Question about Garden
Safe will not unlock I`m using the correct code i initially entered,. it just makes a beeping sound
    Sergeant:
  • 259 Answers
Moisture gets in to the locking mechanism causing the problem.Take a rubber mallet and tap the area below the number pad left right and middle area of the door. Then try to enter the code again to unlock it. After the door is open I would put a moisture absorbant inside the safe.
Posted on Mar 20, 2011
My safe, a Cathedral EA15 Will not lock. Any suggestions people?
Instructions
  1. 1
    Enter your code on the keypad located on the front of the safe. Some electronic digital safes require you to input a special character like "#" before and after your code. The safe should either beep, have a LED turn green, or display "OPEN" if you have correctly entered the code.
  2. 2
    Turn the handle to the right within five seconds of correctly entering the code. If you wait too long, the safe will lock and you will have to enter your code ag
Open the safe with a key. Use your emergency key that came with the safe to open it if you forgot the code or if the batteries have died. Remove the key cover from either the handle or the control panel to reveal the lock.
  1. 1
    Enter your code to open the safe.
  2. 2
    Place the electronic digital safe into code reset mode. On some models you need to hold the last digit of the code or press the "*" button to get into code reset mode. Other safes require you to open them and press a small red button on the inside of the door.
  3. 3
    Enter your new code on the keypad and press "#" to finish. Some safes may require you to press "*" or a letter to finish the code. If the safe requires it, enter the new code again to confirm that you entered it correctly.
  1. 1
    Use your code to open the electronic digital safe's door.
  2. 2
    Locate and remove the battery cover on the inside of the door.
  3. 3
    Replace the used batteries with new ones. For most safes, this will require two or four AA batteries.
  4. 4
    Test the batteries. Use your code while the door is open to test the batteries before closing the safe.
Feb 08, 2015 | Locks & Locksmithing
How do I reset my homenet model 20-40 digital safe, I've put a wrong digit in now can't open it ?
This should work if the safe is not bolted to a wall, i.e. you have access to the rear mounting holes.
On the rear side of the solid iron door is a red button... this allows you to edit/reset the access code to the safe: To get to this button with the safe shut and locked you need to poke a thin object like a knitting needle (a thin pencil may do) through one of the holes on the back of the safe used for anchoring it to a wall. Use the hole on the bottom panel of the safe: To make things easier you can shine a torch through one of the other holes and look through another to see more clearly. Manoeuvre the pencil until you can press the red internal button, you will hear a "beep" sound if you are successful. Good luck
Dec 28, 2014 | Cars & Trucks
How do i set code for paragon safe
INITIAL BATTERY INSTALLATION
1. Remove the key plate cover, insert the key into the keypad and open the door.
2. Remove the battery cover plate located on the inside of the door.
3. Install 4 AA batteries provided and replace the battery cover.
NOTE
: If both the red and green lights are on while the safe is open, this indicates that the batteries are low and need
to be changed.
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
OPENING THE SAFE
1. Input your code and then press the "B" button, the green light will turn on.
2. Turn the knob clockwise within 5 seconds to open the door.
3. Each key pressed will be accompanied by a buzzer and a yellow flashing light. If the entered code is invalid the yellow light will
flash and the buzzer will quickly sound, this indicates the code needs to be re-entered.
CAUTION
: Entering the incorrect passcode 3 times will lock the system for 20 seconds.
More information can be found in the attached document web page.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
Sports afield 6040 executive vault how to reset combination
Spot Afield safes default code is 1,2,3,4,5,6. Open the safe door, with door open lock the handle. This will let you have assess to your things if you have trouble while setting the codes. To change the code, press the * 6 times. You should hear a single beep and one flash from the LED, then enter the default code 1,2,3,4,5,6. Again you should hear one beep and see one flash. Enter the new code you would like to use ...lets say 6,5,4,3,2,1. You should hear one beep and see one flash. Enter the new code again 6,5,4,3,2,1. The code should now be set to 6,5,4,3,2,1. Try the new code and see if it unlocks the door. Also try the old code to make sure it no longer works.. If at any time during the process you hear 3 beeps and flashes something went wrong. You will need to start over.
Good Luck!!
Jun 30, 2014 | Other Sports Afield Executive Gun Safe...
How do you change the code on a Legacy Safe?
Make sure you do this with the door OPEN.
Make sure that you have a fresh battery in place.
Hold down the 0 until you hear a beep twice
Make sure that you have written down your new combination before you enter it, then enter your old combination. Wait for the two beeps.
Now enter your new combination and wait for the two beeps.
Enter your new combination again, waiting for the two beeps.
Wait for 15 seconds, then enter your combination; you should now be able to turn the handle.
May 04, 2014 | Home Security
Can't turn off beep sound on keypad of my stack-on Security Safes Electronic Lock for a 16 gun safe
You can turn off the "Beep" sound of the keypad by entering the code 633.
To turn the "Beep" sound on, enter the code 66
Feb 17, 2013 | Stack-On Stack On 16 Gun Safe with...
After given the correct radio code from a holden dealership I pressed and held the "AS" button and after a short beep was heard I entered the code using the correct proceedure,Now how do I get...
You appear to have been given the wrong code.
For the correct code ,the radio SERIAL NUMBER will be required
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
Feb 24, 2011 | Car Audio & Video
Instructions how to insert unlock code for radio Holden Barina. I have the code just not sure how to input it
If your radio is made by Blaupunkt ( As most Barina radios are ) then here are your instructions.
If yours is a different make then please post a new question quoting the radio MAKE & MODEL
HOW TO ENTER A BLAUPUNKT RADIO CODE
Switch the ignition key ON
Press and hold AS button * and the ON button at the same time
Display Shows SAFE then goes to 10 - - - - with a "Beep" from the speaker
Press Preset Button " 1 "repeatedly until the 1st Digit of your Code is displayed
Press Preset Button " 2" repeatedly until the 2nd Digit of your Code is displayed
Press Preset Button " 3" repeatedly until the 3rd Digit of your code is displayed
Press Preset Button " 4" repeatedly until the 4th Digit of your code is displayed
If the display now shows the correct Code number then
Press Button AS and hold to Enter and if successful there should be a "Beep" from the speaker and the radio should switch on
Jan 16, 2011 | Blaupunkt Car Audio & Video
I purchased a new Sentry Safe, Model CSW 4747 yesterday. When I unboxed the safe, the safe was open, the lock handle was down, cyclinders were a little pertruding, and the lock cyclinder was popped out. ...
(1) sounds like the interior lock activation screw is still installed. it's the long screw on the inside of the door with the yellow tag; (2) when entering the code, make sure the key is turned to the right; (3) after entering the code, make sure you next press the program button. enter the code wrong three times and it locks up for two minutes.
Sep 11, 2010 | Office Equipment & Supplies
Unlock procedure for vw/audi
audi gamma cc type
1e2fb0f.jpg The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
  1. Turn on radio. The radio display shows "SAFE".
  2. Press the FM1 and AM buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  3. Use Preset buttons 1 ... 4 to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1.
  4. Once the code shown on the display is correct, press the FM1 and AM buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
  5. The radio should unlock and be usable shortly afterwards.
  6. If an incorrect code is entered, the word "SAFE" appears, first flashing and then continuously. You can repeat the above steps to unlock the radio once more, the number of attempts will be shown in the display. If an incorrect code is entered again, you radio will be locked for about one hour. After one hour - the radio must stay on and the key must remain in the ignition lock - if the display goes out, the you can repeat the above procedure to unlock again. The cycle - two attempts, one hour lock-up - still applies.
  7. If you lose your radio code, contact your Audi dealer.
audi delta
  2. Press the FM1/2 and DX buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  4. Once the code shown on the display is correct, press the FM1/2 and DX buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
Mar 29, 2010 | 1997 Audi A4
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
