Question about Haier XQBM22-C Top Load Washer
Always unbalanced in the spin cycles - Haier XQBM22-C Top Load Washer
  • 604 Answers
The machine may need to be releveled, if it is not level the clothes will have a tendancy to go to the low side and thereby causing the unbalanced condition
Posted on Mar 20, 2011
Spin cycle is going on balance
Betty, if you suggesting the machine is out of balance/ causing the machine to jump around in spin cycle
1. it may be due to a heavy wet load ,like towels unbalancing the machine, try less load or slower spin ,then fast spin
2. could be concrete balancing block inside machine has come loose, both problems causing a unbalancing affect on the spin cycle.
Nov 11, 2016 | Washing Machines
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
Unbalanced load at nearly every spins cycle ,move clothes around until it spins
Is it a front load or top load? Do you have the make and model?
Jan 26, 2015 | Washing Machines
Wixe167 just stopped running while spinning on last cycle
It stops spinning because the load is unbalanced. It will cycle over and over until the load is even then it will kick into a faster spin. Unbalanced loads could be due to too many items in the washer of a stabilizer problem in the hardware of the machine,
Oct 26, 2013 | Indesit Washing Machines
Noisy Spin Cycle
hi there,
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping/or sound
during the spin, the load of clothes may have become unbalanced. Stop the washer and
redistribute the clothes, then re-start it. Repeat these steps if necessary.
Jun 12, 2008 | Whirlpool LSR9434PQ Top Load Washer
Fwt449gfs1 unbalanced in spin cycle
there is a three post bracket bolted to the back of the inside drum. on ours two of the three spokes are broken. looks like you have to buy whole new drum assembly. around 300 bucks
May 21, 2008 | Frigidaire FWT449
Kenmore 80 series washer stopped during unbalanced spin cycle
lid switch is broke lever probley broke off or screw holes broke out due to off balance load forcing tub over against switch lever
Apr 29, 2008 | Kenmore 20172 Top Load Washer
Loud knocking noise at end of spin cycle
To allow for unbalanced loads and reduce vibration in the floor of the house, the outer tub is suspended by various means. Some machines use a heavy rubber ring, others use spiral springs but either of those can, after a heavily unbalanced load, unhang themselves or in the case of the rubber suspension, the rubber tires and rips.
If you remove the back panel (10-12 screws) and look inside while pushing the tub side-to-side, you should be able to find the suspension and inspect it with good light.
Apr 17, 2008 | Kenmore 22622 Top Load Washer
Haier XQBM22-C Top Load Washer Logo
192 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
