Question about Home
I have a kwikset door set. The interior has a knob and the exterior is a thumb lever. The knob fell off and I am trying to put it back together. The lever does not engage. Their are teeth and it looks like there is nothing to connect into the teeth to activate the lever together with the middle door catch tongue...only the knob turns and works properly when reassembled. Am I missing a very small piece or something?
4 Suggested Answers
  • 1015 Answers
SOURCE: i am replacing my door
Most kwikset locksets will work on either 2 3/8 or 2 3/4 inch setback. There should be two holes on the latch where door knobs fit thru the door. If yours does not have this option I would suggest that you get one that will match your setback.Hope this helps.Thanks.
Posted on Nov 16, 2010
  • 885 Answers
SOURCE: I purchased 2 kwikset entry
Remove the two screws holding the two halves of the lock on the door of the lock you want to change. Pull the keyed side out and turn it 180 degrees until the keyway is facing the direction you want and reinstall the lock and two screws.
Posted on Aug 16, 2011
  • 963 Answers
SOURCE: re-assemble a kwikset front door lever and knob type latch
Since the exterior side of the lock only has a keypad and no lever, I'm not sure what you mean by the "outside lever". Here is a clear, easy to follow video of the installation. Please carefully review each aspect of your installation against it to see if you can spot an installation mistake:
http://www.kwikset.com/Videos/Vitro/smartcode.aspx
Posted on Sep 06, 2012
Exterior door stuck closed manually retract ****** remove knobs KWIKSET
You will probably need to replace the latch assembly. There is a small rivet that holds part of the latch together, and it also acts as a pivot point for a small piece that retracts the latch. If it gets bent, the latch won't retract fully, but you might be able to push it back and get the door open.
May 24, 2014 | Kwikset 740ll 3 Smt Lido Keyed Entry Lever...
Re-assemble a kwikset front door lever and knob type latch
Sep 03, 2012 | Kwikset 909 909-L03 Lifetime Polished...
Front door toggle and knob assembly replacement
I have an exterior screwless doorknob that I need to remove. The faceplate on the inside knob that covers the screws is also covering the little pin that removes the knob. Is there another way to remove...
There is the 3rd version of the Kwikset exterior door set. The interior face plate is removed and on each side of the base plate has small slots with a lever on either side that need to be moved to the other end of the slot. The whole interior knob assembly with come off.
Dec 23, 2011 | Kwikset Locks & Locksmithing
Could you send instructions for thumb door handle ours fell apart and we don't know where the pieces fit....thank you
Sure, let me give you a link to the installation instructions for the Kwikset Lido(keyed lock):
http://s7d5.scene7.com/is/content/BDHHI/44593-01
If this is not what you had in mind, go to this page:
http://www.kwikset.com/Customer-Support/Product-FAQs/Search-Faq.aspx?prod=FAQ+Categories_Levers_Lido
and select the model most like yours. Clicking on the picture will bring up installation and warranty links, etc.
Please note that if I haven't been able to help you, then I urge you to contact Kwikset Customer Support:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Jun 17, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
My exterior door lock (Kwikset) is stuck shut. The knob will not turn. I removed the knobs and tried to pull the mechanism back - but unable to. The door is therefore stuck shut.
Get a big scredriver and put it in the square in the middle of the mechanism and turn it till it opens, or you will just have to pry it out with the scredriver.
Apr 05, 2011 | Kwikset Locks & Locksmithing
We have the thumb press elongated handle on the outside of the front door entry. I was ready to enter the front door when I pressed the thumb handle and the whole set fell apart. Need instructions to put...
For the Lido Keyed Entry, go to this page:
http://www.kwikset.com/Products/Details/Door-Levers/740LL-26D-SMT.aspx
and click on "Installation Guide", found under the red text " Technical Documents"
If I've steered you to the wrong lockset, the product main page foe Kwikset can be found here:
http://www.kwikset.com/Products/Categories/Handlesets.aspx
Feb 13, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
Changing doors would like to know how to take off kwikset door
remove the two screws on each side of the door knob from the inside of the door use medium size phillips head screw driver
pull the door handle off
remove the handle from exterior door side
remove two phillips screws from the side door that hold the door bolt pull the door bolt assembly out
reinstall on new door
insert bolt assembly
insert knob for exterior side(a lign it up
insert knob from interior side and align screws and tighten ligtly
check door for easy turning of knob and actuating latch
good luck
remove that assembly
take screw driver and remove the two scres that remove the plate on the side of the door and
Dec 29, 2008 | Kwikset Professional Door Lock...
Home Logo
50 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
