Question about Ridgid 85942 SP-330 1/3 HP Submersible Sump Pump
The vertical float switch won't trigger when the water levels exceed extreme water levels
    Sergeant:
  • 259 Answers
Sounds like the switch is faulty. You have to get the model of the pump and get a switch at a electrical repair center.
Posted on Mar 20, 2011
Red light flashing
Some of them TDs has a float which triggers a kill switch to stop the dryer if the water level exceeds the level and would overflow. Perhaps your float is stuck. I have not had the priv of working on one of these yet as they are not in my area. But I have been studying em.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 24, 2013 | Hotpoint Dryers
Dishes are still dirty after all cycles
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Sep 01, 2011 | Dishwashers
Do not clean dishes very well
Hi
Daniel
Aug 27, 2011 | Kenmore Dishwashers
The glasses are cloudy inside how do you get it out
Hi
Daniel
Aug 26, 2011 | Dishwashers
Water does not flow thru when cycling.
Hi
Daniel
Aug 24, 2011 | Frigidaire FDB1200RG 24 in. Built-in...
The washer works but will not spray the dishes
Hi
As the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 18, 2011 | Dishwashers
My dishes will not come clean
Hi
Daniel
Aug 16, 2011 | Frigidaire Dishwashers
Will not clean Dishes, leaves film on Glasses
Hi
Daniel
Aug 05, 2011 | Dishwashers
White film on all glasses and plates
Hi
Daniel
Jun 19, 2011 | Hoover Dishwashers
After commencing a programme my Hotpoint BF71 dishwasher takes in water but overfills, filling the whole of the tub nearly to door level. The waste pump starts for a short burst and then more water comes...
Check for a float switch that senses the water level. It may have two level sense of filled and overfill the latter would trigger the waste pump to avoid a flood. If the filled switch has failed, that could cause the problem. The waste pump MAY also be triggered on the basis of the filling taking too much time before the filled switch actuates... if it has failed, the time would be exceeded.
Dec 13, 2010 | Hotpoint 24 in. BF72 Built-in Dishwasher
Ridgid 85942 SP-330 1/3 HP Submersible Sump Pump Logo
248 people viewed this question
Top Ridgid Electrical Supplies Experts
Tim Venetis
Gene Haynes
obsteiner
Are you a Ridgid Electrical Supply Expert? Answer questions, earn points and help others
