E-drive lost from my computer . occured while copy from disk to i-tunes
    Master:
  • 525 Answers
Go to manufacturers website and download the software and reinstall it.
Posted on Mar 20, 2011
I am getting a disk read error occurred. Press ctr-alt-del. what can i do to fix this
Your computer cannot read your copy of Windows from your 'C:' disk-drive.
You need to purchase a replacement disk-drive, and re-install Windows onto the new disk-drive.
I hope that you have a good backup of all your files!
Mar 30, 2011 | Acer Aspire One PC Notebook
Tip
Windows system always restart
Computer often restarts, can not enter windows.<br /> Firstly check your ram.<br /> If you can, do a test with the new ram it's better.<br /> if not, make sure your use ram is fully functional.<br /><br />Turn on your computer, if the problem is still the same.<br />Do a test on your power supply. make sure the power supply to do the test is 100% work or use the new.<br /><br />Turn on your computer again, if the problem still occurs. unplug all cables connected to hard disks, cd / dvd rom, floppy and remove all the pci cards. now leave the connection to the power supply to the motherboard and the other connecting wayer suiz on / off (all the connections on the panel) if you are using a display card, left the display card in the slot and then turn on your computer.<br /><br />Now look at the results. if still the same. This means you need to do tests on your processor and motherboard. but if your computer does not restart again stable, this means, most likely the problem comes from the hard disk.<br /><br />Ok. now try to connect to your hard disk. problem occurs frequently restart <br />again right?<br /><br />If so, you need to perform tests on your hard disk. <br />how to perform the test, if you have important data in the hard disk. I suggest you first Copy your data to another computer first. by connecting the hard disk into the computer that you want to use to make copies (if the type of hard disk pata / ideas, set the jumper to slave and connect to any idea that the cable has not been used in the computer you use, if no the cable idea, you can use a cable that is used for cd / dvd ram for a while) if your SATA hard disk, no need to set jumpers, just connect the sata cable and then just copy the data may be at work to do.<br /> <br />After completion of all copied data. The cover page, then klik2x on my computer icon. observe the hard disk drive for. (For example, now for the hard disk drive is e. Right-click on the drive and click format. If the page to format mungul. Tick box format for quick and clear the volume level and then click Start.<br /> <br />after the format, remove the hard disk and set the jumper to the original and put it on your computer. then for the window installation process you will be done as usual.<br />** (If your problem still occurs. My suggestion is that you must use a new hard disk or a 100% hard work and re-do the installation window, because the hard disk is damaged or has a bad sector will cause your system files are always auto restart due -file to boot normally have been damaged or lost due to bad sectors.) **<br /> <br />good luck ... <br />Contact me for further problems<br /><br />Regards<br />multilinkent<br />Thank fixya<br /><br /><br />
on Feb 22, 2011 | Computers & Internet
Driver of kingston datatraveller g2 2 GB is lost so it is not able to open it data contents please tell solution on this problem
Connect it to a different computer.
Copy its files to the 'C:' drive.
Burn a copy of the files to a CD/DVD-writable disk.
Then "format" the device.
Copy the files back onto the device.
Use the CD/DVD disk on your computer.
Dec 14, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Hi. I have lost my adapter and connectors to connect my smart disk HD to my Macintosh power book (g3 model). The model # on my disk drive is FWFL80-N. Has another # which is JH7X04. Where can I find...
You could buy a disk-drive-to-USB adapter, and connect the "bare" disk-drive to a USB port on your computer, and then copy all the files onto your computer.
See: http://cgi1.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=190391564434
for under $5.00 for such an adapter.
Or, you could spend about $40 to buy a brand-new enclosure & AC-adapter & cable that is "empty", and then you could "transplant" your 40GB disk-drive into that enclosure, without losing any data on the disk-drive. Then, copy the files, and then remove the disk-drive, and purchase a new, larger, disk-drive, and install that into the new enclosure.
Given that your disk-drive is "only" 40GB, it's probably getting old, and is "out-of-warranty", and thus should be "retired" before it completely fails.
So, the best solution would be to buy a brand-new, much larger, external storage device.
Nov 07, 2010 | SmartDisk FireLite 40 GB Hard Drive
When trying to restore my u series 9, (ST3160022ACE) ultra ATA 160 gig hard drive I get this message: Restore was not successful. Remove any USB or Extra Hard drives taht are connected. I have no USB or...
If by "restore" you mean that you are reinstalling Windows onto the disk-drive, to restore Windows to the "as-shipped-from-the-factory" condition, then a failure of that operation can be caused by either of three conditions:
* I/O errors reading files from the CD/DVD disks (due to dust/fingerprints on the bottom of the disks),
* I/O errors writing files to the disk-drive,
* an intermittent problem with the computer's motherboard or RAM, causing "random" failures when using the computer.
So, on another computer, take the CD/DVD disks, and try to copy the entire contents (namely up to 4.7 GB) onto the 'C:' drive, watching for any "I/O errors" during the file-copy operation.
If the file-copy completes successfully, then the copy of the files can be deleted.
If no errors occur, then it's time to suspect that the disk-drive itself is failing.
Buy a new disk-drive, and disconnect the old disk-drive, and connect the new disk-drive,
and restart the "restore" operation. If the "restore" fails on the new disk-drive,
then it's time to suspect that the motherboard has a problem.
Nov 03, 2010 | Seagate Computers & Internet
I have a dell inspiron 1318. whenever i turn the laptop on, there is a black screen with a "read disk error has occured" message...it keeps bringing me back to the same screen...what should i do?
Disk read error is indicative of a hard disk drive failure. If under warranty, call Dell for a replacement drive. If not you can buy drives at places like Newegg.com or EBay
Sep 20, 2010 | Dell Inspiron 1318 Notebook
I was copying something from my External Drive to my computer hard drive. the copy froze and my computer froze i had to restart and ever since I can't get my External Drive to connect to my computer.
you need to scan your external hard drive for bad sectors problems, you can use winpe mini cd, its a live cd that have hirens boot disk inside it as well as a preinstalled windows eviorment that will give you access to many tools and softwares...download it , burn it to disk and boot it.....
the idea is when you was copying files, some read errors occured that crashed the system, and whene the system crashed, bad sectors/clusters appears, and they need to be scaned and fixed.
May 11, 2010 | Western Digital My Book Essential Edition...
When I download progs. from my PC to my iomega multi drive I sometimes find that the download has not occured, and the multi drive shows a question mark alongside the folder. Other times no problem.
most {programs} cannot be copied from say hdd drive to other drives drive for examolr microsoft office can be copied disk to disk or installed on an external hdd but you cannot copy the files from disk to multi disk and exect it to work.
Oct 30, 2008 | Computers & Internet
Lost cd
The vivicam 5100 doesn't require additional software ones the camera is connected you can find - look - copy - delete your pictures by opening the camera drive from my computer, ones connected it should appear as a new disk there.
Jun 18, 2008 | Vivitar ViviCam 5100 Digital Camera
Memory card
Check your memory card, it probably has lock and unlock switch.
May 12, 2008 | Electronics - Others
Computers & Internet Logo
13 people viewed this question
Alun Cox
David Payne
David Payne
