Question about Danby Compact Refrigerator DCR-101W
My refrigerator stopped working because I left the door open for like three hours and the electricity does not go to all the fridge parts like the lighting system is off and the freezer is off every thing is off I think maybe the sensor of the electricity is disconnected can u please help me with that my food getting hotter
  • 2,133 Answers
There is no sensor like you stated. Actually, when you keep open the fridge door, the cooling all will go out and hence thermostat sensor would not cut off, as required temp not reached inside the fridge.
So, the compressor would have run for long time without cut off. Due to this the overload protector trips the compressor. Remove power for 4 to 6 hrs. And then restart the fridge. But make sure you close the fridge door. Thanks.
Posted on Mar 20, 2011
Frigidaire refrigerator beeps every 20 seconds or so. three beeps.
try opening the door.leave it open.unplug the fridge for at least 5 minutes, no less,with the door still open.after that,plug it back in.wait for it to beep.then close the door.
this would reset the door alarm,which beepes when the door isn't properly closed.
also you should wait 24 hours between changing the temperature or it can mess up your fridge.!
Oct 13, 2016 | Frigidaire Refrigerators
The fan stops when i open the fridge and it beeps about 10 times
The beeping is caused to notify you that temperatures are rising the=> 2304099 Defrost Control Board
is possibly defective. Sometimes examining both sides of the defrost board will reveal burn marks or signs of heat damage but not always. Look inside the freezer to see if frost is building on the rear wall of the freezer. Here is a link to a photo of a freezer wall showing frost buildup HERE Here is a link to a parts manual T1FHTXMQ00 Parts Manual User Manual HERE
Other parts that may cause the refrigerator to warm are the=>
2166124 Defrost Heater Assembly
and the 2221677 Defrost Thermostat
Testing the defrost heater and defrost thermostat are easy. I will be here should you have questions, Thanks
Sea Breeze
Apr 05, 2013 | Whirlpool ET1FHTXM Top Freezer...
Maytag MFI2568AES refrigerator was left open a couple hours, now it's not cooling at all.
Unfortunately, this model has had quite a few problems, because it is such a complicated refrigerator. Many times a shorted component that is connected to the Iceland main control board will affect completely unrelated items making it easy to chase your tail for hours. I would suspect the freezer thermostor - only because we have had to replace it many times in the past.
Suggest you go to the www.searspartsdirect.com and copy the electrical diagram and then verify electrical reading on the main PCB, to try to isolate the problem.
Jan 23, 2012 | Nor-Lake Refrigerators
We inadvertently left the freezer door slightly open the frrezer ran continuusly for twenty four hours. Would this cause the condenser to frreze up and burn out? The frrezer is still cold and we...
leaving your freezer door open does nothing ,but work the freezer harder,,,it wont cause no of the prolems you stated,,it will cause your electric bill to rise ,,your ok...the condenser is part of the seal system and it exspell the heat usally under the fridge...good luck
Sep 03, 2011 | Kenmore Top Freezer Refrigerator
Freezer side is working fine. the fridge side appears not to be as cold as it use to be. a few days ago my kid left the door ajar all night. how ever it should be cold by now. there is power I can hearthe...
When a refrigerator door is left open the freezer will continue to run to keep it cold and since it can't cool an open area it will freeze up on the inside, to resolve this you will need to unplug the fridge and open the freezer door and allow the freezer to thaw completely, once it is thawed you can plug it back in and everything should go back to normal after a 24 hour period
Jun 28, 2011 | Kenmore Side by Side Refrigerator
Sub zero stopped working after door left open
whe n you left the door open the fridge have a sensor. and turn the LIGHTS OFF. close the fridge let it cool again.
Aug 09, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Door left open, now fridge won't work right.
Shut down the fridge for 10 - 15 Minutes and leave the fridge door open, and push the Defroce button
ANd start the fridge again and after some time check the temp.+ after some time.
Thanking you,
Your Tech Support
Manish Shirsikar,
Fixya.com
May 18, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Haier HRF10 Fridge weird motor sounds
hi. thanks for the question. leaving the door open ,would let a lot of moisture to enter the freezer, and cause it to frost up. to clear frost. cut power to fridge, open the doors .,let thaw over nite clean up the water mess. dry the inside of fridge & freezer turn power on good to go. to stop the door from being left open .lift the legs under the front so the fridge has more weight, and it will close by self . no more doors left open. thanks the appliance doc
Sep 28, 2008 | Refrigerators
Refrigerator stopped working, freezer works fine
I turned off the refrigerator and left the freezer door open so the coils and the vents could thaw out. The cold air was not getting to the refrigerator section because of ice blocking the vents.
May 01, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Danby Compact Refrigerator DCR-101W Logo
581 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
