010 | Whirlpool Dryers
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
